  2. Enclosures / 3D Printing
  3. Boxes and Enclosures
22 Posts 9 Posters 19.0k Views 4 Watching
    @NotYetRated
    Yeah, that little trick saves you from having to step down the voltage and leaves more space. You should easily fit the step-down, though. I'd urge you to to not even try to keep the radio wires together on the ribbon, they are quite recalcitrant when joined together.
    Noteworthy too is that I had motion sensors working on a 3.3V pin. I know they are rated something like 4V, but yeah they worked. But knowing how flakey they were, and sitting with 5V, well that's how we ended up here.
    I didn't do this, but when you are ready to build your sandwich, you may want to tack down the motion sensor with a little hot melt glue; just to hold it while you build the 'foamburger' or whatever you use to hold it in slight compression.
    have fun with it and show us your results.
    N
    N
    NotYetRated
    @BulldogLowell
    "recalcitrant" hah, nice word.
    Solder gun was acting up so I ordered a new one. Should be here tomorrow, at which time ill finish the build and let you know how things go. Planning to use some silicone caulk to hold things together inside. Non-conductive, and can be pulled apart with relative ease if needed.
    • N NotYetRated
      @BulldogLowell
      marceltrapmanM
      marceltrapmanM
      marceltrapman
      To add another option to this thread.
      I have not yet used them but I am collecting these.
      They look like they are made for these types of sensors :)
      Fulltime Servoy Developer
