  3. fails to wake with 2 interupts
5 Posts 4 Posters 561 Views 4 Watching
  • markjgabbM
    markjgabbM
    markjgabb
    hi all im having issue with the follow code...
    i have two devices on pin 2 and 3 on a pro mini but cant seem to get wake working one both...
    is anyone able to hint/advise on have gone wrong?
     * Version 1.0 - Henrik Ekblad
     * Motion Sensor example using HC-SR501
     * http://www.mysensors.org/build/motion
    // Enable debug prints
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #include <OneWire.h>
    #define COMPARE_TEMP 0
    #define MAX_ATTACHED_DS18B20 1
    #define DOOR_PIN  3
    #define ONE_WIRE_BUS 5 // Pin where dallase sensor is connected
    int numSensors=1;
    bool receivedConfig = false;
    bool metric = true;
    uint32_t SLEEP_TIME = 900000; // Sleep time between reports (in milliseconds)
    #define DIGITAL_INPUT_SENSOR 2   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    #define CHILD_ID_MOTION 1   // Id of the sensor child
    #define CHILD_ID_TEMP 2
    #define CHILD_ID_DOOR 3
    // Initialize motion message
    MyMessage motion(CHILD_ID_MOTION, V_TRIPPED);
    MyMessage temp(CHILD_ID_TEMP,V_TEMP);
    MyMessage door(CHILD_ID_DOOR,V_TRIPPED);
    // BATTERY VOLTAGE DIVIDER SETUP
    #define VBAT_PER_BITS 0.003363075
    #define VMIN 1.9                                  //  Vmin (radio Min Volt)=1.9V (564v)
    #define VMAX 3.0                                  //  Vmax = (2xAA bat)=3.0V (892v)
    int batteryPcnt = 0;                              // Calc value for battery %
    int batLoop = 0;                                  // Loop to help calc average
    int batArray[3];                                  // Array to store value for average calc.
    int BATTERY_SENSE_PIN = A0;                       // select the input pin for the battery sense point
    void before()
      sensors.begin();
    pinMode(DOOR_PIN, INPUT);
      // Activate internal pull-up
      digitalWrite(DOOR_PIN, HIGH);
        sendSketchInfo("Front Hall Motion&temp", "1.0");
        present(CHILD_ID_MOTION, S_MOTION);
        present(CHILD_ID_DOOR, S_DOOR);
        // Read digital motion value
        bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
        Serial.print("Montion Sensor State: ");
        Serial.println(tripped);
        send(motion.set(tripped?"1":"0"));  // Send tripped value to gw
     bool trippeddoor = digitalRead(DOOR_PIN) == HIGH;
        Serial.print("Door Sensor State: ");
        Serial.println(trippeddoor);
        send(door.set(trippeddoor?"1":"0"));  // Send tripped value to gw
      Serial.print("Temprature: ");
      Serial.println(sensors.getTempCByIndex(0));
      wait(500);
        float temperature = sensors.getTempCByIndex(0);
          send(temp.setSensor(1).set(temperature,1));
          batM();
          delay(500);
          sleep(3000);
        sleep(DIGITAL_INPUT_SENSOR,CHANGE,DOOR_PIN,CHANGE,SLEEP_TIME);
    void batM() //The battery calculations
       delay(500);
       // Battery monitoring reading
       delay(500);
       // Calculate the battery in %
       float Vbat  = sensorValue * VBAT_PER_BITS;
       int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
       Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
       // Add it to array so we get an average of 3 (3x20min)
       batArray[batLoop] = batteryPcnt;
       if (batLoop > 2) {
         batteryPcnt = (batArray[0] + batArray[1] + batArray[2] + batArray[3]);
         batteryPcnt = batteryPcnt / 3;
       if (batteryPcnt > 100) {
         batteryPcnt=100;
         Serial.print("Battery Average (Send): "); Serial.print(batteryPcnt); Serial.println(" %");
           batLoop = 0;
         else
         batLoop++;
    BearWithBeardB 1 Reply Last reply
    • markjgabbM markjgabb
      #define DOOR_PIN  3
      int numSensors=1;
      bool metric = true;
      void before()
        sensors.begin();
        wait(500);
            batM();
            delay(500);
            sleep(3000);
         delay(500);
         delay(500);
         if (batLoop > 2) {
           batteryPcnt=100;
             batLoop = 0;
           else
           batLoop++;
      BearWithBeardB
      BearWithBeardB
      BearWithBeard
      @markjgabb said in fails to wake with 2 interupts:
      #define DOOR_PIN  3
      Use the function digitalPinToInterrupt(). It translates the pin number (2, 3) to the corresponding interrupt vector (0, 1).
      sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE,
            digitalPinToInterrupt(DOOR_PIN), CHANGE,
            SLEEP_TIME);
      • mntlvrM
        mntlvrM
        mntlvr
        to be a true pull up your the code should read pinMode(DOOR_PIN, INPUT_PULLUP);
        • skywatchS
          skywatchS
          skywatch
          @markjgabb Two great bits of advice from @BearWithBeard and @mntlvr .
          Put them both in your code and you should be good to go!
          • markjgabbM
            markjgabbM
            markjgabb
            thanks guys, ill add it to my code tonight and see how it goes
