  3. OpenHAB
  4. OH3 - MySensors Binding
135 Posts 34 Posters 35.8k Views 40 Watching
  • C CyborgAndy
    @Jarosław-Narbut Yes, I have.
    D
    D
    daanjjansen
    @CyborgAndy could you please share?
    • D
      D
      daanjjansen
      Im receiving following error in openhab:
      [protocol.mqtt.MySensorsMqttConnection] - Can't send message, connection writer is null
      Did you have the same? What did you do to resolve this?
      Using addon: org.openhab.binding.mysensors-3.2.0-SNAPSHOT.jar
      C 1 Reply Last reply
      • D daanjjansen
        C
        C
        CyborgAndy
        @daanjjansen I'm using OpenHAB 3.3.0
        Information from OpenHAB 3.3.0 release notes:
        Support for the MQTT System Broker has been removed. Replace 'mqtt:systemBroker' things with 'mqtt:broker' things.
        I fixed this error with MqttConnection. Your need remove MQTT System Broker and create new MQTT Broker.
        Download fixed org.openhab.binding.mysensors-3.3.0-SNAPSHOT.jar from my Google Disk
          mbedarff
          It seems that still some people are interested in this MySensors binding being updated further.
          I'm currently using in openHAB 3.2 the version that @vores8 kindly provided in post #109 on 21/07/2022, based on the source fork from @ncollins (https://github.com/nikolac/openhab2-addons/tree/mysensors-oh3-migration).
          Now I noticed that there seems to be a bug in the ethernet gateway with reconnecting after the TCP connection is lost. The loss of the connection is detected, but it is not disconnected and re-established afterwards.
          I would like to look at this in the " current" source code and if possible develop a fix and provide it.
          Therefore the question to the community and especially to @vores8 and @ncollins, if the source code adapted to OH 3.2 or now to OH 3.3 has been uploaded by you to GitHub. If so, under which repository and branch? If not, please catch up on it for us so that we can merge the adaption you have made to the source and possibly bundle and ensure further development.
          Thanks a lot in advance! :face_with_cowboy_hat:
          N C 2 Replies Last reply
          • M mbedarff
            N
            N
            ncollins
            @mbedarff good question. Seems @CyborgAndy is keeping the addon alive? If so, @CyborgAndy are you publishing your changes to a public branch/fork?
            • F forexsieno
              just tested OH3 (3.1.0) on PI3 with mysensors openhab binding (org.openhab.binding.mysensors-3.2.0-SNAPSHOT) in the link provided by vores8.
              feature:install openhab-transport-serial and feature:install openhab-core-io-transport-mqtt. done. It's all up and running . bundle:list shows all active.
              But the "MySensors Serial Gateway" which I intend to use in OH3 will not keep ONLINE.
              It always goes back to offline...
              11:48:29.035 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge mysensors:bridge-ser:6e5dca16a9 DONE!
              11:48:29.035 [DEBUG] [ocol.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB1 [baudRate:115200]
              11:48:29.045 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-ser:6e5dca16a9' changed from OFFLINE to ONLINE
              11:48:29.062 [ERROR] [ocol.serial.MySensorsSerialConnection] - Exception found
              java.lang.IllegalStateException: Serial Port Identifier not found
                      at org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialConnection.establishConnection(MySensorsSerialConnection.java:59) [bundleFile:?]
                      at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.connect(MySensorsAbstractConnection.java:145) [bundleFile:?]
                      at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.run(MySensorsAbstractConnection.java:124) [bundleFile:?]
                      at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) [?:?]
                      at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
                      at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
                      at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) [?:?]
                      at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) [?:?]
                      at java.lang.Thread.run(Thread.java:829) [?:?]
              11:48:29.073 [DEBUG] [ors.internal.gateway.MySensorsGateway] - MySensorsGateway connection status update -connected: false
              11:48:29.077 [DEBUG] [s.discovery.MySensorsDiscoveryService] - Stopping MySensors discovery scan
              11:48:29.080 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-ser:6e5dca16a9' changed from ONLINE to OFFLINE
              11:48:29.081 [DEBUG] [ysensors.internal.event.EventRegister] - Listener org.openhab.binding.mysensors.discovery.MySensorsDiscoveryService@b2d6b0 not present, cannot remove it
              11:48:29.086 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Connection status mysensors:bridge-ser:6e5dca16a9 updated to false
              11:48:29.090 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [0,4]
              11:48:29.095 [ERROR] [ocol.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
              any ideas?
              Duncan PullenD
              Duncan PullenD
              Duncan Pullen
              @forexsieno Did you solve this one?
              I'm still getting the same error.
              Using 3.3.0-SNAPSHOT
              2022-08-08 02:21:23.200 [ERROR] [col.serial.MySensorsSerialConnection] - Exception found
              • M mbedarff
                C
                C
                CyborgAndy
                Hi.
                @mbedarff I fix gateway connection checking issue.
                You can download the fixed version from my Google Disk
                @mbedarff @ncollins I published all changes to GitHub, "mysensors-binding-addon" branch.
                @forexsieno I tested my 3.3.0-SNAPSHOT in different environments (Arduino Nano as serial gateway, OH 3.3 installed on Windows 10 and Ubuntu Server 20.04) and did not find such a problem.
                D od1O 2 Replies Last reply
                  mbedarff
                  @CyborgAndy Glad to hear, that you have published all your fixes and upgrades to GitHub! So we have a current source code base to continue development or for debugging. :+1:
                  Thank you for the gateway connection fix! I just upgrade my OH instance from 3.2 to 3.3 and successfully tested your snapshot. :smiley:
                  Have a nice weekend!
                  • N
                    N
                    niccodemi
                    After upgrading OH from 3.2.0 to 3.3.0 and placing latest Mysensors binding (3.3.0-SNAPSHOT) into addon folder I can only get it to "Installed" status but not "active".
                    Any advise how to remove following issues?
                    openhab> feature:install openhab-transport-serial
                    openhab> feature:install openhab-core-io-transport-mqtt
                    openhab> diag 291
                    openHAB Add-ons :: Bundles :: MySensors Binding (291)
                    Status: Installed
                    Unsatisfied Requirements:
                    osgi.wiring.package; filter:="(osgi.wiring.package=org.openhab.binding.mqtt.handler)"
                    osgi.wiring.package; filter:="(osgi.wiring.package=org.openhab.binding.mysensors.action)"
                    osgi.wiring.package; filter:="(osgi.wiring.package=org.openhab.binding.mysensors.config)"
                    osgi.wiring.package; filter:="(osgi.wiring.package=org.openhab.binding.mysensors.factory)"
                    Declarative Services
                    • C CyborgAndy
                      Hi.
                      D
                      D
                      daanjjansen
                      @CyborgAndy work perfectly here.
                      Thanks for you effort!
                      • jerseyguy1996J
                        jerseyguy1996J
                        jerseyguy1996
                        @CyborgAndy @vores8 and @TimO and everyone else that worked on getting this binding to work on OH3, you guys are rockstars. I fubar'd my OH2 installation and decided that i might as well upgrade to OH3. I'm so glad that the mysensors binding works with it. I'm running a Raspberry Pi Serial Gateway which amazingly also installed with only a few minor hick-ups. Thank you all so much!
                        • C CyborgAndy
                          Hi.
                          od1O
                          od1O
                          od1
                          @CyborgAndy said in OH3 - MySensors Binding:
                          Is it normal than the add-on is not displayed on the official listing available through the UI of openHAB 3.3.0?
                          • V vores8
                            i've managed to build new version from the sources found here https://github.com/nikolac/openhab-addons/tree/mysensors-oh3-migration
                            So far, so good - working with the latest OH 3.1.0
                            please download from https://disk.yandex.ru/d/Yq3gn8N7tXSQxA
                            ChachaC
                            ChachaC
                            Chacha
                            I've upgraded to OH4 and tried Mysensors binding 3.3.0-SNAPSHOT. It fails to load with error:
                            Unresolved requirement: Import-Package: org.openhab.binding.mqtt.handler
                            However 3.2.0-SNAPSHOT works perfectly with OH4!!!
                            You can download it from this post:
                            @vores8 said in OH3 - MySensors Binding:
                            Install instructions: https://github.com/tobof/openhab-addons/wiki/Installation
                            • ChachaC Chacha
                              C
                              C
                              CyborgAndy
                              Hi @Chacha
                              Download org.openhab.binding.mysensors-4.0.4-SNAPSHOT.jar from my Google Disk and try it.
                              I only tested as a MySensors MQTT Gateway
                              kerberosK 1 Reply Last reply
                              • C CyborgAndy
                                Hi @Chacha
                                kerberosK
                                kerberosK
                                kerberos
                                Hi @CyborgAndy
                                many thanks for providing the binding update for MySensors 4.0.4! I upgrade my OpenHAB 3.4.4 a few minutes ago to 4.0.4 successfully with your binding update. I use a USB connected serial-gateway. The OpenHAB manual installation upgrade works perfect. I need to do afterwards the following steps in the Karaf console, to get the gateway online again, after the update:
                                feature:install openhab-core-io-transport-serial-javacomm
                                Many thanks again!
                                kerberos
