Arduino Mega gw wired directly via USB to HASS.IO?
I swear I've spend hours pouring over the documentation and the forums, but I simply cannot find a straight or working answer for this.
I'd like to use an Arduino Mega as both a gateway AND use its pins as sensors/switches, and I'd like to connect it directly to a Raspberry Pi 3 B+ running Home Assistant (hass.io) and use Home Assistant as the controller.
I know 98% of peoples uses cases are wireless, so they involve radios, but mine is all wired and I'd like to do it as I describe.
As far as I can tell, this involves Serial communication somehow, but its not exactly clear either how to initialize MySensors gateway sketch to communicate over the USB port much less how that is accessed on the USB host device.
Can someone please point me in the right direction for what I'd like to do? Any help would be greatly appreciated.
Hin@servo386, welcome to the forum!
Yes, you are on the right track. In MySensors terminology, the Mega becomes a serial gateway with locally attached sensors.
Build a serial gateway as described on https://www.mysensors.org/build/serial_gateway but comment out #define MY_RADIO_RF24 since you don't need any other sensor nodes.
In the serial gateway example, add code for your locally attached sensors, just as if you were building a "normal" MySensors node.
Upload the sketch to the mega, with debug turned on, and make sure the mega is able to read the sensors.
Connect the mega to the controller computer over usb. Add it to Hass following the instructions linked in "plugin and install instructions" at https://www.mysensors.org/controller/homeassistant
Thank you so much! I've got the example "door open/door close" dummy sensor sketch succesfully talking to my HASS.IO.
I'm literally going to type this sentence so that people might find this later in a forum search if they are looking like I was for an answer: direct to USB, wired USB, hass.io arduino mega, serial gateway no radio, local sensor no radio serial gateway usb.
Sorry for that but i was tearing my hair out looking for this simple solution and could not find it.
The trick is to comment out the RF radios (all of them). It wasn't clear to me that blanking out all the radios meant it would still do serial. The part to config on the HASS seemed clear to me (/dev/ttyACM0) but since I couldn't get the gateway part to work I had no idea if that was even right.
Again, thanks so much.
Could I bother you to ask:
Now that I've made my fake door open and close a bunch, is there an example that shows the initializing and presenting of multiple local sensors (local to the gateway) and what that looks like?
I tried to simply put another
present(2, S_DOOR)as child 2 and another door but.. I dont think HA see's it. Am i approaching this wrong?Also, does
sendSketchInfohave to be done for every sensor local to the gateway or is it just presenting the one name under which all the sensors will be "children" ?Any help would be appreciated.
Thanks! I have successfully created TWO dummy doors now! lol
This was instructive to understanding how the presentation of multiple local sensors looks like, since most examples show only one.
My next task is to learn how to control a switch (ie two way communication)
Here it is for anyone else for whom this might be helpful:
#include <MySensors.h> #define OPEN_DOORONE 1 #define CLOSE_DOORONE 0 #define CLOSE_DOORTWO 0 #define OPEN_DOORTWO 1 #define DOORONE_ID 1 #define DOORTWO_ID 2 MyMessage msg1(DOORONE_ID, V_TRIPPED); MyMessage msg2(DOORTWO_ID, V_TRIPPED); uint8_t value_doorone = OPEN_DOORONE; uint8_t value_doortwo = OPEN_DOORTWO; void setup() { // Setup locally attached sensors } void presentation() { // Present locally attached sensors sendSketchInfo("JERTestDoorsss", "1.0"); present(DOORONE_ID, S_DOOR); present(DOORTWO_ID, S_DOOR); } void loop() { // Send locally attached sensor data here value_doorone = value_doorone == OPEN_DOORONE ? CLOSE_DOORONE : OPEN_DOORONE; send(msg1.set(value_doorone)); sleep(2000); value_doortwo = value_doortwo == OPEN_DOORTWO ? CLOSE_DOORTWO : OPEN_DOORTWO; send(msg2.set(value_doortwo)); sleep(2000); value_doortwo = value_doortwo == OPEN_DOORTWO ? CLOSE_DOORTWO : OPEN_DOORTWO; send(msg2.set(value_doortwo)); sleep(2000); value_doortwo = value_doortwo == OPEN_DOORTWO ? CLOSE_DOORTWO : OPEN_DOORTWO; send(msg2.set(value_doortwo)); sleep(2000); value_doortwo = value_doortwo == OPEN_DOORTWO ? CLOSE_DOORTWO : OPEN_DOORTWO; send(msg2.set(value_doortwo)); sleep(2000); } -
So trying to activate a switch (by reading the state of a binary value) does not seem to be working.
With this code, my 2 fake doors show up in Home Assistant, but my S_BINARY does not, despite presenting it. Am I missing something?
#include <MySensors.h> #define OPEN_DOORONE 1 #define CLOSE_DOORONE 0 #define CLOSE_DOORTWO 0 #define OPEN_DOORTWO 1 #define DOORONE_ID 1 #define DOORTWO_ID 2 #define LEDSWITCH_ID 3 #define RELAY_PIN 11 #define RELAY_ON 1 #define RELAY_OFF 0 MyMessage msg1(DOORONE_ID, V_TRIPPED); MyMessage msg2(DOORTWO_ID, V_TRIPPED); uint8_t value_doorone = OPEN_DOORONE; uint8_t value_doortwo = OPEN_DOORTWO; bool state; void before() { pinMode(RELAY_PIN, OUTPUT); digitalWrite(RELAY_PIN, RELAY_OFF); } void setup() { // Setup locally attached sensors } void presentation() { // Present locally attached sensors sendSketchInfo("JERTestDoorsss", "1.0"); present(DOORONE_ID, S_DOOR); present(DOORTWO_ID, S_DOOR); present(LEDSWITCH_ID, S_BINARY); } void loop() { // Send locally attached sensor data here value_doorone = value_doorone == OPEN_DOORONE ? CLOSE_DOORONE : OPEN_DOORONE; send(msg1.set(value_doorone)); sleep(2000); value_doortwo = value_doortwo == OPEN_DOORTWO ? CLOSE_DOORTWO : OPEN_DOORTWO; send(msg2.set(value_doortwo)); sleep(2000); value_doortwo = value_doortwo == OPEN_DOORTWO ? CLOSE_DOORTWO : OPEN_DOORTWO; send(msg2.set(value_doortwo)); sleep(2000); value_doortwo = value_doortwo == OPEN_DOORTWO ? CLOSE_DOORTWO : OPEN_DOORTWO; send(msg2.set(value_doortwo)); sleep(2000); value_doortwo = value_doortwo == OPEN_DOORTWO ? CLOSE_DOORTWO : OPEN_DOORTWO; send(msg2.set(value_doortwo)); sleep(2000); } void receive(const MyMessage &message) { if (message.type == V_STATUS) { state = message.getBool(); digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF); } }``` -
Not even just using the example relay code works. destined output pin is permanently on (HIGH) and activating the switch in controller has no effect on it.
Help please....
Hi servo. Below is my sketch that works in Home Assistant (DHT, reed, relay, motion sensors). It has only problem with multiple DHT but I'm working on it.
When connecting via USB use: #define MY_GATEWAY_SERIAL
// Enable debug prints to serial monitor #define MY_DEBUG // Enable serial gateway #define MY_GATEWAY_SERIAL // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender) #if F_CPU == 8000000L #define MY_BAUD_RATE 38400 #endif // Enable inclusion mode #define MY_INCLUSION_MODE_FEATURE // Enable Inclusion mode button on gateway #define MY_INCLUSION_BUTTON_FEATURE // Inverses behavior of inclusion button (if using external pullup) //#define MY_INCLUSION_BUTTON_EXTERNAL_PULLUP // Set inclusion mode duration (in seconds) #define MY_INCLUSION_MODE_DURATION 60 // Digital pin used for inclusion mode button #define MY_INCLUSION_MODE_BUTTON_PIN 3 #include <SPI.h> #include <MySensors.h> #include <Bounce2.h> #include <DHT.h> // DHT11, DHT22 sensors // ------- PINS DEFINITION // RELAYS // Arduino Digital I/O pin number for first relay (second on pin+1 etc) // Relay for first floor - 10 pcs (Przelaczniki SSR - pierwsze pietro) #define RELAY_PIN_1 22 // Buttons for Relays - to use normal wall switches (Przyciski / laczniki scienne - pierwsze pietro) #define BUTTON_PIN A0 #define NUMBER_OF_RELAYS 10 // Total number of attached relays #define RELAY_ON 1 // GPIO value to write to turn on attached relay #define RELAY_OFF 0 // GPIO value to write to turn off attached relay // Arduino Digital I/O pin for button/reed switch // Reeds #define REED_PIN_1 5 // PIR SENSORS uint32_t SLEEP_TIME = 1000; // 120000; // Sleep time between reports (in milliseconds) #define DIGITAL_INPUT_SENSOR1 22 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!) #define DIGITAL_INPUT_SENSOR2 23 #define SLEEP_NODE true // DHT22 #define DHTPIN 4 // Broche sur laquelle est branché le DHT / what pin we're connected to #define DHTTYPE DHT22 // DHT 22 (AM2302), DHT11 #define DHTPIN2 24 // Broche sur laquelle est branché le DHT / what pin we're connected to #define DHTTYPE2 DHT22 // DHT 22 (AM2302), DHT11 #define DHTPIN3 25 // Broche sur laquelle est branché le DHT / what pin we're connected to #define DHTTYPE3 DHT22 // DHT 22 (AM2302), DHT11 // ------- Data for Motion sensor int oldValueA = 0; int oldValueB = 0; bool stateA = false; bool stateB = false; unsigned long timeDHT1 = 30000; // 30 seconds unsigned long timeDHT2 = 31000; // 30 seconds unsigned long timeDHT3 = 32000; // 30 seconds unsigned long actualTime = 0; unsigned long recentTimeHum1 = 0; unsigned long actualTime2 = 0; unsigned long recentTimeHum2 = 0; unsigned long actualTime3 = 0; unsigned long recentTimeHum3 = 0; // Initialize DHT sensor float lastTemp; float lastTemp2; float lastTemp3; float lastHum; float lastHum2; float lastHum3; boolean metric = true; // for reed switch int oldValue=-1; bool state = false; // Relay for save state inside Arduino's EEPROM bool loadedState1 = false; bool initialValueSent = false; // ------- CHILD IDs // REEDS #define CHILD_ID_REED1 0 // Id of the sensor child // Define CHILD_IDs #define CHILD_ID_TEMP1 1 // Id of the sensor child #define CHILD_ID_HUM1 2 // Id of the sensor child #define CHILD_ID_MOTION1 3 // Id of the sensor child #define CHILD_ID_MOTION2 4 // Id of the sensor child #define CHILD_ID_RELAY1 5 // Id of the sensor child #define CHILD_ID_TEMP2 6 // Id of the sensor child #define CHILD_ID_HUM2 7 // Id of the sensor child #define CHILD_ID_TEMP3 8 // Id of the sensor child #define CHILD_ID_HUM3 9 // Id of the sensor child // ------- void before() { for (int sensor=1, pin=RELAY_PIN_1; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) { // Then set relay pins in output mode pinMode(pin, OUTPUT); // Set relay to last known state (using eeprom storage) digitalWrite(pin, loadState(sensor)?RELAY_ON:RELAY_OFF); } } // Reed switches needs debouncers Bounce debouncer_reed1 = Bounce(); //Relays switched - don't need debouncers Bounce debouncer_relay1 = Bounce(); Bounce debouncer = Bounce(); // Debouncer for Motion sensor Bounce debouncerA = Bounce(); Bounce debouncerB = Bounce(); // Initialize Relay MyMessage msg(CHILD_ID_RELAY1, V_STATUS); // Initialize reed switches MyMessage msgReed1(CHILD_ID_REED1, V_TRIPPED); // Initialize DHT22 MyMessage msgTemp(CHILD_ID_TEMP1, V_TEMP); MyMessage msgHum(CHILD_ID_HUM1, V_HUM); MyMessage msgTemp2(CHILD_ID_TEMP2, V_TEMP); MyMessage msgHum2(CHILD_ID_HUM2, V_HUM); MyMessage msgTemp3(CHILD_ID_TEMP3, V_TEMP); MyMessage msgHum3(CHILD_ID_HUM3, V_HUM); // Initialize motion message MyMessage msg_motion1(CHILD_ID_MOTION1, V_TRIPPED); MyMessage msg_motion2(CHILD_ID_MOTION2, V_TRIPPED); void setup() { // Setup locally attached sensors delay(100); // Setup the button. pinMode(BUTTON_PIN, INPUT_PULLUP); // After setting up the button, setup debouncer. debouncer.attach(BUTTON_PIN); debouncer.interval(5); debouncer_relay1.attach(RELAY_PIN_1); debouncer_relay1.interval(5); // Setup the button pinMode(REED_PIN_1,INPUT_PULLUP); debouncer_reed1.attach(REED_PIN_1); debouncer_reed1.interval(10); // Make sure relays are off when starting up digitalWrite(RELAY_PIN_1, RELAY_OFF); // Then set relay pins in output mode pinMode(RELAY_PIN_1, OUTPUT); // Set relay to last known state (using eeprom storage) loadedState1 = loadState(CHILD_ID_RELAY1); // setup debouncer for Reed switch debouncer_reed1.attach(REED_PIN_1); debouncer_reed1.interval(5); pinMode(REED_PIN_1,INPUT); digitalWrite(REED_PIN_1,HIGH); // Setup PIR Motion sensor "button" pinMode(DIGITAL_INPUT_SENSOR1, INPUT_PULLUP); // Setup the button Activate internal pull-up pinMode(DIGITAL_INPUT_SENSOR2, INPUT_PULLUP); // sets the motion sensor digital pin as input / Setup the button Activate internal pull-up // setup debouncer for motion sensor debouncerA.attach(DIGITAL_INPUT_SENSOR1); debouncerA.interval(5); debouncerB.attach(DIGITAL_INPUT_SENSOR2); debouncerB.interval(5); } void presentation() { sendSketchInfo("Arduino5", "1.0"); // Register all sensors to gw (gateway - they will be created as child devices) present(CHILD_ID_RELAY1, S_BINARY); present(CHILD_ID_REED1, S_DOOR); present(CHILD_ID_TEMP1, S_TEMP); present(CHILD_ID_HUM1, S_HUM); present(CHILD_ID_TEMP2, S_TEMP); present(CHILD_ID_HUM2, S_HUM); present(CHILD_ID_TEMP3, S_TEMP); present(CHILD_ID_HUM3, S_HUM); present(CHILD_ID_MOTION1, S_MOTION); present(CHILD_ID_MOTION2, S_MOTION); } void loop() { actualTime = millis(); // --- DHT22 SENSOR1 if (actualTime - recentTimeHum1 >= timeDHT1) { recentTimeHum1 = actualTime; // DHT sensor DHT dht(DHTPIN, DHTTYPE); // Creation of a dht object in the loop otherwise the values are not measured on awakening float temperature = dht.readTemperature(); float humidity = dht.readHumidity(); if (isnan(temperature)) { //Serial.println("Cannot read DHT temperature"); } else { if (temperature != lastTemp) { lastTemp = temperature; if (!metric) { temperature = dht.readTemperature(true); } //Serial.print("T: "); //Serial.print(temperature); //Serial.print(" | H: "); //Serial.println(humidity); send(msgTemp.set(temperature, 1)); send(msgHum.set(humidity, 1)); } else { //Serial.println("Temperature doesn't change => don't update changes"); //Serial.print("T: "); //Serial.print(temperature); //Serial.print(" | H: "); //Serial.println(humidity); send(msgTemp.set(temperature, 1)); send(msgHum.set(humidity, 1)); } } } // --- DHT22 SENSOR END // --- DHT22 SENSOR2 if (actualTime2 - recentTimeHum2 >= timeDHT2) { recentTimeHum2 = actualTime2; // DHT2 sensor DHT dht2(DHTPIN2, DHTTYPE2); // Creation of a dht object in the loop otherwise the values are not measured on awakening float temperature2 = dht2.readTemperature(); float humidity2 = dht2.readHumidity(); if (isnan(temperature2)) { //Serial.println("Cannot read DHT temperature"); } else { if (temperature2 != lastTemp2) { lastTemp2 = temperature2; if (!metric) { temperature2 = dht2.readTemperature(true); } send(msgTemp2.set(temperature2, 1)); send(msgHum2.set(humidity2, 1)); } else { send(msgTemp2.set(temperature2, 1)); send(msgHum2.set(humidity2, 1)); } } } // --- DHT22 SENSOR END // --- DHT22 SENSOR2 if (actualTime3 - recentTimeHum3 >= timeDHT3) { recentTimeHum3 = actualTime3; // DHT3 sensor DHT dht3(DHTPIN3, DHTTYPE3); // Creation of a dht object in the loop otherwise the values are not measured on awakening float temperature3 = dht3.readTemperature(); float humidity3 = dht3.readHumidity(); if (isnan(temperature3)) { //Serial.println("Cannot read DHT temperature"); } else { if (temperature3 != lastTemp3) { lastTemp3 = temperature3; if (!metric) { temperature3 = dht3.readTemperature(true); } send(msgTemp3.set(temperature3, 1)); send(msgHum3.set(humidity3, 1)); } else { send(msgTemp3.set(temperature3, 1)); send(msgHum3.set(humidity3, 1)); } } } // --- DHT22 SENSOR END // ---- MOTION SENSOR START debouncerA.update(); // Get the update value int valueA = debouncerA.read(); if (valueA != oldValueA) { // Send in the new value send(msg_motion1.set(valueA == HIGH ? 1 : 0)); // Send tripped value to gw oldValueA = valueA; wait(5); } debouncerB.update(); // Get the update value int valueB = debouncerB.read(); if (valueB != oldValueB) { // Send in the new value send(msg_motion2.set(valueB == HIGH ? 1 : 0)); // Send tripped value to gw oldValueB = valueB; wait(5); } // --- MOTION SENSOR END if (!initialValueSent) { //Serial.println("Sending initial value"); send(msg.set(loadedState1?RELAY_ON:RELAY_OFF)); //Serial.println("Requesting initial value from controller"); // Reed Switch int value1 = debouncer_reed1.read(); send(msgReed1.set(value1==HIGH ? 1 : 0)); wait(5); request(CHILD_ID_RELAY1, V_STATUS); request(CHILD_ID_REED1, V_TRIPPED); wait(2000, C_SET, V_STATUS); } // Send locally attached sensor data here if (debouncer.update()) { // Get the update value. int value = debouncer.read(); // Send in the new value. if(value != oldValue){ saveState(CHILD_ID_RELAY1, !loadState(CHILD_ID_RELAY1)); digitalWrite(RELAY_PIN_1, loadState(CHILD_ID_RELAY1)?RELAY_ON:RELAY_OFF); send(msg.set(loadState(CHILD_ID_RELAY1))); oldValue = value; } } // Send locally attached sensor data here if (debouncer_reed1.update()) { // reed // Get the update value int value = debouncer_reed1.read(); if (value != oldValue) { // Send in the new value send(msgReed1.set(value==HIGH ? 1 : 0)); oldValue = value; } } } void receive(const MyMessage &message) { if (message.isAck()) { //Serial.println("This is an ack from gateway"); } if (message.type == V_STATUS) { if (!initialValueSent) { //Serial.println("Receiving initial value from controller"); initialValueSent = true; } switch (message.sensor) { case CHILD_ID_RELAY1: loadedState1 = message.getBool(); digitalWrite(RELAY_PIN_1, loadedState1 ? RELAY_ON : RELAY_OFF); saveState(CHILD_ID_RELAY1, loadedState1); send(msg.set(loadedState1?RELAY_ON:RELAY_OFF)); break; /* case CHILD_ID_RELAY2: loadedState2 = message.getBool(); digitalWrite(RELAY_PIN_2, loadedState2 ? RELAY_ON : RELAY_OFF); saveState(CHILD_RELAY2, loadedState2); send(msg2.set(loadedState2?RELAY_ON:RELAY_OFF)); break; */ } /* Remove debug - not needed in Home Assistant // Write some debug info Serial.print("Incoming change for sensor:"); Serial.print(message.sensor); Serial.print(", New status: "); Serial.println(message.getBool()); */ } }
