  3. NUM_LEDS value in LED-Strip Sketch can not be more than "201"?
16 Posts 3 Posters 2.1k Views 3 Watching
  • Z
    Z
    zen85
    I am having a strange phenomenon here... I made a sketch for mysensors which works perfectly fine. Its a Flameeffekt where you can set the flameheight and intensity with the dimmer (lower value = more and highter flames). Its quite cool and works fine...
     * Example Dimmable Light
     * Code adapted from http://github.com/mysensors/MySensors/tree/master/examples/DimmableLight
    // Enable debug prints
    #define MY_NODE_ID 129
    #define MY_RADIO_RF24
    #define MY_RF24_CE_PIN 10
    #define MY_RF24_CS_PIN 9
    #define CHILD_ID 2
    #define LIGHT_OFF 0
    #define LIGHT_ON 1
    #define SN "Baum"
    #define SV "1.0"
    int16_t last_state = LIGHT_ON;
    int16_t last_dim = 100;
    MyMessage light_msg( CHILD_ID_LIGHT, V_STATUS );
    MyMessage dimmer_msg( CHILD_ID_LIGHT, V_PERCENTAGE );
    int16_t last_state = LIGHT_OFF;
    char rgb[7] = "00ff00"; // RGB value.
    int currentLevel = 0;  // Current dimmer level.
    int red = 100;
    int green = 100;
    int blue = 100;
    MyMessage dimmerMsg(CHILD_ID, V_PERCENTAGE);
    MyMessage lightMsg(CHILD_ID, V_STATUS);
    MyMessage rgbMsg(CHILD_ID, V_RGB);
    #include <Adafruit_NeoPixel.h>
    #ifdef __AVR__
      #include <avr/power.h>
    #define NUM_LEDS 200
    #define PIN 2
    Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRBW + NEO_KHZ800);
    int yada = 255;
    uint32_t magenta_ada = strip.Color(200, 0, 200);
    uint32_t red_ada = strip.Color(200, 0, 0);
    uint32_t black_ada = strip.Color(0, 0, 0);
      //update_light();
      Serial.println( "Blutmond - Digitalled Node ready to receive messages..." );
      strip.begin();
      strip.Color(55, 0, 33);
      strip.setBrightness(100);
      //strip.fill(black_ada);
      //strip.show(); // Initialize all pixels to 'off'
      //In MySensors2.x, first message must come from within loop()
      static bool first_message_sent = false;
      if ( first_message_sent == false ) {
        Serial.println( "Sending initial state..." );
        send_dimmer_message();
        send_status_message();
        send_rgb_message();
        first_message_sent = true;
        int yadacooling = 255/100 * last_dim;
        int yadasparkling = 255/100 * (100 - last_dim);
        int yadaspeed = 120/100 * last_dim;
        Fire(yadacooling,yadasparkling,yadaspeed);
      sendSketchInfo( SN, SV );
      present( CHILD_ID, S_RGB_LIGHT );
       if (message.type == V_RGB) {
        // Retrieve the RGB value from the incoming message.
        // RGB LED not implemented, just a dummy print.
        String hexstring = message.getString();
        hexstring.toCharArray(rgb, sizeof(rgb));
        Serial.print("Changing color to ");
        Serial.println(rgb);
         //getRGB(rgb);
      String rgb2 = rgb;
        Serial.println(rgb2);
      rgb2.toUpperCase();
      char c[7];
      rgb2.toCharArray(c, 8);
      red = hexcolorToInt(c[0], c[1]);
      green = hexcolorToInt(c[2], c[3]);
      blue = hexcolorToInt(c[4], c[5]);
      Serial.print("REED: "); Serial.println(red);
      Serial.print("green: "); Serial.println(green);
      Serial.print("blue: "); Serial.println(blue);
      update_light();
          send_rgb_message();
      //When receiving a V_STATUS command, switch the light between OFF
      //and the last received dimmer value
      if ( message.type == V_STATUS ) {
        Serial.println( "V_STATUS command received..." );
        int lstate = message.getInt();
        if (( lstate < 0 ) || ( lstate > 1 )) {
          Serial.println( "V_STATUS data invalid (should be 0/1)" );
          return;
        last_state = lstate;
        //If last dimmer state is zero, set dimmer to 100
        if (( last_state == LIGHT_ON ) && ( last_dim == 0 )) {
          last_dim=100;
        //Update constroller status
      } else if ( message.type == V_PERCENTAGE ) {
        Serial.println( "V_PERCENTAGE command received..." );
        int dim_value = constrain( message.getInt(), 0, 100 );
        if ( dim_value == 0 ) {
          //Update constroller with dimmer value & status
        } else {
          last_dim = dim_value;
          Serial.println(last_dim);
          int dimmerval = last_dim;
          //red = red /100 * dimmerval;
          //green = green /100 * dimmerval;
          //blue = blue /100 * dimmerval;
          Serial.println(dimmerval);
          //Driver.begin(); // begin
          //Driver.SetColor(red, green, blue); //Red. first node data
          //Driver.SetColor(red, green, blue); //Blue. second node data
          //Driver.end();
      } else {
        Serial.println( "Invalid command received..." );
        return;
      //Here you set the actual light state/level
      update_light();
    void update_light()
      //For this example, just print the light status to console.
      if ( last_state == LIGHT_OFF ) {
        Serial.println( "Light state: OFF" );
          // colorWipe(strip.Color(0, 0, 0), 0); // Red
          //Driver.SetColor(0, 0, 0); //Red. first node data
          //Driver.SetColor(0, 0, 0); //Blue. second node data
          //Driver.end();
      } else {
        Serial.print( "Light state: ON, Level: " );
        Serial.println( last_dim );
          int reddim = red /100 * last_dim;
          int greendim = green /100 * last_dim;
          int bluedim = blue /100 * last_dim;
         //colorWipe(strip.Color(red, green, blue), 2); // Red
          int yada = NUM_LEDS * last_dim / 100;
          Serial.print("yadavalue: " );
          Serial.println (yada);
          int pixelfiller = NUM_LEDS - yada ;
                Serial.print("pixelfiller: ");
          Serial.println (pixelfiller);
         //strip.fill(red_ada, 0, yada);
         //strip.fill(black_ada, yada, pixelfiller);
         //strip.show();
          //Driver.SetColor(reddim, greendim, bluedim); //Red. first node data
          //Driver.end();
    void send_rgb_message()
      send( rgbMsg.set(rgb));
    void send_dimmer_message()
      send( dimmerMsg.set( last_dim ) );
    void send_status_message()
        send( lightMsg.set( (int16_t)0) );
      } else {
        send( lightMsg.set( (int16_t)1) );
    void getRGB(String hexvalue) {
      hexvalue.toUpperCase();
      char c[7];
      hexvalue.toCharArray(c, 8);
      int red = hexcolorToInt(c[1], c[2]);
      int green = hexcolorToInt(c[3], c[4]);
      int blue = hexcolorToInt(c[5], c[6]);
      return red + green + blue;
    int hexcolorToInt(char upper, char lower)
      int uVal = (int)upper;
      int lVal = (int)lower;
      uVal = uVal > 64 ? uVal - 55 : uVal - 48;
      uVal = uVal << 4;
      lVal = lVal > 64 ? lVal - 55 : lVal - 48;
      //  Serial.println(uVal+lVal);
      return uVal + lVal;
    // Fill the dots one after the other with a color
    void colorWipe(uint32_t c, uint8_t wait) {
      for(uint16_t i=0; i<strip.numPixels(); i++) {
        strip.setPixelColor(i, c);
        strip.show();
        delay(wait);
    void Fire(int Cooling, int Sparking, int SpeedDelay) {
      static byte heat[NUM_LEDS];
      int cooldown;
      // Step 1.  Cool down every cell a little
      for( int i = 0; i < NUM_LEDS; i++) {
        cooldown = random(0, ((Cooling * 10) / NUM_LEDS) + 2);
        if(cooldown>heat[i]) {
          heat[i]=0;
        } else {
          heat[i]=heat[i]-cooldown;
      // Step 2.  Heat from each cell drifts 'up' and diffuses a little
      for( int k= NUM_LEDS - 1; k >= 2; k--) {
        heat[k] = (heat[k - 1] + heat[k - 2] + heat[k - 2]) / 3;
      // Step 3.  Randomly ignite new 'sparks' near the bottom
      if( random(255) < Sparking ) {
        int y = random(7);
        heat[y] = heat[y] + random(160,255);
        //heat[y] = random(160,255);
      // Step 4.  Convert heat to LED colors
      for( int j = 0; j < NUM_LEDS; j++) {
        setPixelHeatColor(j, heat[j] );
      showStrip();
      delay(SpeedDelay);
    void setPixelHeatColor (int Pixel, byte temperature) {
      // Scale 'heat' down from 0-255 to 0-191
      byte t192 = round((temperature/255.0)*191);
      // calculate ramp up from
      byte heatramp = t192 & 0x3F; // 0..63
      heatramp <<= 2; // scale up to 0..252
      // figure out which third of the spectrum we're in:
      if( t192 > 0x80) {                     // hottest
        setPixel(Pixel, 255, 255, heatramp);
      } else if( t192 > 0x40 ) {             // middle
        setPixel(Pixel, 255, heatramp, 0);
      } else {                               // coolest
        setPixel(Pixel, heatramp, 0, 0);
      int cooldown;
          heat[i]=0;
        } else {
        int y = random(7);
      showStrip();
      delay(SpeedDelay);
      } else {                               // coolest
    void showStrip() {
     #ifdef ADAFRUIT_NEOPIXEL_H
       // NeoPixel
       strip.show();
     #ifndef ADAFRUIT_NEOPIXEL_H
       // FastLED
       FastLED.show();
    void setPixel(int Pixel, byte red, byte green, byte blue) {
       // NeoPixel
       strip.setPixelColor(Pixel, strip.Color(red, green, blue));
       // FastLED
       leds[Pixel].r = red;
       leds[Pixel].g = green;
       leds[Pixel].b = blue;
    void setAll(byte red, byte green, byte blue) {
      for(int i = 0; i < NUM_LEDS; i++ ) {
        setPixel(i, red, green, blue);
      showStrip();
    what is weird is that if i set the value of the NUM_LEDS to more than 201 it stops working. the flames just dont work anymore eventhough mysensors works fine. If it just take the part of the LEDs and exclude mysensors it works perfectly fine again with higher values like 350...
    #define PIN 2
    #define NUM_LEDS 350
    // Parameter 1 = number of pixels in strip
    // Parameter 2 = pin number (most are valid)
    // Parameter 3 = pixel type flags, add together as needed:
    //   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
    //   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
    //   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
    //   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
     * Version 1.0 - Henrik Ekblad
     * Only sends a quick pulse via a reed relay. Useful to hack other devices with push
     * buttons. In my case, a cheap IKEA dishwasher that didn't have a timer.
    // security
    //#define MY_SIGNING_SIMPLE_PASSWD   "changeme"
    //#define MY_ENCRYPTION_SIMPLE_PASSWD "changeme"
    //#define MY_RF24_DATARATE RF24_250KBPS // Slower datarate offers more range. Only the + version of the radio supports 250kbps
    //#define MY_RF24_DATARATE RF24_1MBPS
    //#define MY_RF24_DATARATE RF24_2MBPS
    #define MY_NODE_ID 76
    //#define MY_RS485
    //#define MY_RF24_CE_PIN 49
    //#define MY_RF24_CS_PIN 53
    //#define MY_RF24_PA_LEVEL RF24_PA_MIN
    //#define MY_REPEATER_FEATURE
    // MySensors children
    #define DEVICE_STATUS_ID 0                          // The first 'child' of this device is a text field that contains status updates.
    #define RELAY_1_CHILD_ID 1 // MySensors child ID
    #define DONE_CHILD_ID 2 // MySensors child ID
    #define RELAY_1_PIN  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define PULSELENGTH 500 // How long the pulse should last (how long the button should be pressed).
    #define LOOPDURATION 600000
    #define ON_TOO_LONG 9 // If it's been on for X * 10 minutes, then it should send a message.
    #define RADIO_DELAY 150 // Keeps the bad Chinese radio happy / supplied with stable power.
    byte loopCounter = 0;
    boolean state = 0;
    byte retryCounter = 3;
    MyMessage charmsg(DEVICE_STATUS_ID, V_TEXT);        // Sets up the message format that we'll be sending to the MySensors gateway later. The first part is the ID of the specific sensor module on this node. The second part tells the gateway what kind of data to expect.
    MyMessage relaymsg(RELAY_1_CHILD_ID, V_STATUS);
    MyMessage donemsg(DONE_CHILD_ID, V_TRIPPED);
    void before()
      //for (int pin=0; pin < NUMBER_OF_RELAYS; pin++) {
      //  pinMode(pin + RELAY_1_PIN, OUTPUT);
      //  digitalWrite(pin, LOW);
        pinMode(RELAY_1_PIN, OUTPUT);
        digitalWrite(RELAY_1_PIN, LOW);
      sendSketchInfo(F("stepperzeug"), F("1.1")); wait(RADIO_DELAY);
      present(DEVICE_STATUS_ID, S_INFO, F("Status")); wait(RADIO_DELAY);
      present(RELAY_1_CHILD_ID, S_BINARY, F("Start")); wait(RADIO_DELAY);
      present(DONE_CHILD_ID, S_MOTION, F("Done?")); wait(RADIO_DELAY);
      //send(relaymsg.setSensor(RELAY_1_CHILD_ID).set( RELAY_OFF )); wait(200);
      //for (int i=0; i<NUMBER_OF_RELAYS; i++) {
        //present(sensor, S_BINARY, F("Start")); wait(100);
        //send(relaymsg.setSensor(RELAY_1).set( RELAY_OFF )); wait(100);
      wait(1000);
      Serial.begin(115200);
      Serial.println(F("Hello world, I am a dish washer."));
        strip.begin();
      if(isTransportReady()){
        Serial.println(F("Connected to gateway"));
      send(charmsg.setSensor(DEVICE_STATUS_ID).set( F("Dishwasher turned on"))); wait(RADIO_DELAY);
      send(relaymsg.set(state?false:true), true); wait(RADIO_DELAY); // Send new state and request ack back
      send(donemsg.setSensor(DONE_CHILD_ID).set(0)); wait(RADIO_DELAY);
      }else{
        Serial.println(F("Not connected to gateway"));
    Fire(-500,15,0);
    void messageRepeat(MyMessage &message, bool ack = true) {
      int repeat = 1;
      int repeats = 10;
      int repeatdelay = 0;
      boolean sendOK = false;
      Serial.print("Sending message of child ");
      Serial.println(message.sensor);
      while ((sendOK == false) and (repeat < repeats)) {
        if (send(message, ack)) {
          sendOK = true;
          Serial.print("Send OK");
        } else {
          sendOK = false;
          Serial.print("Send ERROR ");
          Serial.print(repeat);
          repeatdelay += RADIO_DELAY;
        if (ack == true) {
          Serial.println(" With ack ");
        } else {
          Serial.println(" Without ack ");
        repeat++;
        wait(repeatdelay);
      Serial.print("Incoming message for child: ");
      if (message.isAck() && message.sensor == RELAY_1_CHILD_ID) { // We got the ACK!
        Serial.println("- Received ACK for relay");
        retryCounter = 0;
      else{
        // Change relay state
        Serial.println("-Gateway wants to change relay position");
        if (message.type==V_STATUS) {
          Serial.print ("-Received V_status:");
          if( message.sensor == RELAY_1_CHILD_ID ){
            boolean desiredState = message.getBool()?RELAY_ON:RELAY_OFF;
              if(desiredState == RELAY_ON){
              //digitalWrite(message.sensor-1+RELAY_1_PIN, RELAY_ON);
              //wait(PULSELENGTH);
              //digitalWrite(message.sensor-1+RELAY_1_PIN, RELAY_OFF);
              Serial.print ("-Switching relay on...");
              digitalWrite(RELAY_1_PIN, RELAY_ON);
              //Serial.println ("Switching relay off.");
              //digitalWrite(RELAY_1_PIN, RELAY_OFF);
              send(relaymsg.set(RELAY_ON), true); wait(RADIO_DELAY);
              //retryCounter = 3;
              if(desiredState == RELAY_OFF){
              //Serial.print ("-Switching relay on...");
              //digitalWrite(RELAY_1_PIN, RELAY_ON);
              send(relaymsg.set(RELAY_OFF), true); wait(RADIO_DELAY);
              //retryCounter = 3;
          //digitalWrite(message.sensor-1+RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF);
          // Store state in eeprom
          // Write some debug info
      int cooldown;
          heat[i]=0;
        } else {
        int y = random(7);
      showStrip();
      delay(SpeedDelay);
      byte t192 = round((temperature/255.0)*150);
      heatramp <<= 0; // scale up to 0..252
      } else {                               // coolest
    // *** REPLACE TO HERE ***
    void showStrip() {
       // NeoPixel
       strip.show();
       // FastLED
       FastLED.show();
       // NeoPixel
       // FastLED
      showStrip();
    just adding mysensors makes it weird. I tried everything but nothing works so far. does anybody have an idea?
    electrikE 1 Reply Last reply
    • Z zen85
      #define CHILD_ID 2
      #define LIGHT_OFF 0
      #define LIGHT_ON 1
      #define SN "Baum"
      #define SV "1.0"
      int red = 100;
      int green = 100;
      int blue = 100;
      #ifdef __AVR__
      #define PIN 2
      int yada = 255;
        //update_light();
        strip.begin();
          send_rgb_message();
           //getRGB(rgb);
        String rgb2 = rgb;
        rgb2.toUpperCase();
        char c[7];
        update_light();
            send_rgb_message();
            return;
            last_dim=100;
          } else {
            //Driver.end();
        } else {
          return;
        update_light();
      void update_light()
            //Driver.end();
        } else {
           //strip.show();
            //Driver.end();
        } else {
        char c[7];
        uVal = uVal << 4;
        return uVal + lVal;
          strip.show();
          delay(wait);
        int cooldown;
            heat[i]=0;
          } else {
          int y = random(7);
        showStrip();
        delay(SpeedDelay);
        } else {                               // coolest
        int cooldown;
            heat[i]=0;
          } else {
          int y = random(7);
        showStrip();
        delay(SpeedDelay);
        } else {                               // coolest
      void showStrip() {
         // NeoPixel
         strip.show();
         // FastLED
         FastLED.show();
         // NeoPixel
         // FastLED
        showStrip();
      #define PIN 2
      // security
      //#define MY_RS485
      boolean state = 0;
      void before()
        wait(1000);
          strip.begin();
        }else{
      Fire(-500,15,0);
        int repeat = 1;
        int repeats = 10;
            sendOK = true;
          } else {
            sendOK = false;
          if (ack == true) {
          } else {
          repeat++;
          wait(repeatdelay);
          retryCounter = 0;
        else{
                //retryCounter = 3;
                //retryCounter = 3;
        int cooldown;
            heat[i]=0;
          } else {
          int y = random(7);
        showStrip();
        delay(SpeedDelay);
        } else {                               // coolest
      void showStrip() {
         // NeoPixel
         strip.show();
         // FastLED
         FastLED.show();
         // NeoPixel
         // FastLED
        showStrip();
      electrikE
      electrikE
      electrik
      @zen85 could it be you have an overflow somewhere. You multiply num_leds by another value into an int, perhaps that should be a long
      Z 1 Reply Last reply
      • Z
        Z
        zen85
        first i had the same thought. so i tried adding the flames to another really simple mysensors-relaysketch which have nothing to do with each other and the same thing happens... values over 201 brake the flames entirely as long as there is a mysensors-radio running. i tried with that code:
        #define PIN 2
        // security
        //#define MY_RS485
        boolean state = 0;
        void before()
          wait(1000);
            strip.begin();
          }else{
        Fire(-500,15,0);
          int repeat = 1;
          int repeats = 10;
              sendOK = true;
            } else {
              sendOK = false;
            if (ack == true) {
            } else {
            repeat++;
            wait(repeatdelay);
            retryCounter = 0;
          else{
                  //retryCounter = 3;
                  //retryCounter = 3;
          int cooldown;
              heat[i]=0;
            } else {
            int y = random(7);
          showStrip();
          delay(SpeedDelay);
          } else {                               // coolest
        void showStrip() {
           // NeoPixel
           strip.show();
           // FastLED
           FastLED.show();
           // NeoPixel
           // FastLED
          showStrip();
        whereas:
        #define PIN 2
          strip.begin();
        // *** REPLACE FROM HERE ***
          Fire(-500,15,0);
          int cooldown;
              heat[i]=0;
            } else {
            int y = random(7);
          showStrip();
          delay(SpeedDelay);
          } else {                               // coolest
        void showStrip() {
           // NeoPixel
           strip.show();
           // FastLED
           FastLED.show();
           // NeoPixel
           // FastLED
          showStrip();
        works perfectly fine....
        its really strange.
        • Z zen85
          #define PIN 2
          // security
          //#define MY_RS485
          boolean state = 0;
          void before()
            wait(1000);
              strip.begin();
            }else{
          Fire(-500,15,0);
            int repeat = 1;
            int repeats = 10;
                sendOK = true;
              } else {
                sendOK = false;
              if (ack == true) {
              } else {
              repeat++;
              wait(repeatdelay);
              retryCounter = 0;
            else{
                    //retryCounter = 3;
                    //retryCounter = 3;
            int cooldown;
                heat[i]=0;
              } else {
              int y = random(7);
            showStrip();
            delay(SpeedDelay);
            } else {                               // coolest
          void showStrip() {
             // NeoPixel
             strip.show();
             // FastLED
             FastLED.show();
             // NeoPixel
             // FastLED
            showStrip();
          whereas:
          #define PIN 2
            strip.begin();
            Fire(-500,15,0);
            int cooldown;
                heat[i]=0;
              } else {
              int y = random(7);
            showStrip();
            delay(SpeedDelay);
            } else {                               // coolest
          void showStrip() {
             // NeoPixel
             strip.show();
             // FastLED
             FastLED.show();
             // NeoPixel
             // FastLED
            showStrip();
          its really strange.
          electrikE
          electrikE
          electrik
          @zen85 I also see a delay being used. Can you change that to a wait()…?
            Are you getting a message regarding low memory when uplpading?
            Looks like you might be using an atmega328. It has a total of 2kB ram.
            201 pixels use 603 bytes, plus another 201 for the heat so 804 bytes. That could very well be at the limit.
            When verifying the sketch, you should get something similar to this:
            Global variables use 1278 bytes (62%) of dynamic memory, leaving 770 bytes for local variables. Maximum is 2048 bytes.
              Z
              Z
              zen85
              @mfalkvidd
              actually i am using a nano.
              it tells me:
              Sketch uses 18372 bytes (59%) of program storage space. Maximum is 30720 bytes.
              Global variables use 1070 bytes (52%) of dynamic memory, leaving 978 bytes for local variables. Maximum is 2048 bytes.
              but there is no warning...
              @electrik
              using wait(...) instead of delay(...) just gives me "wait can not be used as a function arduino" and nothing compiles... did you mean millis(...)?
              • electrikE electrik
                Z
                Z
                zen85
                @electrik
                i also tried to change it into long but there is no change in behaviour...
                • Z zen85
                  @mfalkvidd
                  it tells me:
                  @electrik
                  electrikE
                  electrikE
                  electrik
                  @zen85 that is strange. Are you using the latest drivers?
                  See wait here
                  https://www.mysensors.org/download/sensor_api_20
                    See wait here
                    Z
                    Z
                    zen85
                    wrote on last edited by zen85
                    @electrik
                    its indeed strange.
                    i am using 2.3.1 - so this should be ok.... i replaced delay(wait) with wait(wait) which throws:
                    "'wait' cannot be used as a function"
                    my nano uses the "atmega328p (Old Bootloader)" as processor... could that be an issue but i dont see how...?
                    • Z zen85
                      @electrik
                      its indeed strange.
                      Z
                      Z
                      zen85
                      @zen85 said in NUM_LEDS value in LED-Strip Sketch can not be more than "201"?:
                      @electrik
                      its indeed strange.
                      ok... i see why wait(wait) was a problem... i displaced the variable "wait" with another one and then it compiles... but it has no impact on the issue.
                      i also checked out the limit again... it actually works up to 207 leds... more than that and it breaks...
                      • Z
                        Z
                        zen85
                        oke.... apparently the storage for variables was too low on the nano.
                        i replaced it with a mega and now it works.
                        • electrikE
                          electrikE
                          electrik
                          I'm starting to run out of ideas... Is it just the flames that stop working, or is the normal dining still working (when you disable the flames code).
                          It seems to me the mysensors task maybe takes to much time from the led strip library, which is quite time critical
                            Seems like teh Arduino IDE is unable to calculate the memory usage for the Adafruit led strip object.
                            When the Arduino IDE outputs
                            Global variables use 1078 bytes (52%) of dynamic memory, leaving 970 bytes for local variables. Maximum is 2048 bytes
                            it has not added the 603 bytes used by the Adafruit led strip object. So the real usage is 1 681 bytes which is 82%.
                            Some general information on how Arduino memory works https://learn.adafruit.com/memories-of-an-arduino/optimizing-program-memory but there is not much you can do except switching to a mcu with more ram.
                              Z
                              Z
                              zen85
                              @electrik
                              @mfalkvidd
                              its exactly as you guys say. taking a mega solves my issue and thats fine. i work with arduinos for many years now but its the first time i ran out of storage so i did not have this on the radar. i also learned much about arduinos with that issue. i guess thats a huge thanks for steering me into the right direction.
                              • Z zen85
                                @electrik
                                @mfalkvidd
                                learning is the most fun part of Arduino (at least for me) :-)
                                Great work! If you have the time, you're very welcome to share a photo or video of your project. I have gotten a lot of inspiration from stuff other people have made.
                                  Z
                                  Z
                                  zen85
                                  @mfalkvidd
                                  i will definetly do that within the next days.
