  3. How to connect two BH1750 digital light sensor?
bh1750light senorsdigital
2 Posts 2 Posters 511 Views 2 Watching
  • E
    E
    Eilleesy
    Banned
    Hi, all
    I want to read data from two BH1750 sensors at the same time. I connected ADDR pin to VCC for first sensor and didn't connect ADDR pin to second sensor. I2C scanner shows sensors connected to 0x23 and 0x5C respectively.
    I tried to use this LIB by Genotronex, and it's work, but the values prints in int type. So i tried this LIB by Claws, because data reads in float type and wrote a sketch, but my arduino reads data only from 0x23 address and lux1/lux2 has the same values.
    Also, I tried to change calculation method in Genotronex lib, but to no avail.
    I will be glad to any suggestions. Many thanks.
    skywatchS 1 Reply Last reply
    • E Eilleesy
      Hi, all
      skywatchS
      skywatchS
      skywatch
      @Eilleesy I suggest you post your code and any error messages you get. A link to the library you want to use might also be useful.
