  3. Battery Sensor / Voltage Monitor
24 Posts 7 Posters 16.4k Views 3 Watching
  • S stamag
    How can I present the value in Voltage (for example 3.06 V)? I don't like the "Battery monitor".
    I have got the multiple temperature meter (DHT + Dallas) working very well. Would be nice to have battery level in volts also.
    Cheers!
    AWIA
    AWIA
    AWI
    @stamag I don't know exactly which sensors are supported in vera but you could possibly 'trick' the voltage on a custom V_VAR type.
    • S
      stamag
      This post is deleted!
      jeylitesJ 1 Reply Last reply
      • S stamag
        [[topic:post-is-deleted]]
        jeylitesJ
        jeylitesJ
        jeylites
        If I'm measuring a 5.2 volt battery, what value should R1 and R2 be?
        If the measuring voltages goes beyond the set voltage will that destroy the Arduino's input (A0)?
        • S
          stamag
          @jeylites You may change R1 and R2 and you don't destroy (A0).
          An other way is to change the multiplicator (0.003363075) in the formula:
          float batteryV = sensorValue * 0.003363075;
