  3. ESP8266 not connecting to router when not connected to PC
3 Posts 2 Posters 823 Views 2 Watching
  • B
    B
    beersmith
    Hi all
    I have problems with my ESP8266 connecting to the router when it is connected to the external power.
    I am using the ESP8266 as a GW with sensor (temp/hum or door switch) directly connected to D3. I have several of them working but the rule, and not the exception, is that I have the following problem at setup. I have had the problem with a variety of batches of 8266’es, various power sources and a few versions of sketches(albeit very similar).
    I set up the HW ie I attach the sensor to D3 an gnd, solder a short extension antenna to the board and push the code from the Arduino IDE. When I push the code, it usually loads without problem an the LED on the 8266 is blinking. When done it runs the code and connects to the router. I look it up in the router to document the MAC address and IP address and set a fixed IP address in the router. At this stage I can also set it up in Domoticz and get sensor readings. So far so good, as long as it is booted right after pushing the code, still connected to the PC. Now, when I disconnect from the PC and connect the 8266 to external power, usually a 2.4A USB charger, it blinks once. I look it up in the router and it has not connected and obviously Domoticz doesn’t see it either.
    I cannot claim it is a good hypothesis because I have no proof, but I get a feeling it does not boot properly. Maybe it doesn’t when I crudely connect it to the charger ? Maybe the answer can be found in the sketch or in the way I set things up ? Sometimes I get it to work due to magic or the phase of the moon and then I don’t touch it. Usually it then works OK once I got it going once.
    Attached I the sketch, only edited in respect to the SSID and PW.
    I would be grateful for tips. Hopefully someone can see something in the sketch that can be improved to make it more stable and boot better. Or increase the ability to troubleshoot (blinks or whatever??)
    Glad midsommar
    Beersmith
    Sketch below:
     * Doorswitch without NRF24L01 radio, only direct connected doorswitch
     * disabled MY_IP_GATEWAY_ADDRESS
     * Pasted code from sketch "BinarySwitchSensor"  to get locally connected switch
     * added#include <Bounce2.h>
     * changed to #define BUTTON_PIN "D3" instead of only "3"
     * enabled led blink
     * disablat inclusion mode (don't know if I had to but I was worried it would interfere with sensor on D3
     * changed version "maindoor" in order to find the right GW in Domoticz and in the router
     * Version 1.0 - Henrik EKblad
     * Contribution by Ivo Pullens (ESP8266 support)
     * The EthernetGateway sends data received from sensors to the WiFi link.
     * VERA CONFIGURATION:
     * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
     * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
     * LED purposes:
     * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
     * GND        GND
      * Inclusion mode button:
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_NRF24
    //#define MY_RF24_CHANNEL 14
    #define MY_GATEWAY_ESP8266
    // Hsand
    #define MY_ESP8266_SSID "DOVADO-XXXX"
    #define MY_ESP8266_PASSWORD "YYYY"
    // Enable UDP communication
    //#define MY_USE_UDP
    #define MY_ESP8266_HOSTNAME "MAindoor_GW_Hsand"
    // #define MY_IP_GATEWAY_ADDRESS 192,168,178,1
    // #define MY_IP_SUBNET_ADDRESS 255,255,255,0
    #define MY_PORT 5003
    // Enable inclusion mode
    // #define MY_INCLUSION_MODE_FEATURE
    // #define MY_INCLUSION_BUTTON_FEATURE
    // #define MY_INCLUSION_MODE_DURATION 60
    // #define MY_INCLUSION_MODE_BUTTON_PIN  3
    // Set blinking period
    // Flash leds on rx/tx/err
    // Led pins used if blinking feature is enabled above
    #if defined(MY_USE_UDP)
    #include <WiFiUdp.h>
    #include <ESP8266WiFi.h>
    // added from BinarySwitchSensor
    #define CHILD_ID 3
    #define BUTTON_PIN  D3  // Arduino Digital I/O pin for button/reed switch changed from 3 to D3
    Bounce debouncer = Bounce();
    int oldValue=-1;
      // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      sendSketchInfo("Binary switch Sensor", "1.0 maindoor_Hsand");
      present(CHILD_ID, S_DOOR);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
        // Send in the new value
         send(msg.set(value==HIGH ? 1 : 0));
         oldValue = value;
    • B beersmith
      Hi all
      Glad midsommar
      Beersmith
      Sketch below:
       * enabled led blink
       * LED purposes:
       * nRF24L01+  ESP8266
       * VCC        VCC
       * CE         GPIO4
       * CSN/CS     GPIO15
       * SCK        GPIO14
       * MISO       GPIO12
       * MOSI       GPIO13
       * GND        GND
      // Hsand
      #define CHILD_ID 3
      int oldValue=-1;
        // Setup the button
        debouncer.update();
           oldValue = value;
      @beersmith D3 (GPIO0) controls how the esp8266 boots. See https://github.com/espressif/esptool/wiki/ESP8266-Boot-Mode-Selection
      The ESP8266 will enter the serial bootloader when GPIO0 is held low on reset. Otherwise it will run the program in flash.
      Try connecting the button to a different pin. D1, D2, D5, D6 and D7 are usually safe to use (depending on which esp8266 board you are using).
      • B
        B
        beersmith
        Man ska inte ropa Hej...
        But it seems your tip was really working out.
        I tried D1 and D2 but had some other issues so I went back to D3 but made sure the doorswitch was not connected on boot, in order not to interfere. Then it boots, normally, connects to the router and subsequently to Domoticz.
        Thanx a lot ! // Beersmith
