  3. Home Assistant
  4. Dimmer led turns on fully and only after dimms
9 Posts 4 Posters 1.4k Views 3 Watching
  • Adam NovakA
    Adam NovakA
    Adam Novak
    I’d like to turn on my mysensor driver led strips on a certain brightness.
    When I do that the led strips turns on on 100% brightness then immediately dimmed down to the wanted level. Is this intentional? Or am I doing something wrong?
    Full sketch for the arduino:
    #define MY_NODE_ID 141
    #define CHILD_ID 123
    #define CHILD_ID2 124
    #define SN "KitchenCabinet2"
    #define SV "1.5"
    #define LED_PIN 3      // Arduino pin attached to MOSFET Gate pin
    #define LED_PIN2 5      // Arduino pin attached to MOSFET Gate pin
    #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
    static int16_t currentLevel = 0;  // Current dim level...
    static int16_t currentLevel2 = 0;  // Current dim level...
    MyMessage dimmerMsg(CHILD_ID, V_DIMMER);
    MyMessage lightMsg(CHILD_ID, V_LIGHT);
    MyMessage dimmerMsg2(CHILD_ID2, V_DIMMER);
    MyMessage lightMsg2(CHILD_ID2, V_LIGHT);
       Dimmable LED initialization method
      sendSketchInfo(SN, SV);
      present(CHILD_ID, S_DIMMER);
      present(CHILD_ID2, S_DIMMER);
      static bool first_message_sent = false;
      if ( first_message_sent == false ) {
        analogWrite( LED_PIN, 0);
        analogWrite( LED_PIN2, 0);
        Serial.println( "Sending initial state..." );
        send(lightMsg.set(currentLevel));
        send(dimmerMsg.set(currentLevel));
        send(lightMsg2.set(currentLevel2));
        send(dimmerMsg2.set(currentLevel2));
        first_message_sent = true;
      if (message.type == V_LIGHT || message.type == V_DIMMER) {
        if (message.sensor == CHILD_ID) {
          requestedLevel *= ( message.type == V_LIGHT ? 100 : 1 );
          // Clip incoming level to valid range of 0 to 100
          Serial.print( "led1 Changing level to " );
          Serial.print( ", from " );
          Serial.println( currentLevel );
          fadeToLevel( requestedLevel );
          send(lightMsg.set(currentLevel > 0));
          // hek comment: Is this really nessesary?
          send( dimmerMsg.set(currentLevel) );
        if (message.sensor == CHILD_ID2) {
          Serial.print( "Led2 Changing level to " );
          Serial.println( currentLevel2 );
          fadeToLevel2( requestedLevel );
          send(lightMsg2.set(currentLevel2 > 0));
          send( dimmerMsg2.set(currentLevel2) );
        This method provides a graceful fade up/down effect
    void fadeToLevel(int toLevel ) {
      int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
      while ( currentLevel != toLevel ) {
        currentLevel += delta;
        analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
        delay( FADE_DELAY );
    void fadeToLevel2(int toLevel ) {
      int delta = ( toLevel - currentLevel2 ) < 0 ? -1 : 1;
      while (currentLevel2 != toLevel ) {
        currentLevel2 += delta;
        analogWrite(LED_PIN2, (int)(currentLevel2 / 100. * 255) );
        delay(FADE_DELAY );
    • Adam NovakA Adam Novak
      #define SV "1.5"
          delay(FADE_DELAY );
      @adam-novak do you mean when the node boots initially, or when it receives a change in level?
      What message are you sending?
      What does the debug output show?
      • Adam NovakA
        Adam NovakA
        Adam Novak
        wrote on last edited by Adam Novak
        nope, not when the node boots.
        so steps:
        have the lights turned off.
        turn the lights on with brightness lower than 100 percentage.
        results:
        1. leds turned on with brightness 100 percentage.
        2. immediately after that leds are dimmed to the given level.
        I'm using home assistant so not really sure what do you mean by what message am I sending.
        • electrikE
          electrikE
          electrik
          @adam-novak said in Dimmer led turns on fully and only after dimms:
          I would rewrite this to
          analogWrite(LED_PIN2, (int)(currentLevel2 * 255L / 100) );
          • fritsF
            fritsF
            frits
            You could add some debug code to see what messages arrive from home assistant, like
              Serial.print ( "received message for sensor " );
              Serial.print ( message.sensor );
              Serial.print ( ", type " );
              Serial.println ( message.type );
            and this to see if the fading routine works well:
                Serial.print ( "...fadeToLevel: currentLevel=" );
                Serial.print ( currentLevel );
                Serial.print ( ", pwm value=" );
                Serial.print (  (int)(currentLevel / 100. * 255) );
                Serial.println ( );
            post your debug output
            • Adam NovakA
              Adam NovakA
              Adam Novak
              This is the output:
              69082 TSF:MSG:READ,0-0-150,s=151,c=1,t=2,pt=0,l=1,sg=0:1
              69087 TSF:MSG:ACK REQ
              69091 TSF:MSG:SEND,150-150-0-0,s=151,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:1
              received message for sensor 151, type 2
              led1 Changing level to 100, from 0
              70106 TSF:MSG:SEND,150-150-0-0,s=151,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:1
              70114 TSF:MSG:SEND,150-150-0-0,s=151,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:100
              70121 TSF:MSG:READ,0-0-150,s=151,c=1,t=3,pt=0,l=2,sg=0:16
              70126 TSF:MSG:ACK REQ
              70130 TSF:MSG:SEND,150-150-0-0,s=151,c=1,t=3,pt=0,l=2,sg=0,ft=0,st=OK:16
              received message for sensor 151, type 3
              led1 Changing level to 16, from 100
              70984 TSF:MSG:SEND,150-150-0-0,s=151,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:1
              70993 TSF:MSG:SEND,150-150-0-0,s=151,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=OK:16
              fading seems fine, that part is not posted from the logs
              • Adam NovakA
                Adam NovakA
                Adam Novak
                it seems to me that HA sends to messages. first to turn on 100% than dim to the desired level. ?
                • electrikE
                  electrikE
                  electrik
                  Yes that seems correct to me. So you could not check for over if the message types, or check why home assistant sends the message twice.
                  Probably it sends one for the dimmer value and I've for the switch. So if you only check on the dimmer it should be okay
                  Adam NovakA 1 Reply Last reply
                  • electrikE electrik
                    Adam NovakA
                    Adam NovakA
                    Adam Novak
                    @electrik checked HA source as well, and you are absolutely right.
                    I'll just check for the dim message, thanks for the help.
