  3. Can´t more than 11 Sensors send on my Ardoino over tcp
2 Posts 2 Posters 931 Views 2 Watching
  • S Offline
    StefanH
    Hello, i have Trobble with the quantity of Sensors.
    But the first, sorry for my English, its not the best.
    Some keydata,
    Motherboard: Ardoino UNO
    Ethernetshield: W5100
    Use D18B20 Temperature sensor
    So: When i take more than 11 sensors outside from the //, than the void setup become like a loop and tcp to my homeassistant don´t work!
    When i take Sensor 1 in the // and take the 12 outside from the // ,than the program makes what i want. So i think i cant´t use more than 11 Sensors...
    I hope somebody can help me, and thanks :)
    Now the Skript:
    ______________________________________________________________________________________________________________________________________________________________
    //#define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
    #define MY_IP_ADDRESS 192,168,178,66
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
    //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
    // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    //Temperatur
    #include <OneWire.h>
    #define ONE_WIRE_BUS 3 // alle Temperaturfühler an PIN 10
    #define TEMPERATURE_PRECISION 9
    OneWire oneWire(ONE_WIRE_BUS);
    float Temperatur[15]; // Vorgabe der Maximalen Sensoren
    //Temperaturfühleradressen
    DeviceAddress Sensor1 = {0x28, 0xFF, 0x64, 0x1F, 0x57, 0xF0, 0xF5, 0x37}; //S1Kessel
    DeviceAddress Sensor2 = {0x28, 0xFF, 0x64, 0x1F, 0x57, 0xD7, 0x09, 0x4F}; //S2Kessel
    DeviceAddress Sensor3 = {0x28, 0xFF, 0x64, 0x1F, 0x57, 0xE4, 0xBF, 0xD8}; //S3Kessel
    DeviceAddress Sensor4 = {0x28, 0xFF, 0x64, 0x1F, 0x57, 0xE4, 0x5D, 0x8D}; //S4Kessel
    DeviceAddress Sensor5 = {0x28, 0xFF, 0x64, 0x1F, 0x57, 0xD7, 0x98, 0x00}; //S5HVL
    DeviceAddress Sensor6 = {0x28, 0xFF, 0x64, 0x1F, 0x57, 0xDB, 0x11, 0x5D}; //S6HRL
    DeviceAddress Sensor7 = {0x28, 0xFF, 0x64, 0x1F, 0x57, 0xE4, 0x18, 0xF4}; //S7WP1VL
    DeviceAddress Sensor8 = {0x28, 0xFF, 0x64, 0x1F, 0x57, 0xC1, 0x30, 0x2B}; //S8WP1RL
    DeviceAddress Sensor9 = {0x28, 0xFF, 0x64, 0x1F, 0x57, 0xC7, 0x3C, 0x22}; //S9WP2VL
    DeviceAddress Sensor10 = {0x28, 0xFF, 0x64, 0x1F, 0x57, 0xC4, 0xEC, 0x20}; //S10WP2RL
    DeviceAddress Sensor11 = {0x28, 0xFF, 0x64, 0x1F, 0x57, 0xDB, 0x11, 0x5D}; //S11GHVL
    DeviceAddress Sensor12 = {0x28, 0xFF, 0x64, 0x1F, 0x57, 0xE4, 0x18, 0xF4}; //S12GHRL
    DeviceAddress Sensor13 = {0x28, 0xFF, 0x64, 0x1F, 0x57, 0xC1, 0x30, 0x2B}; //S13WP1ZL
    DeviceAddress Sensor14 = {0x28, 0xFF, 0x64, 0x1F, 0x57, 0xE4, 0xBF, 0xD8}; //S14WP1AL
    //DeviceAddress Sensor15 = {0x28, 0xAA, 0x3D, 0xB4, 0x4F, 0x14, 0x01, 0x9D}; //
      //Sensor 1
      sensors.setResolution(Sensor1, TEMPERATURE_PRECISION);
      Serial.print(F("Temperatursensor  1 Resolution: "));
      sensors.requestTemperatures();// Temperatur wird ermittelt
      Temperatur[1] = sensors.getTempC(Sensor1);
      Serial.print(sensors.getResolution(Sensor1), DEC);
      Serial.print(F( "     "));
      Serial.print(Temperatur[1]);
      Serial.println(F(" °C"));
      //Sensor 2
      sensors.setResolution(Sensor2, TEMPERATURE_PRECISION);
      Serial.print(F("Temperatursensor  2 Resolution: "));
      Temperatur[2] = sensors.getTempC(Sensor2);
      Serial.print(sensors.getResolution(Sensor2), DEC);
      Serial.print(Temperatur[2]);
      //Sensor 3
      sensors.setResolution(Sensor3, TEMPERATURE_PRECISION);
      Serial.print(F("Temperatursensor  3 Resolution: "));
      Temperatur[3] = sensors.getTempC(Sensor3);
      Serial.print(sensors.getResolution(Sensor3), DEC);
      Serial.print(Temperatur[3]);
     //Sensor 4
      sensors.setResolution(Sensor4, TEMPERATURE_PRECISION);
      Serial.print(F("Temperatursensor  4 Resolution: "));
      Temperatur[4] = sensors.getTempC(Sensor4);
      Serial.print(sensors.getResolution(Sensor4), DEC);
      Serial.print(Temperatur[4]);
      //Sensor 5
      sensors.setResolution(Sensor5, TEMPERATURE_PRECISION);
      Serial.print(F("Temperatursensor  5 Resolution: "));
      Temperatur[5] = sensors.getTempC(Sensor5);
      Serial.print(sensors.getResolution(Sensor5), DEC);
      Serial.print(Temperatur[5]);
      //Sensor 6
      sensors.setResolution(Sensor6, TEMPERATURE_PRECISION);
      Serial.print(F("Temperatursensor  6 Resolution: "));
      Temperatur[6] = sensors.getTempC(Sensor6);
      Serial.print(sensors.getResolution(Sensor6), DEC);
      Serial.print(Temperatur[6]);
      //Sensor 7
      sensors.setResolution(Sensor7, TEMPERATURE_PRECISION);
      Serial.print(F("Temperatursensor  7 Resolution: "));
      Temperatur[7] = sensors.getTempC(Sensor7);
      Serial.print(sensors.getResolution(Sensor7), DEC);
      Serial.print(Temperatur[7]);
      //Sensor 8
      sensors.setResolution(Sensor8, TEMPERATURE_PRECISION);
      Serial.print(F("Temperatursensor  8 Resolution: "));
      Temperatur[8] = sensors.getTempC(Sensor8);
      Serial.print(sensors.getResolution(Sensor8), DEC);
      Serial.print(Temperatur[8]);
      //Sensor 9
      sensors.setResolution(Sensor9, TEMPERATURE_PRECISION);
      Serial.print(F("Temperatursensor  9 Resolution: "));
      Temperatur[9] = sensors.getTempC(Sensor9);
      Serial.print(sensors.getResolution(Sensor9), DEC);
      Serial.print(Temperatur[9]);
      //Sensor 10
      sensors.setResolution(Sensor10, TEMPERATURE_PRECISION);
      Serial.print(F("Temperatursensor 10 Resolution: "));
      Temperatur[10] = sensors.getTempC(Sensor10);
      Serial.print(sensors.getResolution(Sensor10), DEC);
      Serial.print(Temperatur[10]);
      //Sensor 11
      sensors.setResolution(Sensor11, TEMPERATURE_PRECISION);
      Serial.print(F("Temperatursensor 11 Resolution: "));
      Temperatur[11] = sensors.getTempC(Sensor11);
      Serial.print(sensors.getResolution(Sensor11), DEC);
      Serial.print(Temperatur[11]);
      //Sensor 12
      sensors.setResolution(Sensor12, TEMPERATURE_PRECISION);
      Serial.print(F("Temperatursensor 12 Resolution: "));
      Temperatur[12] = sensors.getTempC(Sensor12);
      Serial.print(sensors.getResolution(Sensor12), DEC);
      Serial.print(Temperatur[12]);
      //Sensor 13
      sensors.setResolution(Sensor13, TEMPERATURE_PRECISION);
      Serial.print(F("Temperatursensor 13 Resolution: "));
      Temperatur[13] = sensors.getTempC(Sensor13);
      Serial.print(sensors.getResolution(Sensor13), DEC);
      Serial.print(Temperatur[13]);
      //Sensor 14
      sensors.setResolution(Sensor14, TEMPERATURE_PRECISION);
      Serial.print(F("Temperatursensor 14 Resolution: "));
      Temperatur[14] = sensors.getTempC(Sensor14);
      Serial.print(sensors.getResolution(Sensor14), DEC);
      Serial.print(Temperatur[14]);
      #define CHILD_ID_1 1
      #define CHILD_ID_2 2
      #define CHILD_ID_3 3
      #define CHILD_ID_4 4
      #define CHILD_ID_5 5
      #define CHILD_ID_6 6
      #define CHILD_ID_7 7
      #define CHILD_ID_8 8
      #define CHILD_ID_9 9
      #define CHILD_ID_10 10
      #define CHILD_ID_11 11
      #define CHILD_ID_12 12
      #define CHILD_ID_13 13
      #define CHILD_ID_14 14
    //   Send the sketch info to the gateway
      sendSketchInfo("Wärmespeicher", "1.0");
      present(CHILD_ID_1, S_TEMP, "Stufe 1");
      present(CHILD_ID_2, S_TEMP, "Stufe 2");
      present(CHILD_ID_3, S_TEMP, "Stufe 3");
      present(CHILD_ID_4, S_TEMP, "Stufe 4");
      present(CHILD_ID_5, S_TEMP, "Haus Vorlauf");
      present(CHILD_ID_6, S_TEMP, "Haus Rücklauf");
      present(CHILD_ID_7, S_TEMP, "Wärmepumpe 1 Vorlauf");
      present(CHILD_ID_8, S_TEMP, "Wärmepumpe 1 Rücklauf");
      present(CHILD_ID_9, S_TEMP, "Wärmepumpe 2 Vorlauf");
      present(CHILD_ID_10, S_TEMP, "Wärmepumpe 2 Rücklauf");
      present(CHILD_ID_11, S_TEMP, "Gasheizung Vorlauf");
      present(CHILD_ID_12, S_TEMP, "Gasheizung Rücklauf");
      present(CHILD_ID_13, S_TEMP, "Wärmepumpe 1 Zuluft");
      present(CHILD_ID_14, S_TEMP, "Wärmepumpe 1 Abluft");
      //15 nicht belegt
    static MyMessage msg_S1(CHILD_ID_1, V_TEMP);
    static MyMessage msg_S2(CHILD_ID_2, V_TEMP);
    static MyMessage msg_S3(CHILD_ID_3, V_TEMP);
    static MyMessage msg_S4(CHILD_ID_4, V_TEMP);
    static MyMessage msg_S5(CHILD_ID_5, V_TEMP);
    static MyMessage msg_S6(CHILD_ID_6, V_TEMP);
    static MyMessage msg_S7(CHILD_ID_7, V_TEMP);
    static MyMessage msg_S8(CHILD_ID_8, V_TEMP);
    static MyMessage msg_S9(CHILD_ID_9, V_TEMP);
    static MyMessage msg_S10(CHILD_ID_10, V_TEMP);
    static MyMessage msg_S11(CHILD_ID_11, V_TEMP);
    //static MyMessage msg_S12(CHILD_ID_12, V_TEMP);
    //static MyMessage msg_S13(CHILD_ID_13, V_TEMP);
    //static MyMessage msg_S14(CHILD_ID_14, V_TEMP);
      send(msg_S1.set(Temperatur[1], 1));
      send(msg_S2.set(Temperatur[2], 1));
      send(msg_S3.set(Temperatur[3], 1));
      send(msg_S4.set(Temperatur[4], 1));
      send(msg_S5.set(Temperatur[5], 1));
      send(msg_S6.set(Temperatur[6], 1));
      send(msg_S7.set(Temperatur[7], 1));
      send(msg_S8.set(Temperatur[8], 1));
      send(msg_S9.set(Temperatur[9], 1));
      send(msg_S10.set(Temperatur[10], 1));
      send(msg_S11.set(Temperatur[11], 1));
      //send(msg_S12.set(Temperatur[12], 1));
      //send(msg_S13.set(Temperatur[13], 1));
      //send(msg_S14.set(Temperatur[14], 1));
    • S StefanH
      Some keydata,
      Now the Skript:
      #define MY_SOFTSPI
      //Temperatur
        //Sensor 1
        //Sensor 2
        //Sensor 3
       //Sensor 4
        //Sensor 5
        //Sensor 6
        //Sensor 7
        //Sensor 8
        //Sensor 9
        //Sensor 10
        //Sensor 11
        //Sensor 12
        //Sensor 13
        //Sensor 14
        //15 nicht belegt
      Welcome to the forum @StefanH
      I took the liberty to edit your post to mark your sketch as code. This makes the code mich easier to read. You can use the </> button on top of the edit area next time.
      Have you looked at https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/DallasTemperatureSensor/DallasTemperatureSensor.ino ? It has support for multiple sensors.
      In any case, please post the debug output of your sketch. It will make it 10-100x easier to troubleshoot. If you haven't already, see https://forum.mysensors.org/topic/666/read-this-first-it-could-save-you-a-lot-of-time/ for how to enable debug output.
      12.2k
