  3. Auto resend on NACK
Auto resend on NACK
23 Posts 6 Posters 5.4k Views 6 Watching
  • alowhumA Offline
    alowhumA Offline
    alowhum
    @mfalkvidd Thank you so much for the explanation! I feel I'm getting a grasp on things.
    • Mark SwiftM Offline
      Mark SwiftM Offline
      Mark Swift
      @mfalkvidd said in Auto resend on NACK:
      https://forum.mysensors.org/post/33832
      Would someone be kind enough to point me in the direction of a good software acknowledgement example? I've been building MySensors for 4 years and still have sensors that don't send reliable messages. While most have been replaced with ESP's - these sensors are extremely remote and battery powered (MySensors wins here!).
      Currently I use:
      void resend(MyMessage &msg, int repeats) {
              int repeat = 1;
              const int repeatDelay = 100;
              boolean sendOK = false;
              while ((sendOK == false) and (repeat <= repeats)) {
                      if (send(msg) == true) {
                              sendOK = true;
                      } else {
                              sendOK = false;
                              #ifdef MY_DEBUG
                              Serial.print(F("Send error: "));
                              Serial.println(repeat);
                              repeat++;
                              wait(repeatDelay);
      But this doesn't seem to ensure reliable delivery (some nodes send 10 msgs before sleeping). Often I get multiple messages arriving (I assume this is the burst), but some (often vital) never make it.
      • electrikE Offline
        electrikE Offline
        electrik
        You will get multiple messages, if the message arrives correctly but the hardware ACK doesn't.
        Do you have a repeater in between the sender and gateway? It could be that the repeater does receive the initial message (and the sensor gets a hardware ACK), but that never reaches the gateway because of a transmission error between the repeater and the gateway.
