  3. Own controller
Own controller
2 Posts 2 Posters 2.0k Views 2 Watching
  • L
    L
    leothlon
    Hi.
    i am building my own HomeAutomation system with nodejs where i will controll zwave(using razberry api) 433mhz with tellstick connected to the pi.
    and now i'm also looking to implement mySensors.. so i am woundering how / if i can use mysensors with my node projekt ether directly or over mqtt ( running mosquitto broker on the raspberry ).
    Basicly... is a controller like vera for example needed or?
    If anyone got any tips or ideas id love to hear them!
    leo
    • ChaoticC
      ChaoticC
      Chaotic
      If you are running MQTT there is a gateway that supports that or if you can read serial input you could use the serial gateway.
      You would probably want to look at the Serial protocol and the Full API
