  2. Announcements
  3. MySensors 2.3.2 released
28 Posts 14 Posters 16.9k Views 13 Watching
  • EmeE Eme
    @Eme cleared eeprom with the sketch and loaded the Gateway Serial. I now have an error for an #include <nrf.h> I've updated boards and libraries but still can't get past the error
    "NRFS Radio is not supported for this platform. " does this mean my Serial GW can't be upgraded since l use NRF24 radios? What am l fling wrong? All my nodes are down. Please help.
    skywatchS
    skywatchS
    skywatch
    @Eme Best to post the gateway sketch you are using. I guess it is the one from 2.3.2 library and not the old one from 2.0.0. Things changed.
    Also I would recommend to clear eeprom on all nodes and then reload the code modified where necessary for the new version if needed.
    It is best to have everything using the same version/protocol.
    EmeE 2 Replies Last reply
    • skywatchS skywatch
      EmeE
      EmeE
      Eme
      thanks @skywatch l took your advice cleared eeprom on only one node, and cloned my SD card before building a Rasberry Gateway/Controller since I was experiencing too much stress with the Nano-RPi gateway.
      My Config was like:-
      ./configure --my-transport=rf24 --my-rf24-irq-pin=15 --my-gateway=serial --my-serial-is-pty --my-serial-port=/dev/ttyUSB020 --my-controller-ip-address=172.0.0.1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
      I changed the Hardware on Domotics to point to the new virtual ttyUSB020 port that appeared on Domotics. but still no connection.
      Rasberry Pi Gateway/Conmtroller Tail Log is asfollows
      /home/pi/MySensors$ tail -f /var/log/syslog
      Aug 18 22:25:53 IoTGateway mysgw: TSF:CKU:OK,FCTRL
      Aug 18 22:25:53 IoTGateway mysgw: TSF:MSG:GWL OK
      Aug 18 22:25:54 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      Aug 18 22:25:55 IoTGateway systemd[1]: Started Session c4 of user pi.
      Aug 18 22:25:55 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      Aug 18 22:25:55 IoTGateway mysgw: TSF:MSG:BC
      Aug 18 22:25:55 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
      Aug 18 22:25:55 IoTGateway mysgw: TSF:CKU:OK,FCTRL
      Aug 18 22:25:55 IoTGateway mysgw: TSF:MSG:GWL OK
      Aug 18 22:25:56 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      Aug 18 22:26:07 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      Aug 18 22:26:07 IoTGateway mysgw: TSF:MSG:BC
      Aug 18 22:26:07 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
      Aug 18 22:26:07 IoTGateway mysgw: TSF:PNG:SEND,TO=0
      Aug 18 22:26:07 IoTGateway mysgw: TSF:CKU:OK
      Aug 18 22:26:07 IoTGateway mysgw: TSF:MSG:GWL OK
      Aug 18 22:26:08 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      Aug 18 22:26:09 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      Aug 18 22:26:09 IoTGateway mysgw: TSF:MSG:BC
      Aug 18 22:26:09 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
      Aug 18 22:26:09 IoTGateway mysgw: TSF:CKU:OK,FCTRL
      Aug 18 22:26:09 IoTGateway mysgw: TSF:MSG:GWL OK
      Aug 18 22:26:10 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      Aug 18 22:26:12 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      Aug 18 22:26:12 IoTGateway mysgw: TSF:MSG:BC
      Aug 18 22:26:12 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
      Aug 18 22:26:12 IoTGateway mysgw: TSF:CKU:OK,FCTRL
      Aug 18 22:26:12 IoTGateway mysgw: TSF:MSG:GWL OK
      Aug 18 22:26:12 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      Aug 18 22:26:14 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      Aug 18 22:26:14 IoTGateway mysgw: TSF:MSG:BC
      Aug 18 22:26:14 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
      Aug 18 22:26:14 IoTGateway mysgw: TSF:CKU:OK,FCTRL
      Aug 18 22:26:14 IoTGateway mysgw: TSF:MSG:GWL OK
      Aug 18 22:26:15 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      Aug 18 22:26:26 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      Aug 18 22:26:26 IoTGateway mysgw: TSF:MSG:BC
      Aug 18 22:26:26 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
      Aug 18 22:26:26 IoTGateway mysgw: TSF:PNG:SEND,TO=0
      Aug 18 22:26:26 IoTGateway mysgw: TSF:CKU:OK
      Aug 18 22:26:26 IoTGateway mysgw: TSF:MSG:GWL OK
      Aug 18 22:26:26 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      Aug 18 22:26:28 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      Aug 18 22:26:28 IoTGateway mysgw: TSF:MSG:BC
      Aug 18 22:26:28 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
      Aug 18 22:26:28 IoTGateway mysgw: TSF:CKU:OK,FCTRL
      Aug 18 22:26:28 IoTGateway mysgw: TSF:MSG:GWL OK
      Aug 18 22:26:28 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      Aug 18 22:26:30 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      Aug 18 22:26:30 IoTGateway mysgw: TSF:MSG:BC
      Aug 18 22:26:30 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
      Aug 18 22:26:30 IoTGateway mysgw: TSF:CKU:OK,FCTRL
      Aug 18 22:26:30 IoTGateway mysgw: TSF:MSG:GWL OK
      Aug 18 22:26:30 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      Aug 18 22:26:32 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      Aug 18 22:26:32 IoTGateway mysgw: TSF:MSG:BC
      Aug 18 22:26:32 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
      Aug 18 22:26:32 IoTGateway mysgw: TSF:CKU:OK,FCTRL
      Aug 18 22:26:32 IoTGateway mysgw: TSF:MSG:GWL OK
      Aug 18 22:26:32 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      Aug 18 22:26:39 IoTGateway mysgw: TSF:MSG:READ,5-5-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      Aug 18 22:26:39 IoTGateway mysgw: TSF:MSG:BC
      Aug 18 22:26:39 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=5
      Aug 18 22:26:39 IoTGateway mysgw: TSF:CKU:OK,FCTRL
      Aug 18 22:26:39 IoTGateway mysgw: TSF:MSG:GWL OK
      Aug 18 22:26:39 IoTGateway mysgw: !TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      Aug 18 22:26:41 IoTGateway mysgw: TSF:MSG:READ,5-5-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      Aug 18 22:26:41 IoTGateway mysgw: TSF:MSG:BC
      Aug 18 22:26:41 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=5
      Aug 18 22:26:41 IoTGateway mysgw: TSF:CKU:OK,FCTRL
      Aug 18 22:26:41 IoTGateway mysgw: TSF:MSG:GWL OK
      Aug 18 22:26:41 IoTGateway mysgw: !TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      Aug 18 22:26:43 IoTGateway mysgw: TSF:MSG:READ,5-5-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      Aug 18 22:26:43 IoTGateway mysgw: TSF:MSG:BC
      Aug 18 22:26:43 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=5
      Aug 18 22:26:43 IoTGateway mysgw: TSF:CKU:OK,FCTRL
      Aug 18 22:26:43 IoTGateway mysgw: TSF:MSG:GWL OK
      Aug 18 22:26:43 IoTGateway mysgw: !TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      Aug 18 22:26:44 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      Aug 18 22:26:44 IoTGateway mysgw: TSF:MSG:BC
      Aug 18 22:26:44 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
      Aug 18 22:26:44 IoTGateway mysgw: TSF:CKU:OK,FCTRL
      Aug 18 22:26:44 IoTGateway mysgw: TSF:MSG:GWL OK
      Aug 18 22:26:44 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      Aug 18 22:26:45 IoTGateway mysgw: TSF:MSG:READ,5-5-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      Aug 18 22:26:45 IoTGateway mysgw: TSF:MSG:BC
      Aug 18 22:26:45 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=5
      Aug 18 22:26:45 IoTGateway mysgw: TSF:CKU:OK,FCTRL
      Aug 18 22:26:45 IoTGateway mysgw: TSF:MSG:GWL OK
      Aug 18 22:26:45 IoTGateway mysgw: !TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      Aug 18 22:26:46 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      Aug 18 22:26:46 IoTGateway mysgw: TSF:MSG:BC
      Aug 18 22:26:46 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
      Aug 18 22:26:46 IoTGateway mysgw: TSF:CKU:OK,FCTRL
      Aug 18 22:26:46 IoTGateway mysgw: TSF:MSG:GWL OK
      Aug 18 22:26:46 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      Aug 18 22:26:48 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      Aug 18 22:26:48 IoTGateway mysgw: TSF:MSG:BC
      Aug 18 22:26:48 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
      Aug 18 22:26:48 IoTGateway mysgw: TSF:CKU:OK,FCTRL
      Aug 18 22:26:48 IoTGateway mysgw: TSF:MSG:GWL OK
      Aug 18 22:26:48 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      Aug 18 22:26:50 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      Aug 18 22:26:50 IoTGateway mysgw: TSF:MSG:BC
      Aug 18 22:26:50 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
      Aug 18 22:26:50 IoTGateway mysgw: TSF:CKU:OK,FCTRL
      Aug 18 22:26:50 IoTGateway mysgw: TSF:MSG:GWL OK
      Aug 18 22:26:50 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      My Domoticz Log :-
      2020-08-18 22:21:53.545 Sunrise: 06:22:00 SunSet: 18:47:00
      2020-08-18 22:21:53.545 Day length: 12:25:00 Sun at south: 12:34:00
      2020-08-18 22:21:53.545 Civil twilight start: 06:00:00 Civil twilight end: 19:08:00
      2020-08-18 22:21:53.545 Nautical twilight start: 05:35:00 Nautical twilight end: 19:34:00
      2020-08-18 22:21:53.545 Astronomical twilight start: 05:09:00 Astronomical twilight end: 19:59:00
      2020-08-18 22:21:53.864 Active notification Subsystems: kodi (1/13)
      2020-08-18 22:21:53.969 Starting shared server on: :::6144
      2020-08-18 22:21:53.410 Status: Domoticz V2020.1 (c)2012-2020 GizMoCuz
      2020-08-18 22:21:53.412 Status: Build Hash: 63fa969e4, Date: 2020-03-22 15:16:16
      2020-08-18 22:21:53.413 Status: Startup Path: /home/pi/domoticz/
      2020-08-18 22:21:53.842 Status: PluginSystem: Started, Python version '3.7.3'.
      2020-08-18 22:21:53.896 Status: WebServer(HTTP) started on address: :: with port 8080
      2020-08-18 22:21:53.912 Status: WebServer(SSL) started on address: :: with port 443
      2020-08-18 22:21:53.915 Status: Camera: settings (re)loaded
      2020-08-18 22:21:53.969 Status: TCPServer: shared server started...
      2020-08-18 22:21:53.970 Status: RxQueue: queue worker started...
      2020-08-18 22:21:55.978 Status: MySensors: Worker started...
      2020-08-18 22:21:55.979 Status: Hardware Monitor: Started
      2020-08-18 22:21:56.979 MySensors: Gateway Ready...
      2020-08-18 22:21:56.004 Status: NotificationSystem: thread started...
      2020-08-18 22:21:56.005 Status: EventSystem: reset all events...
      2020-08-18 22:21:56.010 Status: EventSystem: reset all device statuses...
      2020-08-18 22:21:56.051 Status: PluginSystem: Entering work loop.
      2020-08-18 22:21:56.159 Status: Python EventSystem: Initalizing event module.
      2020-08-18 22:21:56.160 Status: EventSystem: Started
      2020-08-18 22:21:56.160 Status: EventSystem: Queue thread started...
      2020-08-18 22:21:56.979 Status: MySensors: Using serial port: /dev/ttyUSB020
      2020-08-18 22:21:57.055 MySensors: Gateway Version: 2.3.2
      2020-08-18 22:21:57.004 Status: MQTT: Connecting to 192.168.8.100:1883
      2020-08-18 22:21:57.004 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
      2020-08-18 22:22:49.016 Status: MQTT: Connecting to 192.168.8.100:1883
      2020-08-18 22:22:49.218 Status: MQTT: connected to: 192.168.8.100:1883
      2020-08-18 22:22:49.419 Status: MQTT: Subscribed
      2020-08-18 22:24:00.705 Status: New sensors allowed for 5 minutes...
      MySensor Node Serial Printout:
      16 MCO:BGN:INIT REPEATER,CP=RNNRA---,FQ=16,REL=255,VER=2.3.2
      27 TSM:INIT
      28 TSF:WUR:MS=0
      34 TSM:INIT:TSP OK
      36 TSM:INIT:STATID=5
      38 TSF:SID:OK,ID=5
      40 TSM:FPAR
      45 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      2052 !TSM:FPAR:NO REPLY
      2054 TSM:FPAR
      2058 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      4065 !TSM:FPAR:NO REPLY
      4067 TSM:FPAR
      4071 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      6078 !TSM:FPAR:NO REPLY
      6080 TSM:FPAR
      6084 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      8091 !TSM:FPAR:FAIL
      8092 TSM:FAIL:CNT=1
      8094 TSM:FAIL:DIS
      8096 TSF:TDI:TSL
      18098 TSM:FAIL:RE-INIT
      18100 TSM:INIT
      18106 TSM:INIT:TSP OK
      18108 TSM:INIT:STATID=5
      18111 TSF:SID:OK,ID=5
      18113 TSM:FPAR
      18117 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      20124 !TSM:FPAR:NO REPLY
      20126 TSM:FPAR
      20130 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      22138 !TSM:FPAR:NO REPLY
      22140 TSM:FPAR
      22145 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      24153 !TSM:FPAR:NO REPLY
      24155 TSM:FPAR
      24159 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      26167 !TSM:FPAR:FAIL
      26168 TSM:FAIL:CNT=2
      26170 TSM:FAIL:DIS
      26172 TSF:TDI:TSL
      Still no luck. The node still wont present to the new gateway.
      What am I doing wrong? All my devices are still down - 4 days on.
        EmeE
        EmeE
        Eme
        @skywatch Sorry I didn't respond to this question. I didnt change the sketch. I only updated the library and uploaded to the node with the new Library. DO I have to change the sketch altogether? My sketch is as follows...
        // Example sketch showing how to control physical relays.
        // This example will remember relay state even after power failure.
        // Enable debug prints
        #define SLEEP_TIME 10000    //10 seconds
        #define MY_RF24_PA_LEVEL RF24_PA_HIGH // Options MAX to reach the furthest
        #define MY_NODE_ID 5  // Set this to fix your Radio ID or use AUTO or 1
        #define MY_REPEATER_FEATURE
        #define MY_REGISTRATION_FEATURE // Forece registration
        #define MY_REGISTRATION_RETRIES 5
        #include <Wire.h>
        #include <TimeLib.h>
        // For Debug
        #ifdef DEBUG_ON
        #define DEBUG_PRINT(x)   Serial.print(x)
        #else
        #define SERIAL_START(x)
        //#define SLEEP_TIME = 18000000  // Wait every 30 minutes
        #define RELAY_PIN 2  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
        #define NUMBER_OF_RELAYS 5 // Total number of attached relays
        #define SKETCH_NAME "Water Tank Node"
        #define SKETCH_VERSION "0.3.2"
        #define CHILD_ID 0
        MyMessage msg(1,V_LIGHT);
          for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
            // Then set relay pins to output mode
            pinMode(pin, OUTPUT);
            DEBUG_PRINT(F("Initialised Relay: "));
            DEBUG_PRINT(F(sensor));
            DEBUG_PRINT(F(" at pin "));
            DEBUG_PRINT(F(pin));
            DEBUG_PRINT(F(" ("));
            DEBUG_PRINT(F(loadState(pin)));
            DEBUG_PRINTLN(F(")"));
            pinMode(A0, INPUT); // Then set etra sensor pins to input mode
            DEBUG_PRINTLN(F("Initialised additional Sensor: "));
        void presentation() {
        // Fetch relay status
            present(sensor, S_BINARY);
            pinMode(pin, OUTPUT); // Then set relay pins in output mode
            boolean savedState = loadState(pin); // Set relay to last known state (using eeprom storage)
            digitalWrite(pin, savedState?RELAY_ON:RELAY_OFF);
            DEBUG_PRINT(F("Presented Relay at : "));
            DEBUG_PRINTLN(F(pin));
            send(msg.set(savedState? 0 : 1));
              DEBUG_PRINTLN(F("Sensor Presentation Complete"));
        //  sleep(digitalPinToInterrupt(RELAY_PIN), CHANGE, SLEEP_TIME);
        void receive(const MyMessage &message){
        // Change relay state if message is receieved
        //if (digitalRead(A0) == HIGH){
        //  // Sensor says tank is full do something
        //  DEBUG_PRINTLN(F("Float Sensor High, 'Tank is Full'"));
        //  digitalWrite(3, LOW);  // Switch off tank pump
        //  saveState(message.sensor, message.getBool());
        //  bool send(MyMessage &msg, bool ack);
          if (message.type == V_STATUS){
        //   digitalWrite(message.sensor, !digitalRead(message.sensor));
             if (message.getBool() == 0) {
             digitalWrite(message.sensor, LOW);
             // Store state in eeprom
             else //getBool() == 1
             digitalWrite(message.sensor, HIGH);
        // digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
        // Write some debug info
           Serial.print("Incoming change for sensor ID: ");
           Serial.print(message.sensor);
        • tekkaT tekka
          Yet another early holiday gift, MySensors 2.3.2 has finally been released!
          Highlights
          • Add support for RPI4
          • Transport and crypto HAL update
          • Rename "soft ack" to echo
          • Add log parser
          • RF24 improvements
          ...and many other bug fixes and tweaks
          Release notes and changelog: https://github.com/mysensors/MySensors/releases/tag/2.3.2
          Important information:
          If you encounter compilation issues, update your board definitions:
          • AVR 1.8.2
          • ESP8266 2.6.2
          • ESP32 1.0.4
          • SAMD 1.8.4
          • nRF5 0.6.0 (Sandeep Mistry)
          • STM32F1 2019.12.8 (stm32duino)
          Special thanks to the following people who have contributed code to this release:
          • Alfredo
          • desander
          • hannesweisbach
          • ltigges
          • Mikael Falkvidd
          • Patrick Fallberg
          • pragtich
          • Rik Jansen
          • tekka
          • Yveaux
          ...and a little teaser: 2.4 will come with a set of new features some of you have been waiting for... stay tuned :)
          J
          J
          Jstoaks
          @tekka
          It seems that this project has stalled out almost completely. There hasnt been any updates of any significant value that I can see. we have seen the Home automation platforms produce numerous updates in the past two years. Has MySensors given up with this project or will there be any milestones produced???
          skywatchS N 2 Replies Last reply
          • J Jstoaks
            @tekka
            skywatchS
            skywatchS
            skywatch
            This post is deleted!
            • J Jstoaks
              @tekka
              N
              N
              NielBierman
              @Jstoaks
              That would be terrible. This is such a nice project.
              Fumée BleueF 1 Reply Last reply
              • N NielBierman
                @Jstoaks
                Fumée BleueF
                Fumée BleueF
                Fumée Bleue
                No news .. ? MySensors is dead ? :(
                • J
                  J
                  JeeLet
                  what would you like as a novelty ???
                  " MySensors is dead ?" ... No, in my house it is still alive.
                  but it's true you are right to ask the question.
                  the programmers, the creators are always The ????? :)
                  what!? bought by the competition so that MySensors does not evolve any more? it makes damage to the commercial product :)
