  3. Node-RED
  4. myscontroller with ethernet gateway
Scheduled Pinned Locked Moved Node-RED
5 Posts 2 Posters 566 Views 2 Watching
  • J Offline
    J Offline
    JohnDoe2991
    Hi everyone!
    I currently try to setup my first MySensors network.
    I have a sensor and an ethernet gateway sitting on a breadboard and I try to get the sensor data into my database with NodeRed.
    NodeRed is running in a docker container on my database server.
    But I am not able to get the NodeRed myscontroller to work.
    Here is my test flow:
            "id": "16a94524.a7f49b",
            "type": "tab",
            "label": "MySensors",
            "disabled": false,
            "info": ""
            "id": "5ee1d371.4bf144",
            "type": "myscontroller",
            "z": "16a94524.a7f49b",
            "database": "6211fee5.94057",
            "name": "",
            "handleid": true,
            "timeresponse": true,
            "timezone": "Europe/Berlin",
            "measurementsystem": "M",
            "mqttroot": "mys-out",
            "x": 870,
            "y": 180,
            "wires": [
                    "8fd52d51.33df68",
                    "dfec2cf6.42e45"
            "id": "c9f3dd7.76aa4a",
            "type": "tcp in",
            "name": "MySensors Gateway In",
            "server": "client",
            "host": "mysensors-gateway",
            "port": "5003",
            "datamode": "stream",
            "datatype": "utf8",
            "newline": "",
            "topic": "",
            "base64": false,
            "x": 280,
            "y": 180,
            "wires": [
                    "dc2b7145.4ea57"
            "id": "dc2b7145.4ea57",
            "type": "mysdecode",
            "name": "decode",
            "mqtt": false,
            "enrich": true,
            "x": 460,
            "y": 180,
            "wires": [
                    "5ee1d371.4bf144",
                    "d63bd8aa.d34ef8"
            "id": "9e6d49f6.34fef",
            "type": "tcp out",
            "port": "5003",
            "beserver": "reply",
            "base64": false,
            "end": false,
            "name": "MySensors Gateway Out",
            "x": 1490,
            "y": 180,
            "wires": []
            "id": "8fd52d51.33df68",
            "type": "mysencode",
            "name": "encode",
            "mqtt": false,
            "mqtttopic": "",
            "x": 1260,
            "y": 180,
            "wires": [
                    "9e6d49f6.34fef"
            "id": "d63bd8aa.d34ef8",
            "type": "mysdebug",
            "name": "",
            "x": 670,
            "y": 300,
            "wires": [
                    "4170e76.d577f98"
            "id": "4170e76.d577f98",
            "type": "debug",
            "name": "request",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "payload",
            "targetType": "msg",
            "statusVal": "",
            "statusType": "auto",
            "x": 660,
            "y": 380,
            "wires": []
            "id": "dfec2cf6.42e45",
            "type": "mysdebug",
            "name": "",
            "x": 1070,
            "y": 300,
            "wires": [
                    "5653b23b.03664c"
            "id": "5653b23b.03664c",
            "type": "debug",
            "name": "response",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "statusVal": "",
            "x": 1080,
            "y": 380,
            "wires": []
            "id": "6211fee5.94057",
            "type": "mysensorsdb",
            "name": "mysensorsnodedb",
            "file": "/data/mysensorsnode.db"
    For me it looks like the controller receives messages from the gateway and response to them within the flow but the messages don't go to back to the gateway.
    I tested my setup with the MyController controller just to be sure my hardware works and everything worked instantly.
    I'm not very familiar with NodeRed so I guess I made some mistake. Can someone point me to the right direction?
    electrikE 1 Reply Last reply
    • J JohnDoe2991
      Hi everyone!
              "type": "tab",
              "disabled": false,
              "info": ""
              "name": "",
              "handleid": true,
              "x": 870,
              "y": 180,
              "wires": [
                      "8fd52d51.33df68",
                      "dfec2cf6.42e45"
              "type": "tcp in",
              "server": "client",
              "port": "5003",
              "datatype": "utf8",
              "newline": "",
              "topic": "",
              "base64": false,
              "x": 280,
              "y": 180,
              "wires": [
                      "dc2b7145.4ea57"
              "name": "decode",
              "mqtt": false,
              "enrich": true,
              "x": 460,
              "y": 180,
              "wires": [
                      "5ee1d371.4bf144",
                      "d63bd8aa.d34ef8"
              "type": "tcp out",
              "port": "5003",
              "base64": false,
              "end": false,
              "x": 1490,
              "y": 180,
              "wires": []
              "name": "encode",
              "mqtt": false,
              "mqtttopic": "",
              "x": 1260,
              "y": 180,
              "wires": [
                      "9e6d49f6.34fef"
              "type": "mysdebug",
              "name": "",
              "x": 670,
              "y": 300,
              "wires": [
                      "4170e76.d577f98"
              "type": "debug",
              "name": "request",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 660,
              "y": 380,
              "wires": []
              "type": "mysdebug",
              "name": "",
              "x": 1070,
              "y": 300,
              "wires": [
                      "5653b23b.03664c"
              "type": "debug",
              "name": "response",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 1080,
              "y": 380,
              "wires": []
      electrikE Offline
      electrikE Offline
      electrik
      @JohnDoe2991
      I'm wondering if you have to decode before going to myscontroller
      So like this
              "type": "tab",
              "disabled": false,
              "info": ""
              "name": "",
              "handleid": true,
              "x": 870,
              "y": 180,
              "wires": [
                      "8fd52d51.33df68",
                      "dfec2cf6.42e45"
              "type": "tcp in",
              "server": "client",
              "port": "5003",
              "datatype": "utf8",
              "newline": "",
              "topic": "",
              "base64": false,
              "x": 280,
              "y": 180,
              "wires": [
                      "dc2b7145.4ea57"
              "name": "decode",
              "mqtt": false,
              "enrich": true,
              "x": 460,
              "y": 180,
              "wires": [
                      "5ee1d371.4bf144",
                      "d63bd8aa.d34ef8"
              "type": "tcp out",
              "port": "5003",
              "base64": false,
              "end": false,
              "x": 1490,
              "y": 180,
              "wires": []
              "name": "encode",
              "mqtt": false,
              "mqtttopic": "",
              "x": 1260,
              "y": 180,
              "wires": [
                      "9e6d49f6.34fef"
              "type": "mysdebug",
              "name": "",
              "x": 670,
              "y": 300,
              "wires": [
                      "4170e76.d577f98"
              "type": "debug",
              "name": "request",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 660,
              "y": 380,
              "wires": []
              "type": "mysdebug",
              "name": "",
              "x": 1070,
              "y": 300,
              "wires": [
                      "5653b23b.03664c"
              "type": "debug",
              "name": "response",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 1080,
              "y": 380,
              "wires": []
      • J Offline
        J Offline
        JohnDoe2991
        @electrik
        Thanks for the reply, I think I've figured it out now:
        If i connect the myscontroller directly with the TCP connections, it won't send any messages. More importantly it looks like the whole gateway stops working correctly then. I don't receive any messages from the TCP connection.
        I have to add an decode and encode on each side of the myscontroller and restart the gateway so it will work properly.
        I guess when I tried my first flow yesterday I connected the myscontroller directly to the TCP connections and crashed my gateway this way. I didn't noticed that and thats why my second flow with the decode and encode didn't work either.
        So, all in all, it was just a "Have you tried turning it off and on again?" problem.
        • electrikE Offline
          electrikE Offline
          electrik
          Good to hear you solved it!
          • J Offline
            J Offline
            JohnDoe2991
            Well, I'm back again, because it broke again ... and I fixed it somehow again.
            I was playing around with my sensor to get it up and running the way I want it to and resetted its node id.
            It couldn't get a new node ID and I was back where I was yesterday.
            Deleted everything, rebuild the complete flow, restarted everything. Nothing helped. So I added debug messages everywhere and also had a look into the raw Serial protocol here: https://www.mysensors.org/download/serial_api_20
            It looks like you don't need the encode and decode, at least for me the encode after myscontroller totally destroyed the payload. Why did it work yesterday? I have no idea.
            The payload looked fine now without the decode and encode according to the protocol, but it still didn't work. I noticed that the incoming TCP payload always ended with a linefeed "\n", so I added a custom function between the myscontroller and tcp output to also add a linefeed to the outgoing payload and it's working again.
            12.1k
