  3. MQTT ethernet gateway Works great for 3+ hours then stops
24 Posts 6 Posters 15.4k Views
  • P Offline
    P Offline
    pit007
    wrote on last edited by pit007
    #21
    Have you try to init the ENC all ~2 hours or by detecting the connection lost ? (brute force style, but better as powerdown all with a relais)
    • G Offline
      G Offline
      GuyP
      Well it's very simple to detect if the network has gone away.
      In the processEthernetMessage() function, it checks
      if (client) {
      if there's a client connection then the network must be working. If not then either the network has stopped or nothing is connected. Well OpenHAB always maintains a connection.
      So I've just added the
      } else {
      part to say the connection has gone. I also setup a timeout by counting the micros() since boot. so it's not constantly firing the reboot.
      I then raise digital pin 3 which is linked to my 555 timer circuit, which causes the power cycle.
      unsigned long resetCounter = micros();
      int rebootAborted = 0;
      void processEthernetMessages() {
      	char inputString[MQTT_MAX_PACKET_SIZE] = "";
      	uint8_t inputSize = 0;
      	EthernetClient client = server.available();
      	if (client) {
                      resetCounter=micros();
                      if (rebootAborted) {
                        Serial.println("Rebooting Aborted");
                        rebootAborted = 0;
      		while (client.available()) {
      			char inChar = client.read();
      			inputString[inputSize] = inChar;
      			inputSize++;
      #ifdef TCPDUMP
      		Serial.print("<<");
      		char buf[4];
      		for (uint8_t a=0; a<inputSize; a++) { sprintf(buf,"%02X ", (uint8_t)inputString[a]); Serial.print(buf); } Serial.println("");
      		gw.processMQTTMessage(inputString, inputSize);
      	} else {
                if ((micros() - resetCounter) >= 100000000 && !client.connected() && !rebootAborted) {
                    rebootAborted = 1;
                    Serial.println("Rebooting");
                    pinMode(3,OUTPUT);
                    digitalWrite(3,HIGH);
                    delay(100);
                    digitalWrite(3,LOW);
      • P Offline
        P Offline
        pit007
        #23
        Yes - noooo :-) Right - you are able to detect the connection loss (good to know) but why do you not trigger the NE555, but to re-init the ENC28. Have you try if it response via SPI ?
        • G Offline
          G Offline
          GuyP
          It completely locks up.. I tried to talk with at the same point but it doesn't seem to listen to anything
