  3. Feather M0 RFM69 433MHz
1 Posts 1 Posters 286 Views 1 Watching
  • zboblamontZ
    zboblamontZ
    zboblamont
    Would any users of these devices be able to advise whether the power transition between USB and Lipo is per a UPS ?
    I'd looked at these initially but decided on 328 devices which at that time I knew worked with MySensors.
    Only 4 remaining pins available on the 328 was one limit, the other was power transition - From USB to battery no problem, but restoration of USB power caused a reboot - In reality only a problem for one Node on dual power sending in water meter readings.
    Having now damaged two of the 328s (don't ask), now looking for replacements with a little more capability (multiple interrupts + extra pins), so looking again at the Feather M0.
    Thanks in advance
