  3. 💬 MySensors Nrf24/RFM Serial/Ethernet GW Shield (for Uno)
mysensorsnrf24l01+rfm69
28 Posts 4 Posters 4.2k Views 2 Watching
  • sundberg84S sundberg84
    @Nick-Willis - great to hear.
    By using dupont cables and "normal pinout" for RFM radio i now also get the new driver to work thanks to your input.
    #define MY_RADIO_RFM69
    #define MY_RFM69_NEW_DRIVER
    #define MY_RFM69_FREQUENCY RFM69_433MHZ // Set your frequency here
    #define MY_IS_RFM69HW
    //#define MY_SOFTSPI
    //#define MY_SOFT_SPI_SCK_PIN A0
    //#define MY_SOFT_SPI_MOSI_PIN A1
    //#define MY_SOFT_SPI_MISO_PIN A2
    //#ifndef MY_RF24_CE_PIN
    //#define MY_RF24_CE_PIN 5
    //#endif
    //#ifndef MY_RF24_CS_PIN
    //#define MY_RF24_CS_PIN 6
    //#endif
    #define MY_SIGNING_ATSHA204
    #define MY_SIGNING_ATSHA204_PIN A3
    #define MY_SIGNING_WEAK_SECURITY
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    ⸮S[0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RPNGAA--,FQ=16,REL=255,VER=2.3.2
    0;255;3;0;9;108 TSM:INIT
    0;255;3;0;9;111 TSF:WUR:MS=0
    0;255;3;0;9;114 TSM:INIT:TSP OK
    0;255;3;0;9;116 TSM:INIT:GW MODE
    0;255;3;0;9;119 TSM:READY:ID=0,PAR=0,DIS=0
    0;255;3;0;9;123 MCO:REG:NOT NEEDED
    0;255;0;0;18;2.3.2
    0;255;3;0;9;128 MCO:BGN:STP
    0;255;3;0;9;135 MCO:BGN:INIT OK,TSP=1
    0;255;3;0;9;138 TSM:READY:NWD REQ
    0;255;3;0;9;145 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    But with SofSPI engaged - not working-
    0;255;3;0;9;277 TSM:INIT
    0;255;3;0;9;279 TSF:WUR:MS=0
    0;255;3;0;9;282 !TSM:INIT:TSP FAIL
    0;255;3;0;9;285 TSM:FAIL:CNT=1
    0;255;3;0;9;288 TSM:FAIL:DIS
    0;255;3;0;9;290 TSF:TDI:TSL
    • Continuity on all logic level converters are OK
    • Not much traffic at all from the UNO in SPI. I guess the intial contact with the radio is faulty so thats why.
    It must be either connection Uno > Logic Level Shifter > Radio, code / defines or softwareSPI not working.
    #21
    I have now tested all SPI lines and its logic level converter individually.
    To be absolutely sure the hardware worked, I desoldered the radio and wrote a arduino program sending 5v in 5 sek over the same sofwareSPI lines and 0V over 5 sek - all behaved correctly, 3.3v and 0V.
    I also swapped radio, but same same...
    Not really sure how to proceed. I need to get the softwareSPI working or else I cant use it as a ethernet gateway.
    Is there someone here that got RFM gateway working with softwareSPI?
    I dont think its the hardware anymore...
    Code:
    //#define MY_IS_RFM69HW
    #define MY_SOFTSPI
    #define MY_RFM69_CS_PIN 6
    #define MY_RFM69_IRQ_PIN 2
      Code:
      #define MY_SOFTSPI
      #22
      What im noticing is that when I connect the radio, the IRQ line on D2 is 1.0v when high and not 3.3v. Anyone who knows this is normal behaviour? Same with two different (and comfirmed working) radios. SPI logic level converter is comfirmed working and changed with same behavoir.
      Edit > This is the same using normal pins and does not have anything to do with SPI. It works when not using softSPI and IRQ has this low voltage...
      • sundberg84S
        #23
        This post is deleted!
        • sundberg84S
          Anyone good with SPI channel analysis?
          Hardware SPI (Looks great):
          Software SPI (Same setup, just changed code and pins).
          In the first, I can clearly see MOSI and MISO communicating on 5/6. Enable on 7.
          Software SPI does not make any sense.
          H 1 Reply Last reply
            H
            H
            hlehoux
            @sundberg84 Hello, coming back to this RFM GW, so i will try it
            I have soldered between the two 3.3v rails , i confirm now i have 3.3v on the RFM module
            I will test with the softwareSPIs and report.
            I will give a try to your "quickfix" for hardwire : could you please explain or post a photo of what needs to be done for the hardwiring ?
            Thank you!
            • H hlehoux
              Thank you!
              @hlehoux My quickfix means you cant use the ethernet shield.
              All I did was solder with wires to the normal pins and made it a serial gateway.
                H
                H
                hlehoux
                wrote on last edited by hlehoux
                #27
                @sundberg84 thank you.
                i have ordered the components such as BSS138 so i will test when they arrive.I don't need ethernet
                • H
                  H
                  hlehoux
                  Hello, i'm making some progress; received the components this week.
                  Unfortunately it doesn't work... yet
                  For now i have SanityCheck failure in to logs.
                  I'm afraid my soldering of all these little components is not good. I tested with a multimeter the 4 pins and i have continuity on one of them but maybe not the others so i guess i will have to try remelting all these small regulators ???
