  3. OpenHAB
  4. Openhab multiple gateways
5 Posts 3 Posters 1.6k Views 3 Watching
  • N
    N
    niccodemi
    is it possible to configure multiple MySensors gateways (ie one serial and one ethernet) on single Openhab server?
    T 1 Reply Last reply
    • N niccodemi
      TimO
      @niccodemi Yes! There is no limitation.
      • N
        N
        niccodemi
        @TimO thanks, that's great. Do I have to change the bridge name (gateway) for the second bridge to something else? Can I use same node IDs on both gateways?
        Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/pts/2", sendDelay=200 ] {
        	humidity 		hum01 	[ nodeId=172, childId=0 ]
        	temperature		temp01 	[ nodeId=172, childId=1 ]
                light			light01 [ nodeId=105, childId=0  ]
                light			light02 [ nodeId=105, childId=1 ]
        Bridge mysensors:bridge-eth:gateway [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200 ] {
        • N niccodemi
          TimO
          @niccodemi yes, you need to use different names for different things in Openhab. Name it as you like.
          The node id is unique per gateway, so you may use the same node id on different gateways/networks.
          J 1 Reply Last reply
          • T TimO
            J
            J
            Jarosław Narbut
            @TimO said in Openhab multiple gateways:
            I have problem with 2 MQTT gateways, mysensors binding prasing only one mqtt topic. Also in new OH2.5 is problem selecting Mysensors Mqtt Gateway.
