  3. Using interrupts with an LDR (pro min)
3 Posts 2 Posters 2.1k Views 2 Watching
  • S
    shabba
    Hi all,
    I want to use an analog LDR to detect when my mailbox is opened and I want to run it on batteries. Hence I would like to wake only on sensor detection. The pro mini only has digital interrupt pins (not sure how analog would work anyways - thresholds?) - Anyone know any way of setting this up? I know I could use reed switches etc but I'm curious about this now!
    Thanks!
    M 1 Reply Last reply
    • S shabba
      Hi all,
      Thanks!
      maltimus
      @shabba Why not use the LDR on a digital interrupt ? LDR should be able to swing the voltage enough to trigger a state change.
      S 1 Reply Last reply
      • M maltimus
        shabba
        @maltimus Because on a dark day I was concerned this would not be enough to trigger. I intend to test it though!
