  3. [SOLVED] Sensbender Gateway gives a lot of "hu"
7 Posts 3 Posters 1.7k Views 3 Watching
  • magpernM
    magpernM
    magpern
    I'm trying to revive my MySensors network, and started by flasking a new GatewaySerial to the Sensbender Gateway. I have the NRF24 long range version connected to it.
    When the sketch starts this is what I get and it looks wrong to me. A lot of "hu".
    I have cleared eeprom, but still the same. I ave not changed anything, it is stock 2.3.1 and stock GatewaySerial.
    Any idea what I should try next?
    0;255;hu;0;hu;3 MCO:BGN:INIT GW,CP=RNNGS---,REL=hu,VER=2.3.1
    0;255;hu;0;hu;3 TSF:LRT:OK
    0;255;hu;0;hu;3 TSM:INIT
    0;255;hu;0;hu;3 TSF:WUR:MS=0
    0;255;hu;0;hu;3 TSM:INIT:TSP OK
    0;255;hu;0;hu;3 TSM:INIT:GW MODE
    0;255;hu;0;hu;3 TSM:READY:ID=hu,PAR=hu,DIS=hu
    0;255;hu;0;hu;3 MCO:REG:NOT NEEDED
    hu;hu;hu;hu;hu;�
    hu;hu;hu;hu;hu;�
    0;255;hu;0;hu;3 MCO:BGN:STP
    0;255;hu;0;hu;3 MCO:BGN:INIT OK,TSP=hu
    0;255;hu;0;hu;3 TSM:READY:NWD REQ
    0;255;hu;0;hu;3 TSF:MSG:SEND,hu-hu-hu-hu,s=hu,c=hu,t=hu,pt=hu,l=hu,sg=hu,ft=hu,st=�:�```
    tekkaT 1 Reply Last reply
    • magpernM magpern
      hu;hu;hu;hu;hu;�
      hu;hu;hu;hu;hu;�
      tekkaT
      tekkaT
      tekka
      @magpern This originates from the updated Arduino SAMD board definitions (>1.8.1) and is fixed in the dev branch. You can add
      #undef PRId8
      #undef PRIi8
      #undef PRIo8
      #undef PRIu8
      #undef PRIx8
      #undef PRIX8
      #undef PRIdLEAST8
      #undef PRIiLEAST8
      #undef PRIoLEAST8
      #undef PRIuLEAST8
      #undef PRIxLEAST8
      #undef PRIXLEAST8
      #undef PRIdFAST8
      #undef PRIiFAST8
      #undef PRIoFAST8
      #undef PRIuFAST8
      #undef PRIxFAST8
      #undef PRIXFAST8
      #define PRId8		"d"
      #define PRIi8		"i"
      #define PRIo8		"o"
      #define PRIu8		"u"
      #define PRIx8		"x"
      #define PRIX8		"X"
      #define PRIdLEAST8	"d"
      #define PRIiLEAST8	"i"
      #define PRIoLEAST8	"o"
      #define PRIuLEAST8	"u"
      #define PRIxLEAST8	"x"
      #define PRIXLEAST8	"X"
      #define PRIdFAST8	"d"
      #define PRIiFAST8	"i"
      #define PRIoFAST8	"o"
      #define PRIuFAST8	"u"
      #define PRIxFAST8	"x"
      #define PRIXFAST8	"X"
      before the MySensor.h include to temporarily fix that.
      magpernM 1 Reply Last reply
      • tekkaT tekka
        #undef PRId8
        #undef PRIi8
        #undef PRIo8
        #undef PRIu8
        #undef PRIx8
        #undef PRIX8
        #undef PRIdLEAST8
        #undef PRIiLEAST8
        #undef PRIoLEAST8
        #undef PRIuLEAST8
        #undef PRIxLEAST8
        #undef PRIXLEAST8
        #undef PRIdFAST8
        #undef PRIiFAST8
        #undef PRIoFAST8
        #undef PRIuFAST8
        #undef PRIxFAST8
        #undef PRIXFAST8
        #define PRId8		"d"
        #define PRIi8		"i"
        #define PRIo8		"o"
        #define PRIu8		"u"
        #define PRIx8		"x"
        #define PRIX8		"X"
        magpernM
        magpernM
        magpern
        @tekka Thanks! Development branch worked
        • pepsonP
          pepsonP
          pepson
          @tekka said in [SOLVED] Sensbender Gateway gives a lot of "hu":
          Hi
          I have a problem. I buy Sensbender Gateway and compile it with radio RFM69HW and write.... This is my sketch:
          * The ArduinoGateway prints data received from sensors on the serial link.
          * The gateway accepts input on serial which will be sent out on radio network.
          * This GW code is designed for Sensebender GateWay / (Arduino Zero variant)
          * Wire connections (OPTIONAL):
          * - Inclusion button should be connected to SW2
          * LEDs on board (default assignments):
          * - Orange: USB RX/TX - Blink when receiving / transmitting on USB CDC device
          * - Yellow: RX  - Blink fast on radio message received. In inclusion mode will blink fast only on presentation received
          * - Green : TX  - Blink fast on radio message transmitted. In inclusion mode will blink slowly
          * - Red   : ERR - Fast blink on error during transmission error or receive crc error
          * - Blue  : free - (use with LED_BLUE macro)
          #define SKETCH_VERSION "0.2"
          //#define MY_RADIO_RF24
          //#define MY_RADIO_NRF5_ESB
          //#define MY_RADIO_RFM95
          #define MY_RADIO_RFM69
          #define MY_IS_RFM69HW
          #define RFM69_868MH
          #define MY_RFM69_NEW_DRIVER
          //#define MY_RF24_PA_LEVEL RF24_PA_HIGH
          // Enable serial gateway
          #define MY_GATEWAY_SERIAL
          // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & Sensebender)
          #if F_CPU == 8000000L
          #define MY_BAUD_RATE 38400
          // Enable inclusion mode
          // Set blinking period
          // Flash leds on rx/tx/err
          #include <SD.h>
          #include <drivers/ATSHA204/ATSHA204.cpp>
          Sd2Card card;
          #define EEPROM_VERIFICATION_ADDRESS 0x01
          static uint8_t num_of_leds = 5;
          static uint8_t leds[] = {LED_BLUE, LED_RED, LED_GREEN, LED_YELLOW, LED_ORANGE};
          void preHwInit()
          	pinMode(MY_SWC1, INPUT_PULLUP);
          	pinMode(MY_SWC2, INPUT_PULLUP);
          	if (digitalRead(MY_SWC1) && digitalRead(MY_SWC2)) {
          		return;
          	uint8_t tests = 0;
          	for (int i=0; i< num_of_leds; i++) {
          		pinMode(leds[i], OUTPUT);
          	if (digitalRead(MY_SWC1)) {
          		uint8_t led_state = 0;
          		while (!Serial) {
          			digitalWrite(LED_BLUE, led_state);
          			led_state ^= 0x01;
          			delay(500);
          		} // Wait for USB to be connected, before spewing out data.
          	if (Serial) {
          		Serial.println("Sensebender GateWay test routine");
          		Serial.print("MySensors core version : ");
          		Serial.println(MYSENSORS_LIBRARY_VERSION);
          		Serial.print("GateWay sketch version : ");
          		Serial.println(SKETCH_VERSION);
          		Serial.println("----------------------------------");
          		Serial.println();
          	if (testSha204()) {
          		digitalWrite(LED_GREEN, HIGH);
          		tests++;
          	if (testSDCard()) {
          		digitalWrite(LED_YELLOW, HIGH);
          		tests++;
          	if (testEEProm()) {
          		digitalWrite(LED_ORANGE, HIGH);
          		tests++;
          	if (tests == 4) {
          		while(1) {
          			for (int i=0; i<num_of_leds; i++) {
          				digitalWrite(leds[i], HIGH);
          				delay(200);
          				digitalWrite(leds[i], LOW);
          	} else {
          		while (1) {
          			digitalWrite(LED_RED, HIGH);
          			delay(200);
          			digitalWrite(LED_RED, LOW);
          			delay(200);
          bool testSha204()
          	uint8_t rx_buffer[SHA204_RSP_SIZE_MAX];
          	uint8_t ret_code;
          	if (Serial) {
          		Serial.print("- > SHA204 ");
          	atsha204_init(MY_SIGNING_ATSHA204_PIN);
          	ret_code = atsha204_wakeup(rx_buffer);
          	if (ret_code == SHA204_SUCCESS) {
          		ret_code = atsha204_getSerialNumber(rx_buffer);
          		if (ret_code != SHA204_SUCCESS) {
          			if (Serial) {
          				Serial.println(F("Failed to obtain device serial number. Response: "));
          			Serial.println(ret_code, HEX);
          		} else {
          			if (Serial) {
          				Serial.print(F("Ok (serial : "));
          				for (int i=0; i<9; i++) {
          					if (rx_buffer[i] < 0x10) {
          						Serial.print('0'); // Because Serial.print does not 0-pad HEX
          					Serial.print(rx_buffer[i], HEX);
          				Serial.println(")");
          			return true;
          	} else {
          		if (Serial) {
          			Serial.println(F("Failed to wakeup SHA204"));
          	return false;
          bool testSDCard()
          	if (Serial) {
          		Serial.print("- > SD CARD ");
          	if (!card.init(SPI_HALF_SPEED, MY_SDCARD_CS)) {
          		if (Serial) {
          			Serial.println("SD CARD did not initialize!");
          	} else {
          		if (Serial) {
          			Serial.print("SD Card initialized correct! - ");
          			Serial.print("type detected : ");
          			switch(card.type()) {
          			case SD_CARD_TYPE_SD1:
          				Serial.println("SD1");
          				break;
          			case SD_CARD_TYPE_SD2:
          				Serial.println("SD2");
          				break;
          			case SD_CARD_TYPE_SDHC:
          				Serial.println("SDHC");
          				break;
          			default:
          				Serial.println("Unknown");
          		return true;
          	return false;
          bool testEEProm()
          	uint8_t eeprom_d1, eeprom_d2;
          	SerialUSB.print(" -> EEPROM ");
          	eeprom_d1 = hwReadConfig(EEPROM_VERIFICATION_ADDRESS);
          	delay(500);
          	eeprom_d1 = ~eeprom_d1; // invert the bits
          	hwWriteConfig(EEPROM_VERIFICATION_ADDRESS, eeprom_d1);
          	delay(500);
          	eeprom_d2 = hwReadConfig(EEPROM_VERIFICATION_ADDRESS);
          	if (eeprom_d1 == eeprom_d2) {
          		SerialUSB.println("PASSED");
          		hwWriteConfig(EEPROM_VERIFICATION_ADDRESS, ~eeprom_d1);
          		return true;
          	SerialUSB.println("FAILED!");
          	return false;
          bool testAnalog()
          	int bat_detect = analogRead(MY_BAT_DETECT);
          	Serial.print("-> analog : ");
          	Serial.print(bat_detect);
          	if (bat_detect < 400 || bat_detect > 650) {
          		Serial.println(" Failed");
          		return false;
          	Serial.println(" Passed");
          	return true;
          On serial port monitor show me this:
          0;255;hu;0;hu;3 MCO:BGN:INIT GW,CP=RPNGS---,VER=2.2.0
          hu;hu;hu;hu;hu;⸮
          hu;hu;hu;hu;hu;⸮
          I connect it to my raspberry pi 4 with Hass.io image 3.3. Then in configuration add it:
          mysensors:
          gateways:
          - device: '/dev/ttyACM0'
          persistence_file: '/config/mysensors.json'
          baud_rate: 38400
          optimistic: false
          persistence: true
          version: '2.2'
          and still in log has info:
          Gateway /dev/ttyACM0 not ready after 15.0 secs so continuing with setup
          20:56 components/mysensors/gateway.py (WARNING)
          In hardware on hassio show this:
          /dev/ttyACM0
          /dev/serial/by-id/usb-MySensors.org_Sensebender_GW_6A153443514D355934202020FF10182D-if00
          /dev/ttyAMA0
          Please help me what i do wrong...and how resolved this problem.
          • pepsonP pepson
            Hi
            #define RFM69_868MH
            #include <SD.h>
            Sd2Card card;
            void preHwInit()
            		return;
            	uint8_t tests = 0;
            		while (!Serial) {
            			led_state ^= 0x01;
            			delay(500);
            	if (Serial) {
            		Serial.println();
            	if (testSha204()) {
            		tests++;
            	if (testSDCard()) {
            		tests++;
            	if (testEEProm()) {
            		tests++;
            	if (tests == 4) {
            		while(1) {
            				delay(200);
            	} else {
            		while (1) {
            			delay(200);
            			delay(200);
            bool testSha204()
            	uint8_t ret_code;
            	if (Serial) {
            			if (Serial) {
            		} else {
            			if (Serial) {
            			return true;
            	} else {
            		if (Serial) {
            	return false;
            bool testSDCard()
            	if (Serial) {
            		if (Serial) {
            	} else {
            		if (Serial) {
            				break;
            				break;
            				break;
            			default:
            		return true;
            	return false;
            bool testEEProm()
            	delay(500);
            	delay(500);
            		return true;
            	return false;
            bool testAnalog()
            		return false;
            	return true;
            hu;hu;hu;hu;hu;⸮
            hu;hu;hu;hu;hu;⸮
            mysensors:
            gateways:
            baud_rate: 38400
            optimistic: false
            persistence: true
            version: '2.2'
            /dev/ttyACM0
            /dev/ttyAMA0
            magpernM
            magpernM
            magpern
            wrote on last edited by magpern
            @pepson said in [SOLVED] Sensbender Gateway gives a lot of "hu":
            It is the exact same problem as I had. Do what @tekka said. Either put in the code he suggested, or git clone the development branch. The development branch works fine, the "hu" will go away
            And if git clone is to difficult. Download the dev branch github as zip, unzip it and replace the entire "MySensors" folder on your computer. Exactly where it is, I don't know. It's in the library folder where Arduino is installed
            pepsonP 1 Reply Last reply
            • magpernM magpern
              pepsonP
              pepsonP
              pepson
              @magpern
              But mysensors newer than 2.2.0 has problems with radio Rfm69hw.
              • pepsonP pepson
                @magpern
                magpernM
                magpernM
                magpern
                @magpern
                That I don't know anything about. I don't have any Rfm69w for the moment, but I know I ran a rfm69 directly of a raspberry pi about 5 month ago ant that worked fine. And that was the development branch, so more than 2.2.0
