  3. Motion Sensor Recycled based on minimalistic PCB arduino design
7 Posts 3 Posters 6.1k Views 1 Watching
  • FotoFieberF
    FotoFieberF
    FotoFieber
    Take an old motion sensor:
    Remove existing PCB:
    Insert mysensors technology:
    With more skills, it would look nicer:
    Sketch:
    unsigned long SLEEP_TIME = 7200000; // Sleep time between reports (in milliseconds)
    unsigned long SLEEP_TIME_AFTER_MOTION = 30000; // Forced Sleep after motion report
    boolean interrupted = false;
    int batteryRound = 0;
    #define BATTERY_ROUNDS 20
    // Initialize motion message
      //switchClock(1<<CLKPS2);
      delay(1000);
      gw.begin();
      gw.sendSketchInfo("Motion Sensor VC Int", "1.2");
      gw.present(CHILD_ID, S_MOTION);
      gw.sleep(1000);
      // Read digital motion value
      gw.send(msg.set(tripped ? "1" : "0")); // Send tripped value to gw
      batteryRound++;
      if ((interrupted == false) || // wake up from timer?
          (batteryRound >= BATTERY_ROUNDS) )
        batteryRound = 0;
        // measure battery state
        long sensorValue = readVcc();
        // 100 -> 3000, 0 -> 2000
        if (sensorValue < 2000)
          sensorValue = 0;
        else
          sensorValue -= 2000;
        int batteryPcnt = (int)((float)(sensorValue) / 10.0);
        if (batteryPcnt > 100) batteryPcnt = 100;
        gw.sleep(1000);
      if (tripped == true) {
        // take a brake and do not report motion for some time
        interrupted = true;  // don't send vcc after short sleep
        gw.sleep(SLEEP_TIME_AFTER_MOTION);
      // Sleep until interrupt comes in on motion sensor
      else interrupted = gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
    // see http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
    long readVcc() {
    #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
      ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
    #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
      ADMUX = _BV(MUX5) | _BV(MUX0);
    #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
      ADMUX = _BV(MUX3) | _BV(MUX2);
    #else
      while (bit_is_set(ADCSRA, ADSC)); // measuring
      long result = (high << 8) | low;
    void switchClock(unsigned char clk)
      cli();
      CLKPR = 1 << CLKPCE; // Set CLKPCE to enable clk switching
      CLKPR = clk;
      sei();
    Minimalistic PCB (self designed with fritzing):
    mysduino2.fzz
    https://oshpark.com/shared_projects/mcUfoUxu
    The PCB has a flexible design (use jumpers):
    • use with battery (used here)
    • use with 5 volt (and LE33 for NRF24L01+)
    • use with voltage stabilazitaion to 3.3V (LE33) for ATMEGA328P and NRF24l01+
    DwaltD 1 Reply Last reply
    • FotoFieberF FotoFieber
      Sketch:
        delay(1000);
        gw.begin();
        gw.sleep(1000);
        batteryRound++;
          batteryRound = 0;
            sensorValue = 0;
          else
          gw.sleep(1000);
      long readVcc() {
      #else
        cli();
        CLKPR = clk;
        sei();
      mysduino2.fzz
      DwaltD
      DwaltD
      Dwalt
      wrote on last edited by Dwalt
      @FotoFieber
      I am curious why you cut through the existing lens of the old PIR? Could you have used that lens instead for your HC-SR501 and discarded the little dome lens?
      Nice hack! I have also seen many cheap PIR devices and am in the process of hacking mysensors into a PIR led nightlight but I am trying to cross utilize the existing PIR. Almost there...
      • FotoFieberF
        FotoFieberF
        FotoFieber
        With the next PIR device I will try to reuse the lens. Attaching the HC-SR501 is more difficult with such a setup.
        I just wanted to use a proofen design I use in other setups with my first proof of concept.
        • hautomateH
          hautomateH
          hautomate
          Nice... I'm about to mod my motion sensor flood lights in a similar manner, but will reuse the lens and also have a relay for the lighting. Then any motion sensor could trigger any number of relay-enabled lights, like if motion is detected by any sensor on the back of the house all lights on the back could power on instead of just the one that detected motion..
          • FotoFieberF
            FotoFieberF
            FotoFieber
            Second design with reusing the lens:
              DwaltD
              DwaltD
              Dwalt
              @FotoFieber
              Nice and compact! Is that your custom board?
              • FotoFieberF
                FotoFieberF
                FotoFieber
                Yes, this is a minimalistic NRF Arduion PCB:
                http://forum.mysensors.org/topic/595/pcb-boards-for-mysensors/11
