  3. SCT-013-030 current monitor sensor
65 Posts 16 Posters 58.6k Views 15 Watching
  • chatainsimC
    chatainsimC
    chatainsim
    wrote on last edited by chatainsim
    #21
    @AWI
    MyMessage IrmsMsg(CHILD_ID,V_WATT);
    MyMessage kWhMsg(CHILD_ID,V_KWH);
    I also send both data but it's seems that Domoticz is ingnoring it !
    I don't know why.
    AWIA 1 Reply Last reply
    • chatainsimC chatainsim
      @AWI
      I don't know why.
      AWIA
      AWIA
      AWI
      @chatainsim Sounds you like you need to consult the Domoticz forum. The Domoticz code shows that is interpreted.
      case V_WATT:
      			_tMySensorSensor *pSensorKwh = FindSensor(pSensor->nodeID, V_KWH);
      			if (pSensorKwh) {
      				SendKwhMeter(pSensorKwh->nodeID, pSensorKwh->childID, pSensorKwh->batValue, pSensor->floatValue / 1000.0f, pSensorKwh->floatValue, "Meter");
      			else {
      				_tUsageMeter umeter;
      				umeter.id1 = 0;
      				umeter.id2 = 0;
      				umeter.id3 = 0;
      				umeter.id4 = pSensor->nodeID;
      				umeter.dunit = pSensor->childID;
      				umeter.fusage = pSensor->floatValue/1000.0f;
      				sDecodeRXMessage(this, (const unsigned char *)&umeter);
      		break;
      	case V_KWH:
      			_tMySensorSensor *pSensorWatt = FindSensor(pSensor->nodeID, V_WATT);
      			if (pSensorWatt) {
      				SendKwhMeter(pSensor->nodeID, pSensor->childID, pSensor->batValue, pSensorWatt->floatValue / 1000.0f, pSensor->floatValue, "Meter");
      			else {
      				SendKwhMeter(pSensor->nodeID, pSensor->childID, pSensor->batValue, 0, pSensor->floatValue, "Meter");
      		break;```
      • E
        E
        ewgor
        Does anyone have some OpenHab items and rules for @chatainsim sketch posted above? I have a SCT-013-000 can anyone help me use it in my project?
        Thanks!
        • E
          E
          ewgor
          Hello, anybody can help me here?
          What I want to do is to get the instant watt or kW read from my SCT013000 and to get also the kWh from a certain date, let's say fro first of this month!
          Any idea will be kindly appreciated!
          I'm using openhanb to display info and I'll need some rules for this!
          Thanks all!
          • E
            E
            ewgor
            Nobody here?
            • 5546dug5
              5546dug5
              5546dug
              I have got this to work on my Cdn system 120/240 vac using A0 and A1 pins. The code needed to be changed to address our voltage and another clamp added., but I do have a few questions;
              1. Is there a way I can record or view amps consumed in the vera dashboard?
              2. I used the sketch above displayed by @chatainsim and in it there are two lines of code with values 29.0 and second 1480 both in green and in brackets. For the life of me I can not find an explanation of these or how the values were arrived at. Can anyone help with explanation?
                  gw.present(CHILD_ID, S_POWER);
                  emon1.current(A0, 29.0);       // Current: input pin, calibration.
                 gw.process();
                 unsigned long now = millis();
                 double Irms = emon1.calcIrms(1480);
              3. Is there a method to show current in phase. I tried presenting CHILD_ID, S_MULTIMETER and MyMessage IrmsMsg(CHILD_ID,V_CURRENT); but got nowhere.
              4. There is/was much running up and down stairs from electrical panel to computer and back is OTA IDE what I think it might be-- firmware or sketches can be updated over the air from my computer>vera>gw>node while not needing to access the node? If so there is much learning for me to do.
              5. Using arduino 1.6.5, Lib 1.4.1, vera 3/veralite, ui5, Ethernet g/w , win 8.1, pro mini clone
                A Former User
                Hello, last week i buy SCT013-30 (ebay.fr) and follow this topic for have powermeter with mysensors. I need only energy (kWh) and power (W) same my OWL sensors (use with domoticz controler)
                I modifie the sketch from mysensors/pulse powermeter (http://www.mysensors.org/build/pulse_power)
                // EmonLibrary examples openenergymonitor.org, Licence GNU GPL V3  ***/
                #include "EmonLib.h"             // Include Emon Library
                EnergyMonitor emon1;             // Create an instance
                #define CHILD_ID 0
                #define PIN_ANALOG_I A2
                unsigned long lastSend;
                unsigned long lastSend2;
                unsigned long SEND_FREQUENCY = 90000; // Minimum time between send (in milliseconds).
                unsigned long SEND_FREQUENCY2 = SEND_FREQUENCY / 25;
                int index = 0;
                double Irms=0;
                double power;
                boolean pcReceived = false;
                double nrj=0, old_nrj;
                  if (message.type==V_VAR1)
                    nrj = old_nrj = message.getLong();
                    Serial.print("Received last nrj count from gw:");
                    Serial.println(nrj);
                    pcReceived = true;
                  gw.begin(incomingMessage);
                  gw.sendSketchInfo("Energy Meter", "1.0");  // Send the sketch version information to the gateway and Controller
                  gw.present(CHILD_ID, S_POWER);   // Register this device as power sensor
                  gw.request(CHILD_ID, V_VAR1);
                  emon1.current(PIN_ANALOG_I, 30.0);       // Current: input pin, calibration.
                  gw.process();
                  unsigned long now2 = millis();
                  bool sendTime2 = now2 - lastSend2 > SEND_FREQUENCY2;
                  if (sendTime2) //calcul Irms moy
                    if (index==0) Irms=emon1.calcIrms(1480);
                    else {
                    index++;
                    Irms = (index*Irms+emon1.calcIrms(1480))/(index+1);
                    lastSend2 = now2;
                  bool sendTime = now - lastSend > SEND_FREQUENCY;
                  if (sendTime && pcReceived)
                    power = Irms*232.0;
                    gw.send(IrmsMsg.set(power,1));
                    Serial.println(Irms*232.0);
                    nrj += (power*SEND_FREQUENCY/1000)/3.6E6;
                    gw.send(kWhMsg.set(nrj,3));
                    lastSend = now;
                    index = 0;
                    old_nrj=nrj;
                 else if (sendTime && !pcReceived)
                  lastSend=now;
                it seems that it works for now (but not optimal).
                0_1456322448197_upload-3801900a-dd69-437d-ac99-6f2baa635713
                Note 1) my cosphy=1 because i use only ampere clamp, i cant measure the phase between curent i and tension v.
                2) my calibration constant (used in emonlib) is 30
                3) Sorry for my english :disappointed: - Je suis français.
                • O
                  O
                  oudini
                  The cos phi applies only to the three-phase, single phase not
                  Je suis français aussi...
                  • fredokF
                    fredokF
                    fredok
                    Hello, if i remember physics course in university Power P=u.i and energy E=integrale(Pdt)=integrale(u.i.dt)=UeffxIeffxcos(phi)
                    but for particular citizen same me, energy provider non consider cos(phi)
                    So, i correct my last sketch for request last nrj value to the gw.
                    #define CHILD_ID 0
                    unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
                    int index = 0;
                    double Irms=0;
                    double power;
                    boolean onyva=true;
                    float nrj=0, old_nrj;
                        nrj = old_nrj = message.getFloat();
                        pcReceived = true;
                      if (onyva) gw.process();
                      onyva = false;
                      //unsigned long now2 = millis();
                      bool sendTime2 = now - lastSend2 > SEND_FREQUENCY2;
                        else {
                        index++;
                        lastSend2 = now;
                        power = Irms*232.0;
                        gw.send(kWhMsg.set(nrj,5));
                        gw.send(pcMsg.set(nrj,5));
                        lastSend = now;
                        index = 0;
                        old_nrj=nrj;
                        onyva=true;
                      lastSend=now;
                      index=0;
                      onyva=true;
                    thx...
                    chatainsimC warmaniacW 2 Replies Last reply
                      maciejka
                      Hi, I'm beginner of arduino programmer. Can You explain a little this sketch? What for You use "SEND_FREQUENCY2 = SEND_FREQUENCY / 25;" ? Why You using two if statements sendTime2 and sendTime ?
                      Maciej
                      • fredokF
                        fredokF
                        fredok
                        Sorry, I'm late debause i come back holiday today
                        This sketch send Power and energy (kWh) every Sendfrequency=90s but the sketch not measure power every 90s but everyre 90/25=3,6s and send to the GW the mean power (Pmean)
                        this is calculate here :
                        else {
                        index++;
                        lastSend2 = now;
                        chatainsimC 1 Reply Last reply
                        • fredokF fredok
                          #define CHILD_ID 0
                          int index = 0;
                          double Irms=0;
                          double power;
                          boolean onyva=true;
                              pcReceived = true;
                            onyva = false;
                              else {
                              index++;
                              lastSend2 = now;
                              power = Irms*232.0;
                              lastSend = now;
                              index = 0;
                              old_nrj=nrj;
                              onyva=true;
                            lastSend=now;
                            index=0;
                            onyva=true;
                          thx...
                          chatainsimC
                          chatainsimC
                          chatainsim
                          Thanks @fredok I will give a try !
                          And I'm french too ;)
                          • fredokF fredok
                            else {
                            index++;
                            lastSend2 = now;
                            chatainsimC
                            chatainsimC
                            chatainsim
                            Hi @fredok
                            Your sketch working fine.
                            Except in domoticz only the kWh is updated. Watt is not.
                            Do you have a clue about that ?
                            0_1460530318251_upload-2328793c-760b-4d2f-9a6e-5b379895cf58
                            • fredokF
                              fredokF
                              fredok
                              Hello chatainsim, in my domoticz i have only one device counting (kWh+instant Power)
                              0_1460535247416_upload-ddcdf9df-e7f6-441a-bdc0-2d426f76aa27
                              0_1460535269881_upload-a2371cbe-49f0-497d-af85-7e2433941d15
                              The instant power updated every 90s is writing in Watt value(83.3) , the kWh of the day (1.174) and total energy (61.582 kWh).... the device log show the power = f(t).
                              Look if Watt value in (kWhMeter) device change, look the log graph ... if is ok, u not need Wattmeter device.
                              Thx Fredok
                              • fredokF fredok
                                Thx Fredok
                                chatainsimC
                                chatainsimC
                                chatainsim
                                @fredok Yes, the kWhMeter is working fine:
                                0_1460558668986_upload-6238dfee-4382-4716-913e-6fb03b0f2ddf
                                • chatainsimC
                                  chatainsimC
                                  chatainsim
                                  #36
                                  Ok, so it just stop working after almost 24 hours ...
                                  I have some issue with mysensors, I don't know why, sometimes sensors stop working but I don't know why ...
                                  send: 10-10-2-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                                  send: 10-10-2-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.4
                                  send: 10-10-2-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:2
                                  sensor started, id=10, parent=2, distance=2
                                  send: 10-10-2-0 s=255,c=3,t=11,pt=0,l=12,sg=0,st=ok:Energy Meter
                                  send: 10-10-2-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.0
                                  send: 10-10-2-0 s=0,c=0,t=13,pt=0,l=0,sg=0,st=ok:
                                  send: 10-10-2-0 s=0,c=2,t=24,pt=0,l=0,sg=0,st=fail:
                                  send: 10-10-2-0 s=0,c=2,t=24,pt=0,l=0,sg=0,st=ok:
                                  • fredokF
                                    fredokF
                                    fredok
                                    hummm. i use this sketch with arduino mini near the GW (approx 5m max / 1 Wall) and i not see disconnection. So i cant help u.
                                    • chatainsimC
                                      chatainsimC
                                      chatainsim
                                      This is a recurring problem I have with MySensors.
                                      All my sensors stop working, I have to clear the eprom then reupload the sketch.
                                      Now It's working fine, until it fail again ;)
                                      • qqlapralineQ
                                        qqlapralineQ
                                        qqlapraline
                                        Hello All,
                                        I have tried this code and it works fine.
                                        I was questionning myself though. If the index request fails at some point, what would be the behaviour of the code ? From my understanding of it, it will try to get the index again and again until it succeeds. May be a another way would be not to reset the index to 0 and send the additionnal index the next time.
                                        What do you think ?
                                        QQ.
                                        • fredokF
                                          fredokF
                                          fredok
                                          Hello, sorry for my late reply.
                                          About the sketch,
                                          1. At the beginning, the sketch request the last kWh to the GW (I use Domoticz, so GW ask Domoticz the last kWh value) and send to the node.
                                          2. If node receiv, the variable pcreceiv=true and it working fine else node wait for the request until he receiv. A serial.print will inform if receiv.
                                          Fredok
