  3. OpenHAB
  4. [Tutorial] openHAB with serial gateway
78 Posts 25 Posters 86.7k Views 16 Watching
  • H Offline
    H Offline
    HenryWhite
    Can someone help me? I want to integrate a motion sensor in OpenHAB but I don't know how to distinguish between the motion start and end. here's my openhab console log:
    • H Offline
      H Offline
      HenryWhite
      Can somebody help..?
      • Dave DanD Offline
        Dave DanD Offline
        Dave Dan
        Try removing DEBUG in the Serial GW and review messages.
        I receive a 0 or 1 depending if the motion is detected or the sensor is resetting to normal status.
        H 1 Reply Last reply
        • Dave DanD Dave Dan
          H Offline
          H Offline
          HenryWhite
          @Dave-Dan i tried it, but the motion sensor is still sending only zero's.... even if it is not triggered.
          I got these motion sensors: http://www.amazon.de/Pyroelectrische-Infrarot-Bewegung-Sensor-Detektor/dp/B008AESDSY/
          • H Offline
            H Offline
            HenryWhite
            When I look at the serial monitor output for my motion sensor, it clearly gives me a "0" or "1" depending if movement is detected or not.
            But when I look at the serial monitor of my gateway, it only receives the same message no matter if motion started (motion sensor serial monitor: 1) or ended (motion sensor serial monitor: 0)
            • T Offline
              T Offline
              TimO
              @HenryWhite The node is requesting for an id and not sending any status. You'll need to define a static id in the sketch of your node:
              http://www.mysensors.org/download/sensor_api_15#the-full-api
              Look for "Starting up the library" and the "begin()" function.
              • T TimO
                H Offline
                H Offline
                HenryWhite
                @TimO thank you so much! it works now. Any idea why i had to assign a static id? i thought the gateway should tell the node a dynamic id automatically..
                • T Offline
                  T Offline
                  TimO
                  @HenryWhite You're welcome. The id is assigned by the controller, in your case OpenHAB. There is a post in the forum about how to add a rule for id assignment, but I don't use it myself.
                  • L Offline
                    L Offline
                    lundebc
                    I have a real noob question, and I am way better with the electronics that I am the software. I can see my motion detector show up in my gateway, and in the events.log, so I know that I am getting to the Raspberry Pi I deployed opneHAB on.
                    Here's some detail:
                    So I have build the MySensors.org motion detector (and a separate temp/humidity sensor), loaded up the NRF24l01+ and PIR.
                    I created a gateway out of a nano with NRF24l01+.
                    I followed the tutorial on how to do the serial bindings.
                    I see in the terminal window runtime.busevents that the motion detector is detecting movement, and later changing back to 0, along with the other sensor I have, which is the DHT11 for temp and humidity.
                    2016-01-10 18:48:12 - Arduino state updated to 0;0;3;0;9;read: 4-4-0 s=1,c=1,t=0,pt=7,l=5:21.0
                    4;1;1;0;0;21.0
                    2016-01-10 18:48:12 - livingTemp01 state updated to 21.0
                    2016-01-10 18:49:32 - Arduino state updated to 0;0;3;0;9;read: 10-10-0 s=1,c=1,t=16,pt=0,l=1:1
                    10;1;1;0;16;1
                    2016-01-10 18:49:35 - Arduino state updated to 0;0;3;0;9;read: 10-10-0 s=1,c=1,t=16,pt=0,l=1:0
                    10;1;1;0;16;0
                    My confusion is how this software all works to get just the information from the gateway to the screen.
                    I know you have to declare an item in the demo.items file, and that item needs to be in the sitemap to display. but I do not understand how you get the status from the gateway? Can someone point me to some simple examples that include the mysensor.org PIR sensor? How does the item declaration get the knowledge of the change that the gateway is receiving from the sensor? I have read through several documents and tutorials, but I am missing this bit of information.
                    • L Offline
                      L Offline
                      lundebc
                      Ah, I finally see it, it was staring me in the face in the rules section. You identify via the msgType then assign in the rule. Doh!
                      • P poeml
                        @poeml more precisely, the Nano's FTDI chip connects to the booting Raspberry, but instead of registering a single device there are 4 (!) log lines claiming registering 4 devices (very funny), and none of the devices are bound.
                        May 23 23:16:21 bramble kernel: [    3.738087] usb 1-1.5: new full-speed USB device number 5 using dwc_otg
                        May 23 23:16:21 bramble kernel: [    4.283520] usb 1-1.5: new full-speed USB device number 6 using dwc_otg
                        May 23 23:16:21 bramble kernel: [    4.768136] usb 1-1.5: new full-speed USB device number 7 using dwc_otg
                        May 23 23:16:21 bramble kernel: [    5.268161] usb 1-1.5: new full-speed USB device number 8 using dwc_otg
                        I don't find a way to trigger re-registering the device, or power-cycle the USB port, via software. I can only power-cycle the whole USB bridge, which means that the LED goes out (the Ethernet chip is switched off as well...) and LED goes on again, but with the same faulty registering as when booting.
                         # cat reset-usb
                        #!/bin/bash
                        echo 0 > /sys/bus/usb/devices/1-1/authorized
                        sleep 1
                        echo 1 > /sys/bus/usb/devices/1-1/authorized
                        Unplugging and replugging always works.
                        For the record: Raspberry Pi version 2 with the 4 USB ports, just updated to Debian 8.0 (Jessie). I didn't check with Debian Wheezy if it worked then. The Nano was linked from MySensors store I believe and works great otherwise. I have two of them and both have the same problem (or the Raspi's USB stack has the problem, who knows).
                        P Offline
                        P Offline
                        poeml
                        @poeml following up myself, using an external, powered USB hub indeed fixed the problem. The USB adapter is now correctly usable after system bootup. (I use the official Raspberry Foundation hub, which promises to avoid issues with backpowering.)
                        • H Offline
                          H Offline
                          HenryWhite
                          wrote on last edited by HenryWhite
                          #72
                          It just took me 2 hours to realize that you should not use
                          import java.util.*
                          when you want to use timer operations like
                          if (timer=! null) {
                          Without importing java.util.* , everything works as expected. Someone has an idea why this is the case? Can you reproduce my problem?
                          • mark_vennM Offline
                            mark_vennM Offline
                            mark_venn
                            Thanks for this great post. Just what I need to get a handle on using openHAB with MySensors!
                            • N Offline
                              N Offline
                              NickBuilder
                              wrote on last edited by NickBuilder
                              #74
                              Can someone please assist me regarding this serial connection setup.
                              I can see in my event log that I receive updates of the Arduino state as below:
                              Arduino state updated to 99;1;1;0;0;23.7
                              99;0;1;0;1;37.2
                              And also in the openhab.log file I get the following types of messages:
                              [DEBUG] [b.serial.internal.SerialDevice:225  ] - Received message '99;0;1;0;1;37.6
                              ' on serial port /dev/ttyUSB99
                              But the rule is for some reason not initiated I guess as the println and logInfo i I've added to the top of the rule is absent from the logs. I can see from the tutorial and your posts that you get log information like below but these I cant find in any log.
                              [INFO ] [runtime.busevents             ]
                              Possibly I'm missing something in my logback.xml settings or perhaps there is some other reason to this which also might explain why my rule is not started. Perhaps its because I'm using a newer binding for the serial connection? (org.openhab.binding.serial-1.8.3.jar)
                              Any help would be much appreciated!
                              Update 1: Perhaps I'll try the mysensors binding and if I'm more successful with that approach I'll skip this serial binding altogether.
                              Update 2: Ok, I will be using the mysensors binding for the serial connection. I tried it last night and it just worked! And this serial binding approach also demands some quite extensive rule handling of the incoming messages which is not the case with mysensors binding. I think I read somewhere that the mysensors binding will also be available for Openhab 2.0 so hopefully I can continue using it also in the future.
                              My recommendation for new users of the serial gateway (who also uses openhap as a controller) is to go for the mysensors binding!
                              • N Offline
                                N Offline
                                NickBuilder
                                This post is deleted!
                                • H Offline
                                  H Offline
                                  HenryWhite
                                  @TimO is it possible to send commands to actuators with this method? I have a LED Dimmer Actuator and don't know what I have to do in OpenHAB to send commands to this actuator over the serial gateway..
                                  • T Offline
                                    T Offline
                                    TimO
                                    @HenryWhite: Yes it is possible.
                                    Look at this example: https://forum.mysensors.org/topic/655/serial-gateway-connection-to-openhab/70
                                    • T TimO
                                      H Offline
                                      H Offline
                                      HenryWhite
                                      @TimO
                                      Great! Thank you!
