  3. IR distance sensor usage?
proximityinfrareddistance
4 Posts 2 Posters 3.6k Views 1 Watching
  • hetbeestH
    hetbeestH
    hetbeest
    Hi all,
    I'm pretty new to mysensors, although I read a lot. I bought an IR distance sensor, the Sharp GP2Y0A21YK0F GP2Y0A21 10~80cm Infrared Proximity Distance Sensor, but I don't know how to connect it? Anyone any idea? Maybe also an example sketch?
    Thanks,
    Evert
      @hetbeest
      You can find a library and examples here.
      https://github.com/jeroendoggen/Arduino-GP2Y0A21YK-library/tree/master/DistanceGP2Y0A21YK
      If/when you have adopted it to MySensors feel free to post it here.
      • hetbeestH
        hetbeestH
        hetbeest
        Thanks. I'll have a look and surely will post my version.
        • hetbeestH
          hetbeestH
          hetbeest
          I did some quick coding, combining it with a temperature sensor. It did work for a couple of hours, after that my 9V battery was drained so far that I didn't get any data send from the sensors anymore. Quite likely the IR sensor uses a lot of power while it keeps transmitting IR. Anyhow, my quick and dirty code is:
          // Example sketch showing how to send in OneWire temperature readings
          #include <OneWire.h>
          #include <DistanceGP2Y0A21YK.h>
          #define CHILD_ID_DISTANCE 25
          DistanceGP2Y0A21YK Dist;
          unsigned long SLEEP_TIME = 500; // Sleep time between reads (in milliseconds)
          OneWire oneWire(ONE_WIRE_BUS);
          int numSensors=0;
          boolean metric = true;
          int distance;
          int lastDistance=0;
          int loopCounter=0;
          int loopsBetweenTemp = 60;
          MyMessage msg(0,V_TEMP);
          MyMessage msgdist(CHILD_ID_DISTANCE,V_DISTANCE);
          // Startup OneWire
          sensors.begin();
          Dist.begin(0);
          gw.begin();
          gw.sendSketchInfo("Temperature and Distance Sensor", "1.0");
          gw.present(CHILD_ID_DISTANCE,S_DISTANCE);
          gw.present(i, S_TEMP);
          gw.process();
          distance = Dist.getDistanceCentimeter();
          if (distance != lastDistance) {
          lastDistance = distance;
          gw.send(msgdist.set(distance));
          if (loopCounter == 0) {
            if (lastTemperature[i] != temperature && temperature != -127.00) {
          if (++loopCounter >= loopsBetweenTemp) loopCounter = 0;
          gw.sleep(SLEEP_TIME);
