  3. SCT-013-030 current monitor sensor
65 Posts 16 Posters 58.6k Views 15 Watching
  • qqlapralineQ
    qqlapralineQ
    qqlapraline
    Yep, got that lately :)
    Thanks.
    QQ.
    • fredokF fredok
      Hello, if i remember physics course in university Power P=u.i and energy E=integrale(Pdt)=integrale(u.i.dt)=UeffxIeffxcos(phi)
      but for particular citizen same me, energy provider non consider cos(phi)
      So, i correct my last sketch for request last nrj value to the gw.
      // EmonLibrary examples openenergymonitor.org, Licence GNU GPL V3  ***/
      #include "EmonLib.h"             // Include Emon Library
      EnergyMonitor emon1;             // Create an instance
      #define CHILD_ID 0
      #define PIN_ANALOG_I A2
      unsigned long lastSend;
      unsigned long lastSend2;
      unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
      unsigned long SEND_FREQUENCY2 = SEND_FREQUENCY / 25;
      int index = 0;
      double Irms=0;
      double power;
      boolean pcReceived = false;
      boolean onyva=true;
      float nrj=0, old_nrj;
      MyMessage IrmsMsg(CHILD_ID,V_WATT);
      MyMessage kWhMsg(CHILD_ID,V_KWH);
        if (message.type==V_VAR1)
          nrj = old_nrj = message.getFloat();
          Serial.print("Received last nrj count from gw:");
          Serial.println(nrj);
          pcReceived = true;
        gw.begin(incomingMessage);
        gw.sendSketchInfo("Energy Meter", "1.0");  // Send the sketch version information to the gateway and Controller
        gw.present(CHILD_ID, S_POWER);   // Register this device as power sensor
        gw.request(CHILD_ID, V_VAR1);
        emon1.current(PIN_ANALOG_I, 30.0);       // Current: input pin, calibration.
        if (onyva) gw.process();
        onyva = false;
        unsigned long now = millis();
        //unsigned long now2 = millis();
        bool sendTime2 = now - lastSend2 > SEND_FREQUENCY2;
        if (sendTime2) //calcul Irms moy
          if (index==0) Irms=emon1.calcIrms(1480);
          else {
          index++;
          Irms = (index*Irms+emon1.calcIrms(1480))/(index+1);
          lastSend2 = now;
        bool sendTime = now - lastSend > SEND_FREQUENCY;
        if (sendTime && pcReceived)
          power = Irms*232.0;
          gw.send(IrmsMsg.set(power,1));
          Serial.println(Irms*232.0);
          nrj += (power*SEND_FREQUENCY/1000)/3.6E6;
          gw.send(kWhMsg.set(nrj,5));
          gw.send(pcMsg.set(nrj,5));
          lastSend = now;
          index = 0;
          old_nrj=nrj;
          onyva=true;
       else if (sendTime && !pcReceived)
        lastSend=now;
        index=0;
        onyva=true;
      thx...
      warmaniacW
      warmaniacW
      warmaniac
      @fredok
      hi , do you have please updated sketch for newest version of domoticz ? This old cause problems when I compiling it.
      Thanks :+1:
      gohanG 1 Reply Last reply
      • warmaniacW warmaniac
        @fredok
        Thanks :+1:
        @warmaniac look here
        https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
        warmaniacW 1 Reply Last reply
        • fredokF
          fredokF
          fredok
          @warmaniac
          Sorry i not update this sketch ...
            warmaniacW
            warmaniacW
            warmaniac
            wrote on last edited by warmaniac
            #45
            @gohan
            tried to modify but I always get error
            /MySensors.h:328:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
            #define CHILD_ID 0
            #define PIN_ANALOG_I A1
            //MySensor gw;
            int index = 0;
            double Irms=0;
            double power;
            boolean onyva=true;
            //void incomingMessage(const MyMessage &message)
                pcReceived = true;
            void presentation () {
              if (onyva) process();
              onyva = false;
                else {
                index++;
                lastSend2 = now;
                power = Irms*232.0;
                lastSend = now;
                index = 0;
                old_nrj=nrj;
                onyva=true;
              lastSend=now;
              index=0;
              onyva=true;
            It is possible to compile it with old mysensors library ? It will work with gateway which has a newest version ?
            • fredokF
              fredokF
              fredok
              Hello, at the end i write a v2.0 of the sketch
              //#include <Arduino.h>
              #include <OneWire.h>
              EnergyMonitor emon2;
              #define CHILD_ID_CLAMP1 0
              #define CHILD_ID_CLAMP2 1
              #define CHILD_ID_TEMP 2
              #define CHILD_ID_LDR 3
              #define PIN_ANALOG_I1 A2 //pince amperemetrique1
              #define PIN_ANALOG_I2 A3
              #define PIN_LDR A0 // LDR
              #define PIN_DALLAS 3
              //Definition de dallas
              #define MAX_ATTACHED_DS18B20 1
              OneWire oneWire(PIN_DALLAS);
              int numSensors = 1;
              bool receivedConfig = false;
              bool metric = true; //truc v2.0
              //int compat = 0;
              unsigned long lastSend_temp = millis();
              unsigned long lastSend_power = millis();
              unsigned long lastSend_c;
              unsigned long SEND_FREQUENCY = 120000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
              unsigned long SEND_FREQUENCY_TEMP = 300000; //delais d'emission entre 2 mesures de temps
              unsigned long SEND_FREQUENCY_C = SEND_FREQUENCY / 30;
              int index = 0;
              double Irms1 = 0;
              double Irms2 = 0;
              boolean pcReceived1 = false;
              boolean pcReceived2 = false;
              boolean first_time_temp = HIGH;
              float nrj1 = 0, old_nrj1;
              float nrj2 = 0, old_nrj2;
              int ldr = 0, old_ldr;
              MyMessage IrmsMsg1(CHILD_ID_CLAMP1, V_WATT);
              MyMessage kWhMsg1(CHILD_ID_CLAMP1, V_KWH);
              MyMessage pcMsg1(CHILD_ID_CLAMP1, V_VAR1);
              MyMessage IrmsMsg2(CHILD_ID_CLAMP2, V_WATT);
              MyMessage kWhMsg2(CHILD_ID_CLAMP2, V_KWH);
              MyMessage pcMsg2(CHILD_ID_CLAMP2, V_VAR2);
              MyMessage msgLight(CHILD_ID_LDR, V_LIGHT_LEVEL);
              void before() {
                sensors.begin();
                sendSketchInfo("Multisensors_Entree", "2.0");  // Send the sketch version information to the gateway and Controller
                present(CHILD_ID_CLAMP1, S_POWER);   // Register this device as power sensor
                request(CHILD_ID_CLAMP1, V_VAR1);
                present(CHILD_ID_CLAMP2, S_POWER);   // Register this device as power sensor
                request(CHILD_ID_CLAMP2, V_VAR2);
                numSensors = sensors.getDeviceCount(); //compte le nb de ds18
                present(CHILD_ID_LDR, S_LIGHT_LEVEL);
                if (message.type == V_VAR1)
                  nrj1 = old_nrj1 = message.getFloat();
                  Serial.println(nrj1);
                  pcReceived1 = true;
                if (message.type == V_VAR2)
                  nrj2 = old_nrj2 = message.getFloat();
                  Serial.println(nrj2);
                  pcReceived2 = true;
                emon1.current(PIN_ANALOG_I1, 30.0);       // Current: input pin, calibration.
                emon2.current(PIN_ANALOG_I2, 30.0);
                Serial.println("SETUP completed");
              void envoi_donnees(double intrms, int id_clamp)
                Serial.print("Envoi des donnees .... clamp="); Serial.println(id_clamp);
                double energie = (intrms * 232.0 * SEND_FREQUENCY / 1000) / 3.6E6;
                switch (id_clamp)
                  case 1:
                      send(IrmsMsg1.set(intrms * 232.0, 1));
                      nrj1 += energie;
                      send(kWhMsg1.set(nrj1, 5));
                      send(pcMsg1.set(nrj1, 5));
                      old_nrj1 = nrj1;
                    break;
                  case 2:
                      send(IrmsMsg2.set(intrms * 232.0, 1));
                      nrj2 += energie;
                      send(kWhMsg2.set(nrj2, 5));
                      send(pcMsg2.set(nrj2, 5));
                      old_nrj2 = nrj2;
                    break;
                bool sendTime_c = now - lastSend_c > SEND_FREQUENCY_C;
                // Calcul de Irms1 et Irms2
                if (sendTime_c) //calcul Irms moy clamp1/clamp2
                  if (index == 0)
                    Irms1 = emon1.calcIrms(1480);
                    Irms2 = emon2.calcIrms(1480);
                  else
                    Irms1 = (index * Irms1 + emon1.calcIrms(1480)) / (index + 1);
                    Irms2 = (index * Irms2 + emon2.calcIrms(1480)) / (index + 1);
                  lastSend_c = now;
                  index++;
                bool sendTime_temp = now - lastSend_temp > SEND_FREQUENCY_TEMP;
                if (sendTime_temp || first_time_temp)
                  Serial.println("........ quoiqu'il arrive, on envoi la temp+ldr");
                  first_time_temp = LOW;
                  //Send Temp
                  // Envoi Température d'après https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/DallasTemperatureSensor/DallasTemperatureSensor.ino
                  sleep(750);
                  for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++)
                   // float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
                    float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                    if (lastTemperature[i] != temperature && temperature != -127.00 && temperature != 85.00)
                      send(msgTemp.setSensor(i).set(temperature, 1));
                      Serial.println(".....................Envoi Temp");
                      lastTemperature[i] = temperature;
                //Send light LDR
                //Envoi Light LDR
                ldr = (1023 - analogRead(PIN_LDR)) / 10.23;
                if (old_ldr != ldr)
                  send(msgLight.set(ldr));
                  old_ldr = ldr;
                 lastSend_temp=now;
               bool sendTime_power = now - lastSend_power > SEND_FREQUENCY;
               if (sendTime_power)
                // Envoi ou request Puissance1
                if (pcReceived1) envoi_donnees(Irms1, 1);
                else     {
                  Serial.println("Request VAR1");
                // Envoi ou request Puissance2
                if (pcReceived2) envoi_donnees(Irms2, 2);
                else     {
                  Serial.println("Request VAR2");
                //on reinitialise les compteurs
                lastSend_power = now;
                index = 0;
              attention, i use in the same node a ds18b20 for temp and LRD for light measurment
              so u need to delete part of sketch.
              i just compiling/Verifying this with mysensors v2.1 (but not loaded in arduino pro) and no error
              for emonlib => https://github.com/openenergymonitor/EmonLib
              • fredokF
                fredokF
                fredok
                .... u must to look the monitor for see "Envoi des données .... clamp=0" and after (a few minutes after) "Envoi des données .... clamp=1"
                Look after ur domotic soft for see if your gw become something.
                bye.
                warmaniacW 2 Replies Last reply
                • fredokF fredok
                  bye.
                  warmaniacW
                  warmaniacW
                  warmaniac
                  @fredok
                  nice ! thank you very much for fast solution :) I try it at home , it compiles well :+1:
                    @gohan
                    #define CHILD_ID 0
                    //MySensor gw;
                    int index = 0;
                    double Irms=0;
                    double power;
                    boolean onyva=true;
                        pcReceived = true;
                      onyva = false;
                        else {
                        index++;
                        lastSend2 = now;
                        power = Irms*232.0;
                        lastSend = now;
                        index = 0;
                        old_nrj=nrj;
                        onyva=true;
                      lastSend=now;
                      index=0;
                      onyva=true;
                    @warmaniac you got errors because you need to move the
                    "#include <MySensors.h>" after all the "#DEFINE....." otherwise the library does not know how to be configured
                    • fredokF fredok
                      bye.
                      warmaniacW
                      warmaniacW
                      warmaniac
                      @fredok
                      I modyfied your sketch (deleting unwanted code like dallas and light sensor) it works but i think I done something wrong, because it spams my gateway , now it looks like this
                      #define PIN_ANALOG_I1 A1 //pince amperemetrique1
                      //int compat = 0;
                      int index = 0;
                      double Irms1 = 0;
                          pcReceived1 = true;
                        switch (id_clamp)
                          case 1:
                              nrj1 += energie;
                              old_nrj1 = nrj1;
                            break;
                          if (index == 0)
                          else
                          lastSend_c = now;
                          index++;
                       if (sendTime_power)
                        else     {
                      and I get this results now
                      • fredokF
                        fredokF
                        fredok
                        hello, i see the sketch send everyloop ???
                        try this
                        unsigned long lastSend_c = millis();
                        int index = 0;
                        double Irms1 = 0;
                        void before() {
                            pcReceived1 = true;
                          switch (id_clamp) //can be modified ...
                            case 1:
                                nrj1 += energie;
                                old_nrj1 = nrj1;
                              break;
                            if (index == 0)
                            else
                            lastSend_c = now;
                            index++;
                         if (sendTime_power)
                          else     {
                          index = 0;
                        if problem copy the screen of monitor.thx
                        • fredokF
                          fredokF
                          fredok
                          ahoj, if not working i will try with a new arduino for test the code.
                          dobrý večer
                          • fredokF fredok
                            dobrý večer
                            warmaniacW
                            warmaniacW
                            warmaniac
                            @fredok
                            sketch works better now , not spamming
                            0_1490898851738_upload-e9fbdb1a-1c4f-4356-826f-4e9112a25036
                            0_1490898895065_upload-f9c9fbff-f6e5-48ee-96de-8bf28054b129
                            but I dont understand current values
                            0_1490898965008_upload-d6846108-30b7-4a7d-ad02-c0b0897b20fd
                            • fredokF
                              fredokF
                              fredok
                              its seem good kWh every 2min
                              1864W is the power value
                              the sketch send power value P (in W) and energy (in kWh) calculated over 2min.
                              // and after
                              nrj1 += energie;
                              in domoticz i have one "dispositif" included instant power Watt and day cumulate energy kWh
                              bye
                              • fredokF fredok
                                // and after
                                nrj1 += energie;
                                bye
                                warmaniacW
                                warmaniacW
                                warmaniac
                                @fredok
                                Thank you very much! Only one question left, with multimeter I measured my voltage 241.0 V could I update it in sketch or ?
                                • fredokF
                                  fredokF
                                  fredok
                                  a clamp measure only intensity I (in A) and Power =UrmsxIrms so if in u home Urms=241V u can change with this value but the power measurment not consider cosphy
                                  by example the power measurment of my fridge =257W but true value is (with cosphy) 257x0,56=....W
                                  so if u change 232V with 241V why not but at the end its will continu to be a approximate of the true power.
                                  bye
                                  • fredokF fredok
                                    bye
                                    warmaniacW
                                    warmaniacW
                                    warmaniac
                                    @fredok
                                    Okay :) understand now, and what about calibration for wiring I followig this site
                                    https://learn.openenergymonitor.org/electricity-monitoring/ct-sensors/how-to-build-an-arduino-energy-monitor-measuring-current-only?redirected=true
                                    And they calibrate
                                     emon1.current(1, 111.1);
                                    And yours calibration
                                    Is some difference after this calibrations in measuring ?
                                      They also have the same sensor with also voltage measurement for a more accurate reading
                                        warmaniacW
                                        warmaniacW
                                        warmaniac
                                        @gohan
                                        Because with test sketch from that site I get actual consumption 0,5 kWh but from mysensors sketch I get much higher values look
                                        0_1490962213606_upload-ed834413-8133-438b-8e2a-95c017b3f33c
                                        1,7 kWh per one hour is too much , I had only TV and fridge in power on mode, I had total consumption per last year about 2140 kWh , which is about 6 kWh per day.
                                        • fredokF
                                          fredokF
                                          fredok
                                          hello,
                                          1. the constant 30 is the divide between ratio/burden resistor including inside the clamp
                                            for me ration=1800 and R=62ohm (1800/62 approx 30)
                                            http://www.planete-domotique.com/notices/S/C/SCT013-030V.pdf
                                          2. i can see 1677 Wh=1,677 kWh ... but 1900W for only TV+fridge its many
                                            mine clamp2 log in domoticz
                                          3. Maybe it can help u??? i have a pulse powercounter count every flash (1 Wh of energy) of mine electric box and the power (Watt) send to gw is wrong in domoticz but the energy counting (kWh) is great.
                                            Where come the wrong of fake power (GW ? sketch ? domoticz , i dont know)
                                            bye
