  3. How low can arduino can go?
powerarduino pro minlow consumption
29 Posts 10 Posters 24.6k Views 5 Watching
  • I iask
    @funky81 Well I am not sure what else to try to get lower than 11.5uA. If you are getting 4uA then it's possible. I will have to try your sleep method
    void sleep(){
       // disable ADC
      ADCSRA = 0;
      // clear various "reset" flags
      MCUSR = 0;
      // allow changes, disable reset
      WDTCSR = bit (WDCE) | bit (WDE);
      // set interrupt mode and an interval
      WDTCSR = bit (WDIE) | bit (WDP3) | bit (WDP0);    // set WDIE, and 1 second delay
      wdt_reset();  // pat the dog
      set_sleep_mode (SLEEP_MODE_PWR_DOWN);
      noInterrupts ();           // timed sequence follows
      sleep_enable();
      // turn off brown-out enable in software
      MCUCR = bit (BODS) | bit (BODSE);
      MCUCR = bit (BODS);
      interrupts ();             // guarantees next instruction executed
      sleep_cpu ();
      // cancel sleep as a precaution
      sleep_disable();
    currently I am using
    gw.sleep(INTERRUPT,CHANGE, 0);
    F Offline
    F Offline
    funky81
    @iask how is the result?
    • T Offline
      T Offline
      Tibus
      I use the @funky81 's sleep method but the nrf doesn't go to sleep so I draw 14ma. When I use the gw.sleep method, I draw +-26ua. Is it possible to go below? (without the nrf, my own pcb with atmega328 go to 5ua in sleep mode with your function (doesn't work with gw.sleep because it's a test without the nrf ;D)
      F 1 Reply Last reply
      • T Tibus
        F Offline
        F Offline
        funky81
        wrote on last edited by funky81
        #23
        @Tibus do you have other nrf to try? I'm affraid you're using fake nrf.
        30% of my nrf (out of 10), are fake...
        one more thing, sleep method in above post dont turn off nrf radio while sleep.
        you can try gw.sleep() if you want turn off nrf radio while sleep (MyGateway gw)
        • T Offline
          T Offline
          Tibus
          yes, when I use de gw.sleep it works great but I can't go lower than 26ua+-. My test with your function draw 14ma because the nrf doesn't go to sleep... But is there a method to go lower than 26ua with the nrf? I'm already verry happy of the 26ua but if I can go lower, it would be even better ;D
          Do you things it's because I use fake nrf? where can i bought real nrf? The one I use is from electrodragon.
          • T Tibus
            F Offline
            F Offline
            funky81
            @Tibus my suggestion is that try other nrf radio.
            Right now I can low as 10uA while sleeping
            • T Offline
              T Offline
              Tibus
              ok thanks
              • E Offline
                E Offline
                ericvdb
                What do you guys use to measure such low currents?
                • E ericvdb
                  F Offline
                  F Offline
                  funky81
                  Hi @ericvdb , you can use multi tester like in this link....
                  • B Offline
                    B Offline
                    brolly759
                    This is an old thread but Tibus, the problem I had was exactly yours with 26uA. I had to downgrade my Arduino software to 1.0.6 . Then I got normal numbers 3uA.
