  2. Announcements
  3. MySensors 2.3.2 released
28 Posts 14 Posters 17.4k Views 13 Watching
  • EmeE Eme
    Upgraded MS library and my my serial gateway sketch from 2.0.0 this evening - went well. Then noticed Nodes nolonger connect... Status LEDs no longer blick. Tried updating one node to 2.3.2 but it still won't conect. Is there a step by step guide? I have over 10 other nodes that Domotics can't find.
    skywatchS
    skywatchS
    skywatch
    @Eme DId you erase the eeprom using the mysensors clear eeeprom program? If not then run that once and try again.
    EmeE 1 Reply Last reply
    • skywatchS skywatch
      EmeE
      EmeE
      Eme
      wrote on last edited by Eme
      @skywatch thanks for the update. Should l write this sketch to the Gateway alone, on each node or on both? Are there any step by step guides to gracefully migrate with? I'm very cautious, I've nodes in faraway places, wouldn't want to have to start all over again.
      • EmeE Eme
        EmeE
        EmeE
        Eme
        @Eme cleared eeprom with the sketch and loaded the Gateway Serial. I now have an error for an #include <nrf.h> I've updated boards and libraries but still can't get past the error
        "NRFS Radio is not supported for this platform. " does this mean my Serial GW can't be upgraded since l use NRF24 radios? What am l fling wrong? All my nodes are down. Please help.
        skywatchS 1 Reply Last reply
        • EmeE Eme
          skywatchS
          skywatchS
          skywatch
          @Eme Best to post the gateway sketch you are using. I guess it is the one from 2.3.2 library and not the old one from 2.0.0. Things changed.
          Also I would recommend to clear eeprom on all nodes and then reload the code modified where necessary for the new version if needed.
          It is best to have everything using the same version/protocol.
          EmeE 2 Replies Last reply
            EmeE
            EmeE
            Eme
            thanks @skywatch l took your advice cleared eeprom on only one node, and cloned my SD card before building a Rasberry Gateway/Controller since I was experiencing too much stress with the Nano-RPi gateway.
            My Config was like:-
            ./configure --my-transport=rf24 --my-rf24-irq-pin=15 --my-gateway=serial --my-serial-is-pty --my-serial-port=/dev/ttyUSB020 --my-controller-ip-address=172.0.0.1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
            I changed the Hardware on Domotics to point to the new virtual ttyUSB020 port that appeared on Domotics. but still no connection.
            Rasberry Pi Gateway/Conmtroller Tail Log is asfollows
            /home/pi/MySensors$ tail -f /var/log/syslog
            Aug 18 22:25:53 IoTGateway mysgw: TSF:CKU:OK,FCTRL
            Aug 18 22:25:53 IoTGateway mysgw: TSF:MSG:GWL OK
            Aug 18 22:25:54 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            Aug 18 22:25:55 IoTGateway systemd[1]: Started Session c4 of user pi.
            Aug 18 22:25:55 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            Aug 18 22:25:55 IoTGateway mysgw: TSF:MSG:BC
            Aug 18 22:25:55 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
            Aug 18 22:25:55 IoTGateway mysgw: TSF:CKU:OK,FCTRL
            Aug 18 22:25:55 IoTGateway mysgw: TSF:MSG:GWL OK
            Aug 18 22:25:56 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            Aug 18 22:26:07 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            Aug 18 22:26:07 IoTGateway mysgw: TSF:MSG:BC
            Aug 18 22:26:07 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
            Aug 18 22:26:07 IoTGateway mysgw: TSF:PNG:SEND,TO=0
            Aug 18 22:26:07 IoTGateway mysgw: TSF:CKU:OK
            Aug 18 22:26:07 IoTGateway mysgw: TSF:MSG:GWL OK
            Aug 18 22:26:08 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            Aug 18 22:26:09 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            Aug 18 22:26:09 IoTGateway mysgw: TSF:MSG:BC
            Aug 18 22:26:09 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
            Aug 18 22:26:09 IoTGateway mysgw: TSF:CKU:OK,FCTRL
            Aug 18 22:26:09 IoTGateway mysgw: TSF:MSG:GWL OK
            Aug 18 22:26:10 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            Aug 18 22:26:12 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            Aug 18 22:26:12 IoTGateway mysgw: TSF:MSG:BC
            Aug 18 22:26:12 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
            Aug 18 22:26:12 IoTGateway mysgw: TSF:CKU:OK,FCTRL
            Aug 18 22:26:12 IoTGateway mysgw: TSF:MSG:GWL OK
            Aug 18 22:26:12 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            Aug 18 22:26:14 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            Aug 18 22:26:14 IoTGateway mysgw: TSF:MSG:BC
            Aug 18 22:26:14 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
            Aug 18 22:26:14 IoTGateway mysgw: TSF:CKU:OK,FCTRL
            Aug 18 22:26:14 IoTGateway mysgw: TSF:MSG:GWL OK
            Aug 18 22:26:15 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            Aug 18 22:26:26 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            Aug 18 22:26:26 IoTGateway mysgw: TSF:MSG:BC
            Aug 18 22:26:26 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
            Aug 18 22:26:26 IoTGateway mysgw: TSF:PNG:SEND,TO=0
            Aug 18 22:26:26 IoTGateway mysgw: TSF:CKU:OK
            Aug 18 22:26:26 IoTGateway mysgw: TSF:MSG:GWL OK
            Aug 18 22:26:26 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            Aug 18 22:26:28 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            Aug 18 22:26:28 IoTGateway mysgw: TSF:MSG:BC
            Aug 18 22:26:28 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
            Aug 18 22:26:28 IoTGateway mysgw: TSF:CKU:OK,FCTRL
            Aug 18 22:26:28 IoTGateway mysgw: TSF:MSG:GWL OK
            Aug 18 22:26:28 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            Aug 18 22:26:30 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            Aug 18 22:26:30 IoTGateway mysgw: TSF:MSG:BC
            Aug 18 22:26:30 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
            Aug 18 22:26:30 IoTGateway mysgw: TSF:CKU:OK,FCTRL
            Aug 18 22:26:30 IoTGateway mysgw: TSF:MSG:GWL OK
            Aug 18 22:26:30 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            Aug 18 22:26:32 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            Aug 18 22:26:32 IoTGateway mysgw: TSF:MSG:BC
            Aug 18 22:26:32 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
            Aug 18 22:26:32 IoTGateway mysgw: TSF:CKU:OK,FCTRL
            Aug 18 22:26:32 IoTGateway mysgw: TSF:MSG:GWL OK
            Aug 18 22:26:32 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            Aug 18 22:26:39 IoTGateway mysgw: TSF:MSG:READ,5-5-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            Aug 18 22:26:39 IoTGateway mysgw: TSF:MSG:BC
            Aug 18 22:26:39 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=5
            Aug 18 22:26:39 IoTGateway mysgw: TSF:CKU:OK,FCTRL
            Aug 18 22:26:39 IoTGateway mysgw: TSF:MSG:GWL OK
            Aug 18 22:26:39 IoTGateway mysgw: !TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            Aug 18 22:26:41 IoTGateway mysgw: TSF:MSG:READ,5-5-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            Aug 18 22:26:41 IoTGateway mysgw: TSF:MSG:BC
            Aug 18 22:26:41 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=5
            Aug 18 22:26:41 IoTGateway mysgw: TSF:CKU:OK,FCTRL
            Aug 18 22:26:41 IoTGateway mysgw: TSF:MSG:GWL OK
            Aug 18 22:26:41 IoTGateway mysgw: !TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            Aug 18 22:26:43 IoTGateway mysgw: TSF:MSG:READ,5-5-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            Aug 18 22:26:43 IoTGateway mysgw: TSF:MSG:BC
            Aug 18 22:26:43 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=5
            Aug 18 22:26:43 IoTGateway mysgw: TSF:CKU:OK,FCTRL
            Aug 18 22:26:43 IoTGateway mysgw: TSF:MSG:GWL OK
            Aug 18 22:26:43 IoTGateway mysgw: !TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            Aug 18 22:26:44 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            Aug 18 22:26:44 IoTGateway mysgw: TSF:MSG:BC
            Aug 18 22:26:44 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
            Aug 18 22:26:44 IoTGateway mysgw: TSF:CKU:OK,FCTRL
            Aug 18 22:26:44 IoTGateway mysgw: TSF:MSG:GWL OK
            Aug 18 22:26:44 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            Aug 18 22:26:45 IoTGateway mysgw: TSF:MSG:READ,5-5-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            Aug 18 22:26:45 IoTGateway mysgw: TSF:MSG:BC
            Aug 18 22:26:45 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=5
            Aug 18 22:26:45 IoTGateway mysgw: TSF:CKU:OK,FCTRL
            Aug 18 22:26:45 IoTGateway mysgw: TSF:MSG:GWL OK
            Aug 18 22:26:45 IoTGateway mysgw: !TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            Aug 18 22:26:46 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            Aug 18 22:26:46 IoTGateway mysgw: TSF:MSG:BC
            Aug 18 22:26:46 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
            Aug 18 22:26:46 IoTGateway mysgw: TSF:CKU:OK,FCTRL
            Aug 18 22:26:46 IoTGateway mysgw: TSF:MSG:GWL OK
            Aug 18 22:26:46 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            Aug 18 22:26:48 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            Aug 18 22:26:48 IoTGateway mysgw: TSF:MSG:BC
            Aug 18 22:26:48 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
            Aug 18 22:26:48 IoTGateway mysgw: TSF:CKU:OK,FCTRL
            Aug 18 22:26:48 IoTGateway mysgw: TSF:MSG:GWL OK
            Aug 18 22:26:48 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            Aug 18 22:26:50 IoTGateway mysgw: TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            Aug 18 22:26:50 IoTGateway mysgw: TSF:MSG:BC
            Aug 18 22:26:50 IoTGateway mysgw: TSF:MSG:FPAR REQ,ID=2
            Aug 18 22:26:50 IoTGateway mysgw: TSF:CKU:OK,FCTRL
            Aug 18 22:26:50 IoTGateway mysgw: TSF:MSG:GWL OK
            Aug 18 22:26:50 IoTGateway mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            My Domoticz Log :-
            2020-08-18 22:21:53.545 Sunrise: 06:22:00 SunSet: 18:47:00
            2020-08-18 22:21:53.545 Day length: 12:25:00 Sun at south: 12:34:00
            2020-08-18 22:21:53.545 Civil twilight start: 06:00:00 Civil twilight end: 19:08:00
            2020-08-18 22:21:53.545 Nautical twilight start: 05:35:00 Nautical twilight end: 19:34:00
            2020-08-18 22:21:53.545 Astronomical twilight start: 05:09:00 Astronomical twilight end: 19:59:00
            2020-08-18 22:21:53.864 Active notification Subsystems: kodi (1/13)
            2020-08-18 22:21:53.969 Starting shared server on: :::6144
            2020-08-18 22:21:53.410 Status: Domoticz V2020.1 (c)2012-2020 GizMoCuz
            2020-08-18 22:21:53.412 Status: Build Hash: 63fa969e4, Date: 2020-03-22 15:16:16
            2020-08-18 22:21:53.413 Status: Startup Path: /home/pi/domoticz/
            2020-08-18 22:21:53.842 Status: PluginSystem: Started, Python version '3.7.3'.
            2020-08-18 22:21:53.896 Status: WebServer(HTTP) started on address: :: with port 8080
            2020-08-18 22:21:53.912 Status: WebServer(SSL) started on address: :: with port 443
            2020-08-18 22:21:53.915 Status: Camera: settings (re)loaded
            2020-08-18 22:21:53.969 Status: TCPServer: shared server started...
            2020-08-18 22:21:53.970 Status: RxQueue: queue worker started...
            2020-08-18 22:21:55.978 Status: MySensors: Worker started...
            2020-08-18 22:21:55.979 Status: Hardware Monitor: Started
            2020-08-18 22:21:56.979 MySensors: Gateway Ready...
            2020-08-18 22:21:56.004 Status: NotificationSystem: thread started...
            2020-08-18 22:21:56.005 Status: EventSystem: reset all events...
            2020-08-18 22:21:56.010 Status: EventSystem: reset all device statuses...
            2020-08-18 22:21:56.051 Status: PluginSystem: Entering work loop.
            2020-08-18 22:21:56.159 Status: Python EventSystem: Initalizing event module.
            2020-08-18 22:21:56.160 Status: EventSystem: Started
            2020-08-18 22:21:56.160 Status: EventSystem: Queue thread started...
            2020-08-18 22:21:56.979 Status: MySensors: Using serial port: /dev/ttyUSB020
            2020-08-18 22:21:57.055 MySensors: Gateway Version: 2.3.2
            2020-08-18 22:21:57.004 Status: MQTT: Connecting to 192.168.8.100:1883
            2020-08-18 22:21:57.004 Error: MQTT: Failed to start, return code: 14 (Check IP/Port)
            2020-08-18 22:22:49.016 Status: MQTT: Connecting to 192.168.8.100:1883
            2020-08-18 22:22:49.218 Status: MQTT: connected to: 192.168.8.100:1883
            2020-08-18 22:22:49.419 Status: MQTT: Subscribed
            2020-08-18 22:24:00.705 Status: New sensors allowed for 5 minutes...
            MySensor Node Serial Printout:
            16 MCO:BGN:INIT REPEATER,CP=RNNRA---,FQ=16,REL=255,VER=2.3.2
            27 TSM:INIT
            28 TSF:WUR:MS=0
            34 TSM:INIT:TSP OK
            36 TSM:INIT:STATID=5
            38 TSF:SID:OK,ID=5
            40 TSM:FPAR
            45 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            2052 !TSM:FPAR:NO REPLY
            2054 TSM:FPAR
            2058 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            4065 !TSM:FPAR:NO REPLY
            4067 TSM:FPAR
            4071 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            6078 !TSM:FPAR:NO REPLY
            6080 TSM:FPAR
            6084 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            8091 !TSM:FPAR:FAIL
            8092 TSM:FAIL:CNT=1
            8094 TSM:FAIL:DIS
            8096 TSF:TDI:TSL
            18098 TSM:FAIL:RE-INIT
            18100 TSM:INIT
            18106 TSM:INIT:TSP OK
            18108 TSM:INIT:STATID=5
            18111 TSF:SID:OK,ID=5
            18113 TSM:FPAR
            18117 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            20124 !TSM:FPAR:NO REPLY
            20126 TSM:FPAR
            20130 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            22138 !TSM:FPAR:NO REPLY
            22140 TSM:FPAR
            22145 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            24153 !TSM:FPAR:NO REPLY
            24155 TSM:FPAR
            24159 ?TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            26167 !TSM:FPAR:FAIL
            26168 TSM:FAIL:CNT=2
            26170 TSM:FAIL:DIS
            26172 TSF:TDI:TSL
            Still no luck. The node still wont present to the new gateway.
            What am I doing wrong? All my devices are still down - 4 days on.
              EmeE
              EmeE
              Eme
              @skywatch Sorry I didn't respond to this question. I didnt change the sketch. I only updated the library and uploaded to the node with the new Library. DO I have to change the sketch altogether? My sketch is as follows...
              // Example sketch showing how to control physical relays.
              // This example will remember relay state even after power failure.
              // Enable debug prints
              #define SLEEP_TIME 10000    //10 seconds
              #define MY_RF24_PA_LEVEL RF24_PA_HIGH // Options MAX to reach the furthest
              #define MY_NODE_ID 5  // Set this to fix your Radio ID or use AUTO or 1
              #define MY_REPEATER_FEATURE
              #define MY_REGISTRATION_FEATURE // Forece registration
              #define MY_REGISTRATION_RETRIES 5
              #include <TimeLib.h>
              // For Debug
              #ifdef DEBUG_ON
              #define SERIAL_START(x)
              //#define SLEEP_TIME = 18000000  // Wait every 30 minutes
              #define RELAY_PIN 2  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
              #define NUMBER_OF_RELAYS 5 // Total number of attached relays
              #define SKETCH_NAME "Water Tank Node"
              #define SKETCH_VERSION "0.3.2"
              #define CHILD_ID 0
              MyMessage msg(1,V_LIGHT);
                for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
                  // Then set relay pins to output mode
                  pinMode(pin, OUTPUT);
                  DEBUG_PRINT(F("Initialised Relay: "));
                  DEBUG_PRINT(F(sensor));
                  DEBUG_PRINT(F(" at pin "));
                  DEBUG_PRINT(F(pin));
                  DEBUG_PRINT(F(" ("));
                  DEBUG_PRINT(F(loadState(pin)));
                  DEBUG_PRINTLN(F(")"));
                  pinMode(A0, INPUT); // Then set etra sensor pins to input mode
                  DEBUG_PRINTLN(F("Initialised additional Sensor: "));
              // Fetch relay status
                  present(sensor, S_BINARY);
                  pinMode(pin, OUTPUT); // Then set relay pins in output mode
                  boolean savedState = loadState(pin); // Set relay to last known state (using eeprom storage)
                  digitalWrite(pin, savedState?RELAY_ON:RELAY_OFF);
                  DEBUG_PRINT(F("Presented Relay at : "));
                  DEBUG_PRINTLN(F(pin));
                  send(msg.set(savedState? 0 : 1));
              //  sleep(digitalPinToInterrupt(RELAY_PIN), CHANGE, SLEEP_TIME);
              void receive(const MyMessage &message){
              // Change relay state if message is receieved
              //if (digitalRead(A0) == HIGH){
              //  // Sensor says tank is full do something
              //  DEBUG_PRINTLN(F("Float Sensor High, 'Tank is Full'"));
              //  digitalWrite(3, LOW);  // Switch off tank pump
              //  saveState(message.sensor, message.getBool());
              //  bool send(MyMessage &msg, bool ack);
                if (message.type == V_STATUS){
              //   digitalWrite(message.sensor, !digitalRead(message.sensor));
                   if (message.getBool() == 0) {
                   digitalWrite(message.sensor, LOW);
                   // Store state in eeprom
                   else //getBool() == 1
                   digitalWrite(message.sensor, HIGH);
              // digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
                 Serial.print("Incoming change for sensor ID: ");
              • tekkaT tekka
                Yet another early holiday gift, MySensors 2.3.2 has finally been released!
                Highlights
                • Add support for RPI4
                • Transport and crypto HAL update
                • Rename "soft ack" to echo
                • Add log parser
                • RF24 improvements
                ...and many other bug fixes and tweaks
                Release notes and changelog: https://github.com/mysensors/MySensors/releases/tag/2.3.2
                Important information:
                If you encounter compilation issues, update your board definitions:
                • AVR 1.8.2
                • ESP8266 2.6.2
                • ESP32 1.0.4
                • SAMD 1.8.4
                • nRF5 0.6.0 (Sandeep Mistry)
                • STM32F1 2019.12.8 (stm32duino)
                Special thanks to the following people who have contributed code to this release:
                • Alfredo
                • desander
                • hannesweisbach
                • ltigges
                • Mikael Falkvidd
                • Patrick Fallberg
                • pragtich
                • Rik Jansen
                • tekka
                • Yveaux
                ...and a little teaser: 2.4 will come with a set of new features some of you have been waiting for... stay tuned :)
                J
                J
                Jstoaks
                @tekka
                It seems that this project has stalled out almost completely. There hasnt been any updates of any significant value that I can see. we have seen the Home automation platforms produce numerous updates in the past two years. Has MySensors given up with this project or will there be any milestones produced???
                skywatchS N 2 Replies Last reply
                • J Jstoaks
                  @tekka
                  skywatchS
                  skywatchS
                  skywatch
                  • J Jstoaks
                    @tekka
                    N
                    N
                    NielBierman
                    @Jstoaks
                    That would be terrible. This is such a nice project.
                    Fumée BleueF 1 Reply Last reply
                    • N NielBierman
                      @Jstoaks
                      Fumée BleueF
                      Fumée BleueF
                      Fumée Bleue
                      No news .. ? MySensors is dead ? :(
                      • J
                        J
                        JeeLet
                        what would you like as a novelty ???
                        " MySensors is dead ?" ... No, in my house it is still alive.
                        but it's true you are right to ask the question.
                        the programmers, the creators are always The ????? :)
                        what!? bought by the competition so that MySensors does not evolve any more? it makes damage to the commercial product :)
