  3. WaterMeter and GazMeter - Reed IRQ False positive
4 Posts 3 Posters 1.9k Views 1 Watching
  • D
    D
    doblanch
    wrote on last edited by doblanch
    Hello Team,
    I have a concern :-)
    I created 2 sensors. A waterpulse counter based on Reed switch and a Gaz Counter based also on reed switch. For the waterpulse counter, the .ino is the one provided on the mysensors website. My problem is that I have some false positive.
    WhenI just plug the arduino in USB on my MAC, it works. However, If I connect it from a power supply 220V ( vin or USB), I have some issues, and I have some pulse even if there is nothing. For example, I have a soleniod valve, if I switch it ON/OFF, it troubles the Reed IRQ signal and I have a false pulse taking in account...
    So, my question is how to remove the interference. I use the reed switch in pullup, and I applied a 10uF capacitor on the reed switch.
    Should I use a specific powersupply with a filter ???? I'm lost :-( I made some tests during 6 hours without any good result.
    please help...
    • epierreE
      epierreE
      epierre
      Have a look at mine, I don't have any false positive with a reed adapted this way:
      https://github.com/empierre/arduino/blob/master/WaterMeterPulseSensor2.ino
      z-wave - Vera -> Domoticz
      • D
        D
        doblanch
        You code just remove multiple pulse during a short period of time, like a push button.
        My problem is different. I have to remove the first random pulse ! Each pulse is important for me as I use it for my gaz cooker.
        In fact, I found the solution, I remove the IRQ interrupt. The reed switch clode around 250ms. So I test during each loop. If the switch is close, I wait 30ms and test again if switch is close. If it is still close, it means that's not a false postiive and I can count a pulse.
        I have the code since 1 week, and it works properly without any false pulse.
        In fact my solenoide valve is too close from arduino and it make some interference I can't remove with capacitors...
        Here is my code:
         if (state != laststate)
           delay(30);
           delay(30);
               if (state == HIGH)
                unsigned long interval = newBlink-lastBlink;
                lastPulse = millis();
                flow = (60000000.0 /interval) / ppl;
                lastBlink = newBlink;
                pulseCount++;
                Serial.print("pulseCount:");
                Serial.println(pulseCount);
                Serial.print("interval:");
                Serial.println(interval/1000);
                state = laststate;
                flow = (60000000.0 / interval) / ppl;
                alarm_flag = 1;
           //     state1 == true; // un pulse est apparu, on demarre l'alarm
                alarm1 = 0;
                alarm1_t = millis();
               if (state == LOW)
               state = laststate;
        • BulldogLowellB
          BulldogLowellB
          BulldogLowell
          delay(30);
          delay(30);
          why do you have these blocking delay()s? I would focus on non-blocking code for such a device... Are you using an interrupt?
          I think you need to post your entire sketch to get good comments
