  2. Announcements
  3. 💬 Touch Display Scene Controller
15 Posts 9 Posters 6.6k Views 11 Watching
  • A
    artipi
    how long will the battery hold? Any tests?
      spacewombat
      Hi Everyone, seems Im late to the party. Only just stumbled upon this site tonight as Ive been struggling to get a mention display to work as a remote transmitter from one arduino nano and a NRF24L01 radio with a nextion basic 2.4" display, to another arduino either nano or uno clone board-nrf24l01 radio, and a l298 motor shield.
      It seems what you guys have been doing is very similar, only with standard tft panel and not nextion.
      Has anyone had any success with boards other than a mega? Im trying to keep the "remote control" part of the project as small as possible, even use a pro mini if I can...
      Looking forward to any sort of advice/code you can offer...?
        spacewombat
        With regards to powering the remotes, has anyone ever notice that the pins on a cr2032 coin battery holder fit straight into the VIN and GND pins of a Nano, works a charm you just have to cut a small piece of the plastic away from the battery holder to allow for the reset button. I used a dremel for this, but was the only mod I had to do , the battery holder is almost designed for it otherwise. Not sure how long it will last though, depends what you load its up with as always.
        • S spacewombat
          Big welcome to the MySensors forum @spacewombat !
          Cool observation about the battery holder.
          Using a Pro Mini with tft screens works, I have done it myself. The biggest limitation is the small ram and flash. Fonts, images, etc take up a lot of space. But if you only draw simple stuff on the screen it can definitely be done.
            spacewombat
            Thanks for the speedy response mate, its good to be on board with the my sensors crew, certainly helps to have like minded IOT tinkerers to bounce off.
            Good to know its possible with a pro mini too, very encouraging. I have a couple of standard tft screens available to try out, one is a 1.8" V1.0 SPI 128*160, it has a single row of pins down one side, blue pcb and takes a normal size sd card also.Pins are labeled on the screen, how did you go about hooking it up to the pro mini?
            The other is a red board 2.4" TFT LCD Shield for an uno, again, not sure how to go about connecting to the pro.
            Any advice mate?
            Also, Did you have to do much with the code, other than the pin assignments?
            I was actually starting to doubt whether it was possible to run nrf24lo1 as well as a display also with SPI, side by side on the smaller arduinos.
            • S spacewombat
              Any advice mate?
              @spacewombat https://forum.mysensors.org/post/34738 describes how I did. But it is not a way I would recommend :)
                spacewombat
                thanks for the link, I'm on my way to have a look.
                • SpannersS
                  SpannersS
                  Spanners
                  Hi All,
                  Does anyone know how to get the text to wrap on the buttons (or have multiple lines of text on the buttons)? UTFT_Buttons doesn't automatically word wrap, is there a way to put a CR/LF or something in the button string?
                  So using Hek's original exmaple sketch, having:
                  Good
                  Morning
                  Instead of:
                  Good Morning
                  • J
                    J
                    Jean Pierre Rojas Vanegas
                    To make this sketch works, you need to define: #define MY_RF24_CE_PIN 17 and #define MY_RF24_CS_PIN 18 or it'll not work.
                    • MGHaffM
                      MGHaffM
                      MGHaff
