  3. Node-RED
  4. myscontroller with mqtt gateway
Scheduled Pinned Locked Moved Node-RED
1 Posts 1 Posters 313 Views 1 Watching
  • N
    N
    NickL
    wrote on last edited by NickL
    I have a flow like this:
    [{"id":"16a94524.a7f49b","type":"tab","label":"MySensors","disabled":false,"info":""},{"id":"5ee1d371.4bf144","type":"myscontroller","z":"16a94524.a7f49b","database":"bea8f6d2.2a1b38","name":"","handleid":true,"timeresponse":true,"timezone":"US/Eastern","measurementsystem":"M","mqttroot":"mysensors-out","x":310,"y":120,"wires":[["8fd52d51.33df68","dfec2cf6.42e45"]]},{"id":"dc2b7145.4ea57","type":"mysdecode","z":"16a94524.a7f49b","database":"bea8f6d2.2a1b38","name":"decode","mqtt":true,"enrich":false,"x":140,"y":120,"wires":[["5ee1d371.4bf144","d63bd8aa.d34ef8"]]},{"id":"8fd52d51.33df68","type":"mysencode","z":"16a94524.a7f49b","name":"encode","mqtt":true,"mqtttopic":"","x":500,"y":120,"wires":[["781b37ca.286d28"]]},{"id":"d63bd8aa.d34ef8","type":"mysdebug","z":"16a94524.a7f49b","name":"","x":310,"y":180,"wires":[["4170e76.d577f98"]]},{"id":"4170e76.d577f98","type":"debug","z":"16a94524.a7f49b","name":"request","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":300,"y":240,"wires":[]},{"id":"dfec2cf6.42e45","type":"mysdebug","z":"16a94524.a7f49b","name":"","x":510,"y":180,"wires":[["5653b23b.03664c"]]},{"id":"5653b23b.03664c","type":"debug","z":"16a94524.a7f49b","name":"response","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":660,"y":180,"wires":[]},{"id":"ccc86104.d7832","type":"mqtt in","z":"16a94524.a7f49b","name":"Listen on MyS out","topic":"mysensors-out/#","qos":"2","datatype":"auto","broker":"a4c6ef71.21994","nl":false,"rap":true,"rh":0,"x":170,"y":60,"wires":[["dc2b7145.4ea57"]]},{"id":"781b37ca.286d28","type":"mqtt out","z":"16a94524.a7f49b","d":true,"name":"Send to MyS out","topic":"","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"a4c6ef71.21994","x":690,"y":120,"wires":[]},{"id":"bea8f6d2.2a1b38","type":"mysensorsdb","name":"","file":"/home/pi/MySensors/aut-main.db"},{"id":"a4c6ef71.21994","type":"mqtt-broker","name":"aut-main","broker":"aut-main","port":"1883","clientid":"","usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
    Sensor nodes have statically assigned node ids. Gateway is on Raspberry Pi, loaded with MySensors 2.4.0 Alpha. Nodes are on MySensors 2.3.2.
    If I'm enabling 'Send to MyS out' node, during the presentation phase I'm getting a flood of messages trough 'response' node, all containing the same
    "INTERNAL;nodeId:11;childId:255;SubType:I_CONFIG;ACK:0;Payload:M"
    When monitoring MQTT, it is:
    mysensors-out/11/255/3/0/6 M
    I understand that with static node ids I don't need myscontroller output, but thought I'll ask anyway, because at some point I may decide to allow dynamic node ids.
