Truncated message when arduino sending version info:
I check that in mMySensors arduino lib 2.3.2 on ArduinoMega
Problem with the cut message when arduino send version info:
0;255;0;0;17;2 /*!< Major release versIn Arduino/libraries/MySensors/core/Version.h, in MYSENSORS_LIBRARY_VERSION_MINOR is this cut off message. This makes mysensors in the home assistant not work.
Line 58:
#define MYSENSORS_LIBRARY_VERSION STR(MYSENSORS_LIBRARY_VERSION_MAJOR) "." STR(MYSENSORS_LIBRARY_VERSION_MINOR) "." STR(MYSENSORS_LIBRARY_VERSION_PATCH) //!< final release versioningWhen I replace it with, this work for me.
MYSENSORS_LIBRARY_VERSION "2.3.2"Is this correct behavior ?
Arduino Code:
#define MY_GATEWAY_SERIAL #define MY_REPEATER_FEATURE #define MY_NODE_ID 0 #include <SPI.h> #include <MySensors.h> #include <Bounce2.h> #define RELAY_PIN 5 #define BUTTON_PIN A0 #define CHILD_ID 1 #define RELAY_ON 1 #define RELAY_OFF 0 Bounce debouncer = Bounce(); bool state = false; bool initialValueSent = false; MyMessage msg(CHILD_ID, V_STATUS); void setup() { pinMode(BUTTON_PIN, INPUT_PULLUP); debouncer.attach(BUTTON_PIN); debouncer.interval(10); // Make sure relays are off when starting up digitalWrite(RELAY_PIN, RELAY_OFF); pinMode(RELAY_PIN, OUTPUT); } void presentation() { sendSketchInfo("Relay+button", "1.0"); present(CHILD_ID, S_BINARY); } void loop() { if (!initialValueSent) { Serial.println("Sending initial value"); send(msg.set(state?RELAY_ON:RELAY_OFF)); Serial.println("Requesting initial value from controller"); request(CHILD_ID, V_STATUS); wait(2000, C_SET, V_STATUS); } if (debouncer.update()) { if (debouncer.read()==LOW) { state = !state; // Send new state and request ack back send(msg.set(state?RELAY_ON:RELAY_OFF), true); } } } void receive(const MyMessage &message) { if (message.isAck()) { Serial.println("This is an ack from gateway"); } if (message.type == V_STATUS) { if (!initialValueSent) { Serial.println("Receiving initial value from controller"); initialValueSent = true; } // Change relay state state = (bool)message.getInt(); digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF); send(msg.set(state?RELAY_ON:RELAY_OFF)); } }Serial Output:
0;255;3;0;14;Gateway startup complete. 0;255;0;0;17;2 /*!< Major release vers 0;255;3;0;11;Relay+button 0;255;3;0;12;1.0 0;1;0;0;3; -
