  3. OpenHAB
  4. OH3 - MySensors Binding
135 Posts 34 Posters 32.6k Views 40 Watching
  • K Klabbe
    @TimO Thank you! It works for me with my Ethernet Gateway. I don't have that many nodes but the ones that I have, works as good as they did with OpenHAB2. I have a watermeter, an actuator and a door sensor. Great work!
    TimO
    @Klabbe thank you for your feedback!
    • K Klabbe
      G
      G
      Guillermo Schimmel
      @Klabbe great! perhaps I'll go back to ethernet gateway. Do you think is better option over mqtt gateway?
      • H
        H
        haasje30
        I did some testing with 2 openhab versions to one ethernet gateway. At first it did not discover any devices, thats because they were allready discovered in the old (2.5) version of openhab, I Think, because when I created a new mysensor device,it was immediattely discovered by the new openhab. I noticed a minor problem, there is an ability to scan (and because auto discovery did not seem to work I tried this), but after a scan the ethernet gateways failes. When you try to add a device(manually), it goes back to the first page when you select the gateway. I had to restart de openhab service to get it running again.
        I tested with a new blinds sensor (with smartsleep), and smartsleep seem to work OK. So I prefer this binding over de generic mqtt binding, because stuf like request() and smartsleep() work 'out of the box'. These are my fisrt tests, I will be doing more (other sensor types) later on when I have an additional gateway available.
        Regards...
        • T TimO
          For those of you willing to help testing the OH3 integration here is a link:
          Jar Download
          Please don't forget to fulfill the requirements for mqtt und serial. Installation of bindings will do.
          What's working after a quick test:
          • binding loads in OH3
          • serial gateway receives messages (ethernet gateway should work too)
          • discovery is working
          What's not working:
          • MQTT gateway: it's broken some time and needs some tinkering
          Please let me know if you found some time to test the binding.
          G
          G
          Guillermo Schimmel
          This post is deleted!
          • T TimO
            Jar Download
            What's not working:
            kerberosK
            kerberosK
            kerberos
            @TimO ,
            many thanks for the updated binding. I just wait to update my OpenHAB to version 3.0.0 till your binding is ready. I use a OpenHAB manual install since many years on a ArchLinuxARM system. My Mysensors gateway is a serial one, which works like a charm till OpenHAB 2.5.11 and your bindings.
            Today I updated to OpenHAB 3.0.0 and tried also OpenHAB 3.1.0-Snapshot. In both cases I got the Mysensors binding not working. It shows just "Initializing" in the Things overview. mqtt and serial transport features are installed. I don't change the manual config (things / items) files from 2.5.11 to 3.0.0.
            If I use the openhab console, the bundle:diag and bundle:status shows "Active" and no errors.
            If I take a look into the openhab.log, I found entries like:
            [WARN ] [core.karaf.internal.FeatureInstaller] - The binding add-on 'mysensors' does not exist - ignoring it.
            or
            [WARN ] [org.apache.felix.fileinstall        ] - A bundle with the same symbolic name (org.openhab.binding.mysensors) and version (3.1.0.202012312203) is already installed.  Updating this bundle
            instead.
            [WARN ] [org.apache.felix.fileinstall        ] - Failed to uninstall bundle: /opt/openhab/addons/org.openhab.binding.mysensors-3.1.0.jar.1 with id: 87. The bundle has already been uninstalled
            Maybe you can share some ideas how to solve this issue? Any help is appreciated...
            T 1 Reply Last reply
            • kerberosK kerberos
              @TimO ,
              or
              instead.
              TimO
              @kerberos Interesting find. Haven't seen something like this till now. I suggest to delete the jar file, delete the cache and start over again.
              I haven't tested textual configuration, but this should work just fine and your problem occurred before the textual configuration is initialized.
              kerberosK 1 Reply Last reply
              • A
                A
                Andreas Kräuchi
                hmm maybe I go back to the binding as well. Just spent several hours migrating all to the mqtt binding. It's working now but much slower.... So when I press a button the mqtt is slower to react as with the mysensor binding is. Why so?
                • T TimO
                  kerberosK
                  kerberosK
                  kerberos
                  @TimO
                  many thanks for quick answer. I already remove the jar file and delete the cache, tmp and mysensors folder in the userdata folder several times. The textual configuration is used for many years, with some small updates. I don't try the gui configuration.
                  If you need more data's for debugging, I will provide.
                  • G
                    G
                    gjongerh
                    Great work TimO your thing is working for me. Didn't do that much with it yet, so will keep testing.
                    • T TimO
                      Jar Download
                      What's not working:
                      Dustin HagstromD
                      Dustin HagstromD
                      Dustin Hagstrom
                      @TimO What a fantastic build, thank you so much!
                      My build:
                      OH2 -> 3.0.0 upgraded via raspberry pi update (in OH3 instructions)
                      Battery Nodes, Color Lights, Buttons, Moisture sensors
                      My Sensors Eth Gateway Serial bridge
                      Side note for any newbies like me out there. Follow the instructions for OH2 installation for my sensors. Follow the directions for manually adding in the addon. And using TimO's jar instead.
                      I've been monitoring all my logs and no issues reported, everything seems to work just like in OH2.
                      • syntacrscS
                        syntacrscS
                        syntacrsc
                        wrote on last edited by syntacrsc
                        #31
                        @TimO
                        Thanks a lot for the updated version of the openHAB Binding (jar file) for openHAB 3.
                        It seems to be working well on OH 3- just perfomed some initial testing on my OH3 (3.0.0) test system.
                        Also I feel it might be a good idea adding a link to the new 3.1.0 jar file to the "official" Install Instruction on https://www.mysensors.org/controller/openhab - don't you agree?
                        • N
                          N
                          ncollins
                          @TimO Great work.
                          I've had a merge request https://github.com/tobof/openhab2-addons/pull/141 floating around for months to add a wind direction channel to the my sensors binding.
                          Is your code in a shared repo? I'd love help add in my enhancement into your OH3 mysensors build.
                          • N
                            N
                            ncollins
                            Well, after a rather painful experience of manually upgrading and cherrypicking SerialPort changes from the decompiled OH3 mysensors jar posted above, I managed to get it a build working of the MySensors binding 3.1-SNAPSHOT.
                            This is the source: https://github.com/nikolac/openhab2-addons/tree/mysensors-oh3-migration/bundles/org.openhab.binding.mysensors
                            This fork has my addition, a direction channel on wind variables.
                            • fabyteF
                              fabyteF
                              fabyte
                              @ncollins Any chance this rebased work will be pushed upstream to the openhab/openhab-addons repo? Mainline support could help this binding with future framework changes and avoid reverse engineering of code changes and simplifies the binding installation.
                              Also any ideas on the MQTT bridge problem? Somehow the broker name cannot be resolved as also discussed here:
                              https://forum.mysensors.org/topic/10184/help-openhab-2-4-binding-mqtt
                              N 1 Reply Last reply
                              • fabyteF fabyte
                                N
                                N
                                ncollins
                                @fabyte I'd love to see this get pulled into the main repo. Not sure if @TimO plans to continue support, but I have no problem helping or even picking up where he leaves off.
                                I didn't contribute any MQTT specific fixes, and I don't recall manually migrating any MQTT fixes, but let me take a look.
                                fabyteF 1 Reply Last reply
                                • N ncollins
                                  fabyteF
                                  fabyteF
                                  fabyte
                                  wrote on last edited by fabyte
                                  #36
                                  @ncollins Thanks, really appreciate it :) Let me know if you need more info, here's the basic config I did:
                                  • created a mqtt broker (not system broker) This thing is ONLINE
                                  UID: mqtt:broker:mosquitto
                                  label: mosquitto
                                  thingTypeUID: mqtt:broker
                                  configuration:
                                    lwtQos: 0
                                    publickeypin: true
                                    keepAlive: 60
                                    clientid: 566e1af2-19c2-4596-904f-18b89c502e53
                                    qos: 0
                                    reconnectTime: 60000
                                    host: localhost
                                    secure: false
                                    certificatepin: true
                                    lwtRetain: true
                                    enableDiscovery: true
                                  • created a MySensors MQTT Bridge with default settings (brokername = mosquitto)
                                  UID: mysensors:bridge-mqtt:01d212b118
                                  label: MySensors MQTT Gateway
                                  thingTypeUID: mysensors:bridge-mqtt
                                  configuration:
                                    networkSanCheckSendHeartbeat: false
                                    topicPublish: mygateway1-in
                                    networkSanCheckInterval: 3
                                    networkSanCheckSendHeartbeatFailAttempts: 10
                                    topicSubscribe: mygateway1-out
                                    networkSanCheckEnabled: false
                                    networkSanCheckConnectionFailAttempts: 3
                                    startupCheckEnabled: false
                                    brokerName: mosquitto
                                    imperial: false
                                    sendDelay: 100
                                  Here's the logs:
                                  09:59:32.973 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-mqtt:01d212b118' changed from UNINITIALIZED to INITIALIZING
                                  09:59:32.980 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                                  09:59:32.994 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached not exist.
                                  09:59:32.995 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached not exist. Default passed, creating it...
                                  09:59:32.997 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
                                  09:59:32.998 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
                                  09:59:33.011 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Enabling connection watchdog
                                  09:59:33.015 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                                  09:59:33.016 [DEBUG] [s.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
                                  09:59:33.022 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - No connection to broker: mosquitto
                                  09:59:33.027 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-mqtt:01d212b118' changed from INITIALIZING to OFFLINE
                                  09:59:33.027 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
                                  09:59:33.029 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
                                  I tried different broker names (like mqtt:broker:mosquitto, the clientid, different uid names, but the log always says the broker cannot be found. It maps to the following lines: link
                                  I can provide more info if needed and try out debug versions of the binding if required.
                                  • fabyteF fabyte
                                    label: mosquitto
                                    configuration:
                                      lwtQos: 0
                                      publickeypin: true
                                      keepAlive: 60
                                      qos: 0
                                      host: localhost
                                      secure: false
                                      lwtRetain: true
                                    configuration:
                                      imperial: false
                                      sendDelay: 100
                                    Here's the logs:
                                    fabyteF
                                    fabyteF
                                    fabyte
                                    #37
                                    Okay, now i tried to configure the MQTT system broker connection and this seems to work.
                                    • I set up the system broker and named it 'mosquitto'.
                                    • in the MySensors MQTT bridge, as before, I used mosquitto as Broker Name. Now the Broker Name could be resolved and the Thing is online.
                                    10:12:55.086 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                                    10:12:55.089 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached not exist.
                                    10:12:55.091 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached not exist. Default passed, creating it...
                                    10:12:55.094 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
                                    10:12:55.100 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
                                    10:12:55.103 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Enabling connection watchdog
                                    10:12:55.106 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                                    10:12:55.108 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - Reason unknown
                                    10:12:55.113 [DEBUG] [s.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
                                    10:12:55.117 [DEBUG] [protocol.mqtt.MySensorsMqttConnection] - Adding consumer for topic: mygateway1-out/+/+/+/+/+
                                    10:12:55.127 [WARN ] [protocol.mqtt.MySensorsMqttConnection] - Skipping I_VERSION connection test, not recommended...
                                    10:12:55.133 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-mqtt:84dd4a387f' changed from INITIALIZING to ONLINE
                                    10:12:55.133 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
                                    10:12:55.139 [INFO ] [protocol.mqtt.MySensorsMqttConnection] - Successfully connected to MySensors Bridge.
                                    But
                                    I'm having troubles with the MQTT system broker, it can't connect the broker instance.
                                    com.hivemq.client.mqtt.exceptions.ConnectionClosedException: java.io.IOException: Connection reset by peer
                                    Caused by: java.io.IOException: Connection reset by peer
                                            at sun.nio.ch.FileDispatcherImpl.read0(Native Method) ~[?:?]
                                            at sun.nio.ch.SocketDispatcher.read(SocketDispatcher.java:39) ~[?:?]
                                            at sun.nio.ch.IOUtil.readIntoNativeBuffer(IOUtil.java:276) ~[?:?]
                                            at sun.nio.ch.IOUtil.read(IOUtil.java:233) ~[?:?]
                                            at sun.nio.ch.IOUtil.read(IOUtil.java:223) ~[?:?]
                                            at sun.nio.ch.SocketChannelImpl.read(SocketChannelImpl.java:358) ~[?:?]
                                            at io.netty.buffer.PooledByteBuf.setBytes(PooledByteBuf.java:247) ~[bundleFile:4.1.42.Final]
                                            at io.netty.buffer.AbstractByteBuf.writeBytes(AbstractByteBuf.java:1147) ~[bundleFile:4.1.42.Final]
                                            at io.netty.channel.socket.nio.NioSocketChannel.doReadBytes(NioSocketChannel.java:347) ~[bundleFile:4.1.42.Final]
                                            at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:148) [bundleFile:4.1.42.Final]
                                            at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:700) [bundleFile:4.1.42.Final]
                                            at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:635) [bundleFile:4.1.42.Final]
                                            at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:552) [bundleFile:4.1.42.Final]
                                            at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:514) [bundleFile:4.1.42.Final]
                                            at io.netty.util.concurrent.SingleThreadEventExecutor$6.run(SingleThreadEventExecutor.java:1044) [bundleFile:4.1.42.Final]
                                            at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) [bundleFile:4.1.42.Final]
                                            at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) [bundleFile:4.1.42.Final]
                                            at java.lang.Thread.run(Thread.java:834) [?:?]
                                    Since this seems more a OpenHAB/mosquitto issue I will dig into it myself.
                                    Edit
                                    The MQTT System Broker seems to be a concept from OH2, where a MQTT broker was shipped internally with OpenHAB and it seems to be broken in OH3 (OH Forum).
                                    This leaves me with the following conclusions:
                                    1. The MySensors binding configuration references the MQTT system broker connection
                                    2. With OH3, this MQTT System Broker is not working anymore.
                                    I suppose the correct way of handling this issue is to make the MySensors binding reference a normal MQTT Broker bridge, not a System Broker bridge.
                                    Anyone who knows what changes this would require? My guess is that it should be manageable -> Source Code
                                    • fabyteF fabyte
                                      But
                                      Edit
                                      N
                                      N
                                      ncollins
                                      @fabyte this is helpful.
                                      My intuition says the embedded mqtt broker and the generic mqtt binding create the same "mqtt" connection service behind the scenes. I'm guessing the generic mqtt binding isn't registering its service by name, or it's registering it by some other key.
                                      I'd like to get the mysensors addon to work with both mqtt brokers if possible.
                                      • fabyteF
                                        fabyteF
                                        fabyte
                                        @ncollins Yes, it looks like some resources are blocked or not resolved correctly when using the system broker.
                                        But the system broker functionality comes with the mqtt binding itself. Here is a screen of the settings when I deleted the mqtt binding:
                                        Also I never got the system broker working, even without defining a generic mqtt broker thing.
                                        • fabyteF
                                          fabyteF
                                          fabyte
                                          After reinstalling the mqtt bindung the MQTT System Broker connection now could be established - strange, that a reinstall was required since I did several OpenHAB system restarts and those didn't fix it.
                                          Well, now the MySensors binding is working with the system broker:
                                          Here's a MySensors temperature item:
                                          To sum up, here's what I did
                                          1. (manually) installed MySensors binding
                                          2. uninstalled mqtt binding
                                          3. installed mqtt binding
                                          4. set up the MQTT system broker connection
                                            4.1 set Connection Name to systembroker
                                            4.2 set Broker Host to localhost (it's running on the same device)
                                            4.3 Show advanced -> set Broker Port to 1883 since it was always using 8883 but I don't use a secure connection
                                            (4.4 I didn't set a clientid, no user and no password)
                                          5. set up the MySensors MQTT Gateway thing
                                            5.1 set Broker Name to systembroker
                                          N H 2 Replies Last reply
