  3. example of using sleep
5 Posts 2 Posters 683 Views 2 Watching
  • markjgabbM
    markjgabbM
    markjgabb
    Hi all
    I know this has probably been addressed before but i cant seem to find any examples of eactly how sleep should be used in this situation
    my snippet is as below
    sleep(int BUTTON_PIN, int CHANGE, unsigned long ms=0);
    im guessing i have my syntax wrong, but cant find any good examples
    i keep getting the following error
    expected primary-expression before 'int'
    basicly i just want the node to sleep forever untill the button is pressed... i know ive got something wrong, but i cant find any examples in the forum that use this verity of sleep
    YveauxY 1 Reply Last reply
    • markjgabbM markjgabb
      Hi all
      YveauxY
      YveauxY
      @markjgabb please post your full code.
      • markjgabbM
        markjgabbM
        markjgabb
        hey @Yveaux
        #define MY_RADIO_RF24
        #include <Bounce2.h>
        #define CHILD_ID 1
        #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
        Bounce debouncer = Bounce();
        int oldValue=-1;
        MyMessage msg(CHILD_ID,V_LIGHT);
        // BATTERY VOLTAGE DIVIDER SETUP
        #define VBAT_PER_BITS 0.003363075
        #define VMIN 1.9                                  //  Vmin (radio Min Volt)=1.9V (564v)
        #define VMAX 3.0                                  //  Vmax = (2xAA bat)=3.0V (892v)
        int batteryPcnt = 0;                              // Calc value for battery %
        int batLoop = 0;                                  // Loop to help calc average
        int batArray[3];                                  // Array to store value for average calc.
        int BATTERY_SENSE_PIN = A0;                       // select the input pin for the battery sense point
          // Setup the button
          pinMode(BUTTON_PIN,INPUT);
          // Activate internal pull-up
          debouncer.attach(BUTTON_PIN);
          debouncer.interval(5);
        void presentation() {
          sendSketchInfo("Lounge Multi", "3.0");
          wait(100);
          present(CHILD_ID, S_LIGHT);
          debouncer.update();
          // Get the update value
          int value = debouncer.read();
          if (value != oldValue) {
             // Send in the new value
             send(msg.set(value==HIGH ? 1 : 0));
             oldValue = value;
          batM();
        void batM() //The battery calculations
           delay(500);
           // Battery monitoring reading
           delay(500);
           // Calculate the battery in %
           float Vbat  = sensorValue * VBAT_PER_BITS;
           int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
           Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
           // Add it to array so we get an average of 3 (3x20min)
           batArray[batLoop] = batteryPcnt;
           if (batLoop > 2) {
             batteryPcnt = (batArray[0] + batArray[1] + batArray[2] + batArray[3]);
             batteryPcnt = batteryPcnt / 3;
           if (batteryPcnt > 100) {
             batteryPcnt=100;
             Serial.print("Battery Average (Send): "); Serial.print(batteryPcnt); Serial.println(" %");
               batLoop = 0;
             else
             batLoop++;
          hey @Yveaux
          #define CHILD_ID 1
          int oldValue=-1;
            // Setup the button
            wait(100);
            debouncer.update();
               oldValue = value;
            batM();
             delay(500);
             delay(500);
             if (batLoop > 2) {
               batteryPcnt=100;
                 batLoop = 0;
               else
               batLoop++;
          YveauxY
          YveauxY
          @markjgabb said in example of using sleep:
          You should remove the int & unsigned long ms= from the function call. These are only required when defining a function :
          sleep(BUTTON_PIN, CHANGE, 0);
          • markjgabbM
            markjgabbM
            markjgabb
            @Yveaux
            Cheers that's perfect.... unfortunately my FTDI programmer broke last night so now i have to wait for a new one to arrive so that i can do some more work on it :(
