  3. [SOLVED] rfm69-node <-> rpi 4 gateway: !TSM:FPAR:NO REPLY
6 Posts 2 Posters 704 Views 2 Watching
  • K
    K
    kiesel
    I am trying to build my first node using an easypcb, an arduino pro mini 3,3v and an rfm69w.
    Onto the pcb I soldered:
    • rfm69
    • arduino pro mini 3,3v
    • antenna
    • door sensor on D3
    • screw terminal.
    This is the sketch:
     * Simple binary switch example
     * Connect button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND.
     * http://www.mysensors.org/build/binary
    // General settings
    #define SKETCH_NAME "Briefkasten"
    #define SKETCH_VERSION "1.0"
    #define MY_NODE_ID 1
    #define MY_RFM69_NEW_DRIVER
    //#define MY_RADIO_RF24
    #define MY_RADIO_RFM69
    #include <Bounce2.h>
    #define CHILD_ID 3
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer = Bounce();
    int oldValue=-1;
      // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
    void presentation() {
      present(CHILD_ID, S_DOOR);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         send(msg.set(value==HIGH ? 1 : 0));
         oldValue = value;
    The gateway on the raspberry pi 4 was configured like this:
    ./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mysensorsgateway1 --my-mqtt-user=mysensors --my-mqtt-password=secretpw --my-port=1883
    This is the gateway-log:
    pi@raspberrypi:~/MySensors/bin $ sudo ./mysgw
    Jan 04 20:12:33 INFO  Starting gateway...
    Jan 04 20:12:33 INFO  Protocol version - 2.3.2-beta
    Jan 04 20:12:33 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,FQ=NA,REL=8,VER=2.3.2-beta
    Jan 04 20:12:33 DEBUG TSF:LRT:OK
    Jan 04 20:12:33 DEBUG TSM:INIT
    Jan 04 20:12:33 DEBUG TSF:WUR:MS=0
    Jan 04 20:12:33 DEBUG TSM:INIT:TSP OK
    Jan 04 20:12:33 DEBUG TSM:INIT:GW MODE
    Jan 04 20:12:33 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
    Jan 04 20:12:33 DEBUG MCO:REG:NOT NEEDED
    Jan 04 20:12:33 DEBUG MCO:BGN:STP
    Jan 04 20:12:33 DEBUG MCO:BGN:INIT OK,TSP=1
    Jan 04 20:12:33 DEBUG GWT:RMQ:CONNECTING...
    Jan 04 20:12:33 DEBUG connected to 127.0.0.1
    Jan 04 20:12:33 DEBUG GWT:RMQ:OK
    Jan 04 20:12:33 DEBUG GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
    Jan 04 20:12:33 DEBUG TSM:READY:NWD REQ
    Jan 04 20:12:33 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    Jan 04 20:27:33 DEBUG TSF:SAN:OK
    And this is the node-log:
    21:31:23.866 ->
    21:31:23.866 ->  __  __       ____
    21:31:23.866 -> |  \/  |_   _/ ___|  ___ _ __  ___  ___  _ __ ___
    21:31:23.866 -> | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __|
    21:31:23.866 -> | |  | | |_| |___| |  __/ | | \__ \  _  | |  \__ \
    21:31:23.866 -> |_|  |_|\__, |____/ \___|_| |_|___/\___/|_|  |___/
    21:31:23.866 ->         |___/                      2.3.2
    21:31:23.866 ->
    21:31:23.866 -> 16 MCO:BGN:INIT NODE,CP=RPNNA---,FQ=8,REL=255,VER=2.3.2
    21:31:23.866 -> 28 TSM:INIT
    21:31:23.866 -> 28 TSF:WUR:MS=0
    21:31:23.866 -> 30 RFM69:INIT
    21:31:23.866 -> 32 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
    21:31:23.866 -> 36 RFM69:PTX:LEVEL=5 dBm
    21:31:23.866 -> 38 TSM:INIT:TSP OK
    21:31:23.866 -> 40 TSM:INIT:STATID=1
    21:31:23.866 -> 43 TSF:SID:OK,ID=1
    21:31:23.866 -> 45 TSM:FPAR
    21:31:23.899 -> 47 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
    21:31:23.899 -> 53 RFM69:CSMA:RSSI=-106
    21:31:23.899 -> 57 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    21:31:25.888 -> 2066 !TSM:FPAR:NO REPLY
    21:31:25.888 -> 2068 TSM:FPAR
    21:31:25.888 -> 2070 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0
    21:31:25.921 -> 2074 RFM69:CSMA:RSSI=-107
    21:31:25.921 -> 2080 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    21:31:27.910 -> 4089 !TSM:FPAR:NO REPLY
    21:31:27.910 -> 4091 TSM:FPAR
    21:31:27.944 -> 4093 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0
    21:31:27.944 -> 4098 RFM69:CSMA:RSSI=-105
    21:31:27.944 -> 4104 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    21:31:29.933 -> 6113 !TSM:FPAR:NO REPLY
    21:31:29.933 -> 6115 TSM:FPAR
    21:31:29.966 -> 6117 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0
    21:31:29.966 -> 6121 RFM69:CSMA:RSSI=-106
    21:31:29.966 -> 6127 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    21:31:31.955 -> 8136 !TSM:FPAR:FAIL
    21:31:31.955 -> 8138 TSM:FAIL:CNT=1
    21:31:31.955 -> 8140 TSM:FAIL:DIS
    21:31:31.955 -> 8142 TSF:TDI:TSL
    21:31:31.955 -> 8142 RFM69:RSL
    21:31:41.968 -> 18145 TSM:FAIL:RE-INIT
    21:31:41.968 -> 18147 TSM:INIT
    21:31:41.968 -> 18149 RFM69:INIT
    21:31:42.001 -> 18151 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
    21:31:42.001 -> 18155 RFM69:PTX:LEVEL=5 dBm
    21:31:42.001 -> 18157 TSM:INIT:TSP OK
    21:31:42.001 -> 18161 TSM:INIT:STATID=1
    21:31:42.001 -> 18163 TSF:SID:OK,ID=1
    21:31:42.001 -> 18165 TSM:FPAR
    21:31:42.001 -> 18167 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
    21:31:42.001 -> 18173 RFM69:CSMA:RSSI=-108
    21:31:42.001 -> 18180 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    21:31:44.023 -> 20187 !TSM:FPAR:NO REPLY
    21:31:44.023 -> 20189 TSM:FPAR
    21:31:44.023 -> 20191 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0
    21:31:44.056 -> 20195 RFM69:CSMA:RSSI=-104
    21:31:44.056 -> 20201 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    21:31:46.045 -> 22210 !TSM:FPAR:NO REPLY
    Does anybody know what I am doing wrong?
    • K
      K
      kiesel
      wrote on last edited by kiesel
      I tried compiling the gateway as an ethernet gateway and suddenly got this output:
      pi@raspberrypi:~/MySensorsDev/MySensors $ sudo ./bin/mysgw
      Jan 04 21:05:11 INFO  Starting gateway...
      Jan 04 21:05:11 INFO  Protocol version - 2.4.0-alpha
      Jan 04 21:05:11 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,FQ=NA,REL=0,VER=2.4.0-alpha
      Jan 04 21:05:11 DEBUG TSF:LRT:OK
      Jan 04 21:05:11 DEBUG TSM:INIT
      Jan 04 21:05:11 DEBUG TSF:WUR:MS=0
      Jan 04 21:05:11 DEBUG !TSM:INIT:TSP FAIL
      Jan 04 21:05:11 DEBUG TSM:FAIL:CNT=1
      Jan 04 21:05:11 DEBUG TSM:FAIL:DIS
      Jan 04 21:05:11 DEBUG TSF:TDI:TSL
      Jan 04 21:05:21 DEBUG TSM:FAIL:RE-INIT
      Jan 04 21:05:21 DEBUG TSM:INIT
      Jan 04 21:05:21 DEBUG !TSM:INIT:TSP FAIL
      Jan 04 21:05:21 DEBUG TSM:FAIL:CNT=2
      Jan 04 21:05:21 DEBUG TSM:FAIL:DIS
      Jan 04 21:05:21 DEBUG TSF:TDI:TSL
      ^CJan 04 21:05:23 NOTICE Received SIGINT
      pi@raspberrypi:~/MySensorsDev/MySensors $ ./configure --my-gateway=ethernet --my-port=5003
      I am guessing this means my wiring is not ok? Strange that the MQTT-gateway doesn't throw the same error.
      • K kiesel
        @kiesel did you omit the rfm69 settings when you configured the gateway for ethernet? If so, the gateway tried to use a nrf24 radio, which causes init to fail.
        All parameters to configure needs to be present. Any new configure command will reset to the default settings.
        Do you have at least a few meters between the node and the gateway? If not, the signal might be too strong.
        K 1 Reply Last reply
          K
          K
          kiesel
          @mfalkvidd
          Good catch, I didn't do that. Before I saw your message I checked the wiring and I introduced a new bug apparently because now the MQTT-gateway doesn't start anymore either, so I'll have to rewire.
          I'll write again after I did that. Thanks for the help!
          • K kiesel
            @mfalkvidd
            K
            K
            kiesel
            So this was either a faulty module or bad soldering. I soldered a new module and now everything works as expected. Thanks for the help!
            • K kiesel
              Great work @kiesel, thanks for reporting back.
