  3. MQTT ethernet gateway Works great for 3+ hours then stops
24 Posts 6 Posters 15.6k Views
  • GuyPG
    GuyPG
    GuyP
    I've built an ethernet gateway from scratch.. using the ENC28J60 Ethernet module and NRF24L01 Radio. I loaded the MQTT gateway into my ATMega268 and started it going...
    For the first few hours everything is working perfectly. I can see it receiving updates from the the sensors (Temperature for the moment), and sending it on to openHAB. I can see a TCP connection on the OpenHAB server and all will be well.
    After 3+ hours though the MQTT will still be receiving traffic from the sensor but will stop Ethernet communication and not send it onto OpenHAB. I suspect it's a overflow issue somewhere.. As soon as I reboot the MQTT gateway all is well again.
    I've seen a few people report issues similar to this and discussing a watchdog to reboot the MQTT if it fails. I'd rather not do this though, and better to find the underlaying issue. I also read that not all the ATMega support it.
    C 1 Reply Last reply
    • GuyPG GuyP
      C
      C
      C.r.a.z.y.
      @GuyP You are lucky my mqtt worked only 3 minutes :)
        marceloaqno
        Code Contributor
        There have been some updates to the MQTT gateway recently. Are you using the latest version of mysensors?
        • GuyPG
          GuyPG
          GuyP
          Yup I'm on the latest library 1.4 and the latest version of the MQTT gateway that's posted.
          I'm in the process of designing a PCB and 3D printed case for my temp sensors. But having to reboot the gateway 3 times a day or more is really putting a damper on the project.
            marceloaqno
            Code Contributor
            Do you still see the node messages being printed on the serial output of the gateway after the problem happens?
            GuyPG 1 Reply Last reply
            • M marceloaqno
              GuyPG
              GuyPG
              GuyP
              Yup... They continue to be received by the MQTT, so the issue appears to lie with the Ethernet part.
                marceloaqno
                Code Contributor
                @GuyP @C.r.a.z.y.
                What happens if you ping the gateway IP?
                What happens if you restart openhab?
                Do you see any error messages in the openhab console?
                Could you try to connect to the gateway using another MQTT client and see if it responds? Like paho-MQTT, MQTT-fx, mosquito_sub
                • M marceloaqno
                  @GuyP @C.r.a.z.y.
                  GuyPG
                  GuyPG
                  GuyP
                  @celonunes said:
                  @GuyP @C.r.a.z.y.
                  GP> the MQTT stops responding pings
                  GP> nothing! :( it doesn't reconnect to the MQTT, in fact I can't telnet to the MQTT on port 1883 when it stops responding. I just have to reboot the MQTT to get it back on track.
                  GP> No nothing
                  GP> I'll give it a go but as I'm not able to telnet to it I don't think that will fair any better
                  • GuyPG GuyP
                    @celonunes said:
                    @GuyP @C.r.a.z.y.
                    GP> No nothing
                    C
                    C
                    C.r.a.z.y.
                    @GuyP
                    You can find MQTT and serial logs in the zip files openhab 1.6.2 and 1.7.0 logs-1.7.0.zip logs-1.6.2.zip
                    • MagiskeM
                      MagiskeM
                      Magiske
                      Have had this problem. And I am pretty sure it's a power issue. Running 5v lines on a 3.3v. Works flawless when I pipe the ethernet lines through a 74LVC245 or when I replaced my "base station" with a Uno+Shield.
                      So try a level shifter or try running it with a 3.3v(3.7v) power supply to test ?(Remember to set the Arduino to 8Mhz so it's not overclocked)
                      /Mads
                      • MagiskeM Magiske
                        /Mads
                        GuyPG
                        GuyPG
                        GuyP
                        /Mads
                        Interesting... I am running the whole circuit at 3.3Volts from a regulator (LE33CZ-TR) and I have a capacitor across the power lines as well. But it's clocked at 16Mhz..
                        I don't have an 8Mhz crystal at hand to test with. I guess I could try the internal clock.
                        • MagiskeM
                          MagiskeM
                          Magiske
                          Just rechecking the specs, and the ENC28J60 should be 5v tolerant ? I ran my at 8mhz using the internal clock.
                          So if it was the levelshift or 8mhz that "fixed" mine is a good question.
                          Have to add that the Uno+Shield I am using now for the gateway is a W5100 simply because I ordered the W5100 shield when I started having the issues.
                          (And this have also been running flawless from day one!)
                          • GuyPG
                            GuyPG
                            GuyP
                            I setup a continuous ping every 60 seconds to the MQTT gateway and when it stops working the pings stop as well. I also see that the "Green and Yellow" LEDS on the ENC28J60 are no longer lit.
                            • MagiskeM
                              MagiskeM
                              Magiske
                              Sounds like the same issue I had.. Some time it would run for a day other times it would stop responding after an hour or so.
                              After reboot it was back right away. So it looks like the ENC28J60 chip is crashing.
                              For me fideling with it and droppinglines to 3.3v running at 8mhz worked(And working was having it up and running for at least 3-4 days compared to "normal"). But I remember seeing others having ENC28J60 issues to ?? Maybe you should check to see if you are running latest ENC28J60 Lib ??
                              • GuyPG
                                GuyPG
                                GuyP
                                I've been doing a great deal of research on this and I think I might have found the issue.
                                It seems that the radio is very sensitive to power changes... In my original circuit I had the Arduino and the radio running from the 3.3v line. Since I moved it to the 5Volts line the Gateway has stayed up for over a day now.
                                So to sum up. Everything is now powered by 5Volts except the radio which is 3.3v from the LE33CZ-TR regulator. I have it powered direct from a USB power adapter as well rather than the Uno I did have.
                                Once I have etched and tested I will post the circuit and PCB layout.
                                • GuyPG
                                  GuyPG
                                  GuyP
                                  So to follow up.. yes indeed it seems that the power was my issue.
                                  the connector just above the Radio is the 5Volts and ground. The Single connection on the other side is serial TX so I can see the serial diagnostics.
                                  • A
                                    A
                                    AlinClaudiu
                                    @Magiske said:
                                    ENC28J60
                                    you connected ENC28J60 to 5v?
                                    http://www.alban.ro/category/arduino
                                    • A AlinClaudiu
                                      @Magiske said:
                                      ENC28J60
                                      GuyPG
                                      GuyPG
                                      GuyP
                                      @AlinClaudiu said:
                                      @Magiske said:
                                      ENC28J60
                                      Yes, the ENC28J60 and the Arduino are running on 5V. The only thing connected to the 3.3Volt regulator is the Radio, NRF24L01+
                                      • GuyPG
                                        GuyPG
                                        GuyP
                                        And now in it's 3D Printed case..
                                        • GuyPG
                                          GuyPG
                                          GuyP
                                          I was still seeing it stop working. However after further diagnostics it seems the issue lies with the ethernet side of things, the Arduino and Radio still continue to function.
                                          I tried to use the Arduino to reboot it's self, which didn't work, but also would not have rebooted the ethernet modules and thus would not have solved this.
                                          I've ended up building a 555 timer circuit which is triggered from the Arduino (Digital pin 3), the time fires and triggers a relay to remove power from everything for 2 seconds. Thus we end up with a complete reboot.
                                          Here's my circuit diagram, take 5Volts directly and then PWR is fed into my previous circuit that way when the relay clicks over all power to the Arduino and ethernet is removed.
