Solar Energy Harvesting for wireless motes
Looks as though the EM8500 solar energy harvester can still function even if fed a current of just 1ua, for a total of 1uw power, and perhaps even less: https://www.emmicroelectronic.com/sites/default/files/products/datasheets/8500-ds.pdf
If I'm not mistaken, that's lower power than any other chip! And if it's price really is $2.30 for quantity 1, then that would make it one of the least expensive energy harvester chips as well.
Unfortunately, neither digikey nor mouser carry it.
Intended for TEGs instead of photovoltaic, the EM8900 is nonetheless impressive. According to its datasheet, it can both cold start and operate with an input voltage as low as 5mv. That's far and away better than the LTC3108, which before now I had thought was the world leader with its 20mv minimum operating voltage. https://www.emmicroelectronic.com/sites/default/files/products/datasheets/8900-ds.pdf
@NeverDie can't you order from https://www.cdiweb.com/products/detail/em8500a001lf24b-em-microelectronic/594464/ ?
@mfalkvidd Yup. It was when looking there for the EM-8500 that I first noticed the EM-8900 (just 79 cents, quantity one!).
cough cough , so much dust here in the archives... ;)
@NeverDie SPV1050 is what you are looking for, only Maximum Power Point Tracking IC from all IC's you mentioned/tested in both your topics. And trust me, it makes a whole world of a difference. ST even have online component calculator for matching it to solar panel and battery used. My usage scenario was outdoor rechargeable coin cell battery and calculator solar cell. Only drawback: you have to determine maximum power point of your solar cell.
@Sasquatch Cool! How did you wire yours up? Did you use an eval board of some kind, or did you do something custom? I actually have one of these:
https://media.digikey.com/pdf/Data Sheets/DFRobot PDFs/DFR0579_Web.pdf
but I hadn't gotten around to testing it. So, thanks for the feedback! Now I have a reason to try it sooner rather than later.Looks as though the setting of the "MPPT" may be similar to how the LTC3105 does it:
https://www.openhardware.io/view/281/Solar-Energy-Harvester
It's not really MPPT, though, so Linear Technology calls it MPPC instead. -
