  3. Measuring gas concentration with an MQ sensor in MySensors setup?
2 Posts 2 Posters 1.2k Views 1 Watching
  • A Offline
    A Offline
    Aria James
    Banned
    Hi everyone! I’m putting together a MySensors node and want to measure gas levels (like smoke or CO) using an MQ-series gas sensor, then send that data over MySensors radio to my controller. I found this tutorial explaining the MQ Gas Sensor series (MQ-2, MQ-3, etc.), covering their working principles and interfacing with microcontrollers: <spam link removed>
    I also checked example sketches on GitHub for MQ sensors with ESP modules, and read a blog post comparing different gas sensors in home air quality projects. Has anyone integrated an MQ sensor into a MySensors network? What resistor, calibration, or data smoothing tips worked best for you?
    • E Offline
      E Offline
      epierre
      as I experienced, MQ sensors are not really gaz sensitive, they are more particle size sensitive when hot enough and when not totally scrap.
      I would not rely my life on them, if you have an alcool spray use it around and any MQ will to go the sky...
      z-wave - Vera -&gt; Domoticz
      rfx - Domoticz &lt;- MyDomoAtHome &lt;- Imperihome
      mysensors -&gt; mysensors-gw -&gt; Domoticz
