  3. Home Assistant
  4. USB gateway Arduino Mega: HA doesn't see switches and relays
10 Posts 2 Posters 2.0k Views 3 Watching
  • J
    J
    Jan Kocon
    wrote on last edited by Jan Kocon
    Hi, I'm struigling with connecting MySensors to my Home Assistant (server on unRaid - docker).
    here is my sketch (4 relays but I've another sketch for 24 which will be used when everything will be working):
    //#define MY_RADIO_NRF24
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    #define MY_BAUD_RATE 38400
    // Flash leds on rx/tx/err
    // #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // #define MY_WITH_LEDS_BLINKING_INVERSE
    // Enable inclusion mode
    #include <Bounce2.h>
    #define MY_REPEATER_FEATURE
    #define RELAY_1  14  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_2  15
    #define RELAY_3  16
    #define RELAY_4  17
    #define NUMBER_OF_RELAYS 4 // Total number of attached relays
    #define BUTTON_PIN 5
    #define BUTTON2_PIN 6
    #define BUTTON3_PIN 7
    #define BUTTON4_PIN 8
    void before() {
        pinMode(pin, OUTPUT);
    Bounce debouncer = Bounce();
    Bounce debouncer2 = Bounce();
    Bounce debouncer3 = Bounce();
    Bounce debouncer4 = Bounce();
      delay(10000);
       // Setup the button.
      pinMode(BUTTON_PIN, INPUT_PULLUP);
      pinMode(BUTTON2_PIN, INPUT_PULLUP);
      pinMode(BUTTON3_PIN, INPUT_PULLUP);
      pinMode(BUTTON4_PIN, INPUT_PULLUP);
      // After setting up the button, setup debouncer.
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      debouncer2.attach(BUTTON2_PIN);
      debouncer2.interval(5);
      debouncer3.attach(BUTTON3_PIN);
      debouncer3.interval(5);
      debouncer4.attach(BUTTON4_PIN);
      debouncer4.interval(5);
      //presentation();
        present(sensor, S_LIGHT);
    MyMessage msg(1, V_LIGHT);
    MyMessage msg2(2, V_LIGHT);
    MyMessage msg3(3, V_LIGHT);
    MyMessage msg4(4, V_LIGHT);
      if (debouncer.update()) {
        // Get the update value.
        int value = debouncer.read();
        // Send in the new value.
        if(value == LOW){
             saveState(1, !loadState(1));
             digitalWrite(RELAY_1, loadState(1)?RELAY_ON:RELAY_OFF);
             send(msg.set(loadState(1)));
      if (debouncer2.update()) {
          int value2 = debouncer2.read();
        if(value2 == LOW){
             saveState(2, !loadState(2));
             digitalWrite(RELAY_2, loadState(2)?RELAY_ON:RELAY_OFF);
             send(msg2.set(loadState(2)));
      if (debouncer3.update()) {
          int value3 = debouncer3.read();
        if(value3 == LOW){
             saveState(3, !loadState(3));
             digitalWrite(RELAY_3, loadState(3)?RELAY_ON:RELAY_OFF);
             send(msg3.set(loadState(3)));
      if (debouncer4.update()) {
          int value4 = debouncer4.read();
        if(value4 == LOW){
             saveState(4, !loadState(4));
             digitalWrite(RELAY_4, loadState(4)?RELAY_ON:RELAY_OFF);
             send(msg4.set(loadState(4)));
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    Home Assistant config:
    mysensors:
      gateways:
        - device: '/dev/ttyACM0'
          persistence_file: 'mysensors.json'
          baud_rate: 38400
          topic_in_prefix: 'mygateway1-out'
          topic_out_prefix: 'mygateway1-in'
      optimistic: false
      persistence: true
      retain: true
      version: '2.0'
    mysensors.json generated by Home Assistant:
    when I'm connecting arduino to HA I'm getting this:
    2019-08-26 18:33:09 INFO (MainThread) [mysensors] Connected to Serial<id=0x14800ea0cf90, open=True>(port='/dev/ttyACM0', baudrate=38400, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False)
    2019-08-26 18:33:10 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:Starting gateway (R-NGA-, 2.0.0)
    2019-08-26 18:33:10 INFO (MainThread) [mysensors.handler] n:0 c:255 t:3 s:14 p:Gateway startup complete.
    2019-08-26 18:33:10 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 0 child 255
    2019-08-26 18:33:15 DEBUG (SyncWorker_12) [mysensors.persistence] Saving sensors to persistence file /config/mysensors.json
    2019-08-26 18:33:20 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:No registration required
    2019-08-26 18:33:20 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:Init complete, id=0, parent=0, distance=0, registration=1
    any idea to make it work?
    petewillP 1 Reply Last reply
    • J Jan Kocon
      #define RELAY_2  15
      #define RELAY_3  16
      #define RELAY_4  17
      void before() {
        delay(10000);
        //presentation();
          if(value == LOW){
          if(value2 == LOW){
          if(value3 == LOW){
          if(value4 == LOW){
      mysensors:
        gateways:
            baud_rate: 38400
        optimistic: false
        persistence: true
        retain: true
        version: '2.0'
      petewillP
      petewillP
      petewill
      @jan-kocon I am just learning Home Assistant myself so I'm no expert. One thing it looks like your relay code is missing is to send an initial relay value in the loop function of your code when the node first starts (which is required by Home Assistant). Here is the link for more info: https://www.home-assistant.io/components/mysensors/#presentation
      • J
        J
        Jan Kocon
        @petewill I've uncommented "//presentation" part in the code
          //presentation();
        and I've got this in the log:
        2019-08-28 17:40:25 ERROR (MainThread) [mysensors.handler] Node 0 is unknown, will not add child 1
        2019-08-28 17:40:25 ERROR (MainThread) [mysensors.handler] Node 0 is unknown, will not add child 2
        2019-08-28 17:40:25 ERROR (MainThread) [mysensors.handler] Node 0 is unknown, will not add child 3
        2019-08-28 17:40:25 ERROR (MainThread) [mysensors.handler] Node 0 is unknown, will not add child 4
        Plus I've added those lines in void setup:
          digitalWrite(RELAY_1, RELAY_OFF);
          digitalWrite(RELAY_2, RELAY_OFF);
          digitalWrite(RELAY_3, RELAY_OFF);
          digitalWrite(RELAY_4, RELAY_OFF);
          pinMode(RELAY_1, OUTPUT);
          pinMode(RELAY_2, OUTPUT);
          pinMode(RELAY_3, OUTPUT);
          pinMode(RELAY_4, OUTPUT);
        I've defined node in the code
        #define MY_NODE_ID 1
        and updated HA config
        mysensors:
          gateways:
              baud_rate: 115200
              nodes:
                1:
          optimistic: true
          persistence: true
          retain: true
          version: '2.0'
        but unfortunatelly when I'm pressing any button on Arduino I'm getting this in log:
        2019-08-28 17:50:50 WARNING (MainThread) [mysensors] Node 0 is unknown
        2019-08-28 17:50:50 INFO (MainThread) [mysensors] Requesting new presentation for node 0
        And i have no idea what esle to do :(
        • petewillP
          petewillP
          petewill
          @Jan-Kocon I would recommend starting with the relay example sketch that is in the presentation section of this site: https://www.home-assistant.io/components/mysensors/#presentation
          Once you have that working you can start integrating your existing sketch in to that one.
          One thing I notice with your existing sketch is you have a sensor type of "S_LIGHT" which doesn't exist. You need S_BINARY (https://www.mysensors.org/download/serial_api_20).
          You also need to send the initial value in the loop function like this:
            if (!initialValueSent) {
              send(msg.set(state?RELAY_ON:RELAY_OFF));
              Serial.println("Requesting initial value from controller");
              request(CHILD_ID, V_STATUS);
              wait(2000, C_SET, V_STATUS);
          J 1 Reply Last reply
          • petewillP petewill
            J
            J
            Jan Kocon
            @petewill I've tried that config earlier but no luck.
            I've added some changes in my Arduino code, here is actual code:
            // Override Setting for Manual Node ID to 2
            #define MY_NODE_ID 2
            #define RELAY_2  15
            #define RELAY_3  16
            #define RELAY_4  17
            #define BUTTON1_PIN 5
            bool initialValueSent = false;
            MyMessage msg1(1, V_LIGHT);
            void before() {
            Bounce debouncer1 = Bounce();
              delay(10000);
              pinMode(BUTTON1_PIN, INPUT_PULLUP);
              debouncer1.attach(BUTTON1_PIN);
              debouncer1.interval(5);
                send(msg1.set(loadState(1)?RELAY_OFF:RELAY_ON),true);
                wait(1000);
                send(msg2.set(loadState(2)?RELAY_OFF:RELAY_ON),true);
                wait(1000);
                send(msg3.set(loadState(3)?RELAY_OFF:RELAY_ON),true);
                wait(1000);
                send(msg4.set(loadState(4)?RELAY_OFF:RELAY_ON),true);
                wait(1000);
                Serial.println("Sending initial value: Completed");
                wait(5000);
              if (debouncer1.update()) {
                int value = debouncer1.read();
                if(value == LOW){
                     send(msg1.set(loadState(1)));
                if(value2 == LOW){
                if(value3 == LOW){
                if(value4 == LOW){
            and finally I can see my relays in GUI:
            mysensor file:
                "0": {
                    "sensor_id": 0,
                    "children": {
                        "1": {
                            "id": 1,
                            "type": 3,
                            "description": "",
                            "values": {
                                "2": "1"
                        "2": {
                            "id": 2,
                            "type": 3,
                            "description": "",
                            "values": {
                                "2": "1"
                        "3": {
                            "id": 3,
                            "type": 3,
                            "description": "",
                            "values": {
                                "2": "1"
                        "4": {
                            "id": 4,
                            "type": 3,
                            "description": "",
                            "values": {
                                "2": "1"
                    "type": 17,
                    "sketch_name": "Relay",
                    "sketch_version": "1.0",
                    "battery_level": 0,
                    "protocol_version": "2.3.1",
                    "heartbeat": 0
            But it couldn't be to good...
            Home Assistant doesn't save changes in GUI so when I'm switch relay to off it will turn off the relay and it will stay off on device but after 2-3 seconds it's coming back on in GUI (on arduino it's still off). To trun it back on I have to turn on and turn off relay in GUI pretty fast before it will 'switch' back again.
            when I'm switching relay in GUI I'm getting this:
            2019-08-29 13:14:07 WARNING (MainThread) [mysensors.message] Error decoding message from gateway, bad data received: Incoming change for sensor:1, New status: 0
            2019-08-29 13:14:07 WARNING (MainThread) [mysensors] Not a valid message: not enough values to unpack (expected 5, got 0)
            and additionaly every few seconds I'm getting those lines in logs (even when it's iddle):
            2019-08-29 13:16:34 WARNING (MainThread) [mysensors.message] Error decoding message from gateway, bad data received: Sending initial value
            2019-08-29 13:16:34 WARNING (MainThread) [mysensors] Not a valid message: not enough values to unpack (expected 5, got 0)
            2019-08-29 13:16:34 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 0 child 1
            2019-08-29 13:16:34 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Relay 0 1: value_type 2, value = 1
            2019-08-29 13:16:35 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 0 child 2
            2019-08-29 13:16:35 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Relay 0 2: value_type 2, value = 1
            2019-08-29 13:16:36 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 0 child 3
            2019-08-29 13:16:36 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Relay 0 3: value_type 2, value = 1
            2019-08-29 13:16:37 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 0 child 4
            2019-08-29 13:16:37 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Relay 0 4: value_type 2, value = 1
            2019-08-29 13:16:37 DEBUG (SyncWorker_32) [mysensors.persistence] Saving sensors to persistence file /config/mysensors2.json
            2019-08-29 13:16:38 WARNING (MainThread) [mysensors.message] Error decoding message from gateway, bad data received: Sending initial value: Completed
            2019-08-29 13:16:38 WARNING (MainThread) [mysensors] Not a valid message: not enough values to unpack (expected 5, got 0)
            • J
              J
              Jan Kocon
              Well... another update:
              I've deleted this part from code:
                  wait(1000);
                  wait(1000);
                  wait(1000);
                  wait(1000);
                  wait(5000);
              and its working fine, I'm not getting update for intitial value and degub lines apears when I'm pressing buttons and they are working fine and I can see changes in HA.
              Still when I'm changing state on GUI it's coming back to previous state in GUI but it's holding new state on Arduino.
              Last problem with debug log:
              2019-08-29 15:43:56 WARNING (MainThread) [mysensors.message] Error decoding message from gateway, bad data received: Incoming change for sensor:3, New status: 1
              2019-08-29 15:43:56 WARNING (MainThread) [mysensors] Not a valid message: not enough values to unpack (expected 5, got 0)
              Any idea what to change in code?
              • petewillP
                petewillP
                petewill
                @Jan-Kocon I am experiencing the same thing with my devices (where the status doesn't stick but the relay stays on). I haven't had time to dig into it yet but I suspect this ultimately needs to be fixed in the Home Assistant integration. The example code on the Home Assistant site sends back the status after the relay has been updated. The MySensors RelayActuator sketch does not send back the status this way.
                It seems to me there are two workarounds for this.
                1. Set the "optimistic" setting in the home assistant configuration.yaml file to True
                2. Send the state back to Home Assistant after the relay has been changed. See these lines of code for in the example:
                    state = (bool)message.getInt();
                    send(msg.set(state?RELAY_ON:RELAY_OFF));```
                • petewillP
                  petewillP
                  petewill
                  @Jan-Kocon I found the issue. Home Assistant doesn't request an Ack response for some reason. Here is a comparison of my current home automation controller (Vera) and Home Assistant. The top line is Vera (requesting an Ack response) and the bottom line is Home Assistant.
                  https://www.mysensors.org/build/parser?log=19%3B0%3B1%3B1%3B2%3B1 19%3B0%3B1%3B0%3B2%3B0
                  • J
                    J
                    Jan Kocon
                    So, I've found sketch which is perfectly integrating with Home Assistant:
                    https://github.com/th0m4sek/mysensors/tree/master?fbclid=IwAR0Bn7kfJ_whDpGWfeB3RpyfU0FAofEm1E3KjPvn4enJnUtNuT7qWmHvb3Y
                    hope it works in the future projects!
                    • J Jan Kocon
                      petewillP
                      petewillP
                      petewill
                      @jan-kocon I actually submitted a fix for the echo/ack that is now in the most recent version of Home Assistant. So, as long as you are on the most current version the default sketches should work now.
