  3. How to manage dynamic number of sensors?
6 Posts 3 Posters 871 Views 2 Watching
  • T
    tssk
    Hello
    I build mqtt mysensors gateway with DS2482-100 to handle many (currently 15 DS18B20) 1wire sensors.
    My idea was that the gateway will dynamically start to report each attached 1wire sensors 1wire address and value automatically without necessity to change the sketch before attaching new sensor. But from what I see I need to set MyMessage(uint8_t childSensorId, uint8_t variableType); first.
    Is there some best practice pattern how to do it?
    Tomas
    • T tssk
      Hello
      Tomas
      @tssk have you tried the temperature example sketch? It supports a dynamic number of sensors.
      T 1 Reply Last reply
        tssk
        @mfalkvidd I did not see it - thanks for mentioning it.
        I think this is what I was looking for - the sketch uses one MyMessage msg(0,V_TEMP); for values from all DS18B20 with such code construction
              send(msg.setSensor(i).set(temperature,1));
        I thought I will need to set up MyMessage msg(0,V_TEMP) x number_of_sensors which would be terrible.
        I guess if I extend the code with MyMessage msg(0,V_ID) to send also the 1wire address it will be what I am looking for.
        Thanks!
        • T tssk
          Thanks!
          zboblamontZ
          zboblamontZ
          zboblamont
          @tssk I hope I've not misunderstood what you intend, but possibly a further consideration ?
          I have 14 sensors defined in an array with their digital addresses.
          During presentation a similar "for" loop to the above ties each sensor digital address with a dedicated "i" to the Controller as in your sketch. That way the sensor location is fixed - if one goes faulty it only requires that specific address edited in the array for the replacement device and reprogram the Node.
          In reality the last 2 devices in the array (Boiler) are on a separate data line to the first 12 (Spaces), but it is relatively simple to call each defined data line and address them by altering the "i" and "MAX_ATTACHED..." for each instance.
          • zboblamontZ zboblamont
            tssk
            @zboblamont Thanks for the tip. I am trying to avoid hardcoding any addresses - maybe I find out that it will be necessary at some point. But so far it looks fine:
            23:08:43.873 -> 0 MCO:BGN:INIT GW,CP=R-NGA---,FQ=8,REL=255,VER=2.3.2
            23:08:44.438 -> 585 GWT:TPC:IP=192.168.1.113
            23:08:45.468 -> 1589 MCO:BGN:STP
            23:08:45.468 -> 1591 MCO:REG:NOT NEEDED
            23:08:45.468 -> 1595 MCO:BGN:INIT OK,TSP=NA
            23:08:45.468 -> 1597 GWT:TPC:IP=192.168.1.113
            23:08:46.464 -> 2600 GWT:RMQ:CONNECTING...
            23:08:46.464 -> 2611 GWT:RMQ:OK
            23:08:46.464 -> 2613 GWT:TPS:TOPIC=1wire-out/0/255/0/0/17,MSG SENT
            23:08:46.497 -> 2619 GWT:TPS:TOPIC=1wire-out/0/255/3/0/11,MSG SENT
            23:08:46.497 -> 2625 GWT:TPS:TOPIC=1wire-out/0/255/3/0/12,MSG SENT
            23:08:46.497 -> DBG: loop start
            23:08:47.559 -> 0 : 280838211713012D
            23:08:47.559 -> 3704 GWT:TPS:TOPIC=1wire-out/0/0/1/0/42,MSG SENT
            23:08:47.592 -> 0 : 5A014B467FFF0C1044 : 21.62
            23:08:47.626 -> 3753 GWT:TPS:TOPIC=1wire-out/0/0/1/0/0,MSG SENT
            23:08:47.692 -> 1 : 28A82B7D17130189
            23:08:47.692 -> 3825 GWT:TPS:TOPIC=1wire-out/0/1/1/0/42,MSG SENT
            23:08:47.692 -> 1 : 53014B467FFF0C102D : 21.19
            23:08:47.758 -> 3876 GWT:TPS:TOPIC=1wire-out/0/1/1/0/0,MSG SENT
            23:08:47.824 -> 2 : 28949D2816130138
            23:08:47.824 -> 3948 GWT:TPS:TOPIC=1wire-out/0/2/1/0/42,MSG SENT
            23:08:47.824 -> 2 : 5F014B467FFF0C1012 : 21.94
            23:08:47.858 -> 3999 GWT:TPS:TOPIC=1wire-out/0/2/1/0/0,MSG SENT
            23:08:47.924 -> 3 : 282C3C2A16130167
            23:08:47.924 -> 4071 GWT:TPS:TOPIC=1wire-out/0/3/1/0/42,MSG SENT
            23:08:47.957 -> 3 : 56014B467FFF0C107B : 21.37
            23:08:47.990 -> 4122 GWT:TPS:TOPIC=1wire-out/0/3/1/0/0,MSG SENT
            23:08:48.057 -> 4 : 28FC801F16130104
            23:08:48.057 -> 4194 GWT:TPS:TOPIC=1wire-out/0/4/1/0/42,MSG SENT
            23:08:48.057 -> 4 : 5C014B467FFF0C10D7 : 21.75
            23:08:48.123 -> 4245 GWT:TPS:TOPIC=1wire-out/0/4/1/0/0,MSG SENT
            23:08:48.190 -> 5 : 2832312A161301C3
            23:08:48.190 -> 4317 GWT:TPS:TOPIC=1wire-out/0/5/1/0/42,MSG SENT
            23:08:48.190 -> 5 : 58014B467FFF0C10C2 : 21.50
            23:08:48.223 -> 4368 GWT:TPS:TOPIC=1wire-out/0/5/1/0/0,MSG SENT
            23:08:48.322 -> 6 : 28CAD31F16130180
            23:08:48.322 -> 4440 GWT:TPS:TOPIC=1wire-out/0/6/1/0/42,MSG SENT
            23:08:48.322 -> 6 : 57014B467FFF0C1038 : 21.44
            23:08:48.356 -> 4489 GWT:TPS:TOPIC=1wire-out/0/6/1/0/0,MSG SENT
            23:08:48.422 -> 7 : 28FFE4493118014F
            23:08:48.422 -> 4560 GWT:TPS:TOPIC=1wire-out/0/7/1/0/42,MSG SENT
            23:08:48.422 -> 7 : 58014B467FFF0C10C2 : 21.50
            23:08:48.488 -> 4612 GWT:TPS:TOPIC=1wire-out/0/7/1/0/0,MSG SENT
            23:08:48.555 -> 8 : 28FF345E311801AF
            23:08:48.555 -> 4683 GWT:TPS:TOPIC=1wire-out/0/8/1/0/42,MSG SENT
            23:08:48.555 -> 8 : 5B014B467FFF0C1007 : 21.69
            23:08:48.621 -> 4734 GWT:TPS:TOPIC=1wire-out/0/8/1/0/0,MSG SENT
            23:08:48.687 -> 9 : 28FF094131180165
            23:08:48.687 -> 4806 GWT:TPS:TOPIC=1wire-out/0/9/1/0/42,MSG SENT
            23:08:48.687 -> 9 : 55014B467FFF0C10BE : 21.31
            23:08:48.721 -> 4855 GWT:TPS:TOPIC=1wire-out/0/9/1/0/0,MSG SENT
            23:08:48.787 -> 10 : 28FFE513311802A3
            23:08:48.787 -> 4927 GWT:TPS:TOPIC=1wire-out/0/10/1/0/42,MSG SENT
            23:08:48.820 -> 10 : 51014B467FFF0C10AB : 21.06
            23:08:48.853 -> 4980 GWT:TPS:TOPIC=1wire-out/0/10/1/0/0,MSG SENT
            23:08:48.920 -> 11 : 28FF2B1F31180231
            23:08:48.920 -> 5052 GWT:TPS:TOPIC=1wire-out/0/11/1/0/42,MSG SENT
            23:08:48.920 -> 11 : 56014B467FFF0C107B : 21.37
            23:08:48.986 -> 5103 GWT:TPS:TOPIC=1wire-out/0/11/1/0/0,MSG SENT
            23:08:48.986 -> DBG: loop end
            • T
              tssk
              wrote on last edited by tssk
              In case someone is interested in the code for mysensors mqtt gateway using the DS2482.h library from https://github.com/paeaetech/paeae. The temperature conversion code is from example. I am omitting the mysensors setup.
              #include <DS2482.h>
              #include <Ethernet.h>
              #include <Wire.h>
              DS2482 ds( 0 );  //channels ds2482-800 is 0 to 7, DS2482-100 is just set 0
              byte dsData[8]; //holding for onewire capture
              byte dsAddr[8]; //1wire wire address and CRC
              MyMessage msgAddr( 0, V_ID );
              MyMessage msgTemp( 0, V_TEMP );
                //Uses Wire library to communicate with DS2482 so be sure to call Wire.begin() before using the library.
                Wire.begin();
                ds.reset();
              void presentation() {
                sendSketchInfo( SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER );
                #ifdef MY_DEBUG
                  Serial.println( "DBG: loop start" );
                ds.wireResetSearch();
                ds.wireReset();
                ds.wireSkip();
                //need to send high power to bus??  Adding 5 volts to devices makes it work.
                ds.wireWriteByte( 0x44 ); //convert temperature on all devices
                delay( 1000 );
                byte sensorId = 0;
                while( ds.wireSearch( dsAddr ) ) {
                  #ifdef MY_DEBUG
                    Serial.print( sensorId );
                    Serial.print( " : " );
                  char sensorAddr[17]; //eg. 280838211713012D
                  for( int i = 0; i < 8; i++ ) {
                    sensorAddr[i*2] = ( dsAddr[i] >> 4 ) + 0x30;
                    if ( sensorAddr[i*2] > 0x39 ) {
                      sensorAddr[i*2] += 7;
                    sensorAddr[i*2+1] = ( dsAddr[i] & 0x0f ) + 0x30;
                    if ( sensorAddr[i*2+1] > 0x39 ) {
                      sensorAddr[i*2+1] += 7;
                  sensorAddr[16]  = '\0'; //always zero terminate string
                  #ifdef MY_DEBUG
                    Serial.print( sensorAddr );
                    Serial.print( "\n" );
                  send( msgAddr.setSensor( sensorId ).set( sensorAddr ) );
                  #ifdef MY_DEBUG
                  if ( ds.crc8( dsAddr, 7 ) != dsAddr[7] ) {
                    Serial.print( "CRC is not valid!" );
                    return;
                  //test if device code DS18B20
                  if ( dsAddr[0]==0x28 ) {
                  //test if device code MAX31850
                  if ( dsAddr[0]==0x3B ) {
                  //read temperature data.
                  ds.wireReset(); //ds.reset();
                  ds.selectChannel( 0 ); //necessary on -800
                  ds.wireSelect( dsAddr );
                  ds.wireWriteByte( 0xbe ); // Read Scratchpad command
                  //display hex values of scratchpad
                  for ( int i = 0; i < 9; i++ ) { // we need 9 bytes
                    dsData[i] = ds.wireReadByte();
                    #ifdef MY_DEBUG
                      if ( dsData[i] < 16 ) {
                        Serial.print( "0" );
                      Serial.print( dsData[i], HEX );
                  //convert to decimal temperature
                  int LowByte = dsData[0];
                  int HighByte = dsData[1];
                  int TReading = ( HighByte << 8 ) + LowByte;
                  int SignBit = TReading & 0x8000; // test most sig bit
                  if ( SignBit ) // negative
                          TReading = ( TReading ^ 0xffff ) + 1; // 2's comp
                  float Tc_100 = (double) TReading * 0.0625;
                  if ( SignBit ) { // If its negative
                          Tc_100 = 0 - Tc_100;
                  //print temp for each device
                  #ifdef MY_DEBUG
                    Serial.println( Tc_100 );
                  send ( msgTemp.setSensor( sensorId ).set( Tc_100, 2 ) );
                  sensorId++;
                #ifdef MY_DEBUG
                  Serial.println( "DBG: loop end" );
                delay( 60000 );
              I am of course happy for any feedback. Especially if I am doing anything stupid as I am no programmer :)
