  3. Binary sensor expanded help
15 Posts 4 Posters 5.8k Views 2 Watching
  • C
    C
    chuckconnors
    I've tried the binary sensor with a switch and it works great. I would like to expand this to incorporate a few more switches, but I am not sure what the best approach would be. I have tried copying portions of the code and changing variable names and almost have things working okay (debouncing acts weird), but I know my method is no very effective. I have very little experience with programming on the arduino and would appreciate some advice on what to do or where to look for help.
      mikeones
      I have been using this sketch for about a week now and it is working fine for my needs.
      // Simple binary switch example
      // Connect button or door/window reed switch between
      // digitial I/O pin 3 (ZONE_1 below) and GND.
      #include <Sensor.h>
      #include <EEPROM.h>
      #include <RF24.h>
      #include <Bounce2.h>
      #define ZONE_1  14  // Arduino Digital I/O pin for button/reed switch
      #define NUMBER_OF_ZONES 6
      Sensor gw;
      Bounce debouncer_1 = Bounce();
      Bounce debouncer_2 = Bounce();
      Bounce debouncer_3 = Bounce();
      Bounce debouncer_4 = Bounce();
      Bounce debouncer_5 = Bounce();
      Bounce debouncer_6 = Bounce();
      int oldValue_1 =-1;
      int oldValue_2 =-1;
      int oldValue_3 =-1;
      int oldValue_4 =-1;
      int oldValue_5 =-1;
      int oldValue_6 =-1;
        gw.begin();
        for (int i=0; i<NUMBER_OF_ZONES;i++) {
         // Setup the button
      	pinMode(ZONE_1+i,INPUT);
      	// Activate internal pull-up
      	digitalWrite(ZONE_1+i,HIGH);
      	switch (1+i) {
      	  case 1:
      		debouncer_1.attach(ZONE_1);
      		debouncer_1.interval(5);
      		break;
      	  case 2:
      		debouncer_2.attach(ZONE_1+i);
      		debouncer_2.interval(5);
      		break;
      	  case 3:
      		debouncer_3.attach(ZONE_1+i);
      		debouncer_3.interval(5);
      		break;
      	  case 4:
      		debouncer_4.attach(ZONE_1+i);
      		debouncer_4.interval(5);
      		break;
      	  case 5:
      		debouncer_5.attach(ZONE_1+i);
      		debouncer_5.interval(5);
      		break;
      	// If S_LIGHT is used, remember to update variable type you send in below.
      	gw.sendSensorPresentation(ZONE_1+i, S_DOOR);
      	delay(1000);
      	int num = 1+i;
      	// Get the update value
      	switch (num) {
      	  case 1:
      		  debouncer_1.update();
      		  int value_1 = debouncer_1.read();
      		  if (value_1 != oldValue_1) {
      		   // Send in the new value
      		   gw.sendVariable(ZONE_1+i, V_TRIPPED, value_1==HIGH ? "1" : "0");  // Change to V_LIGHT if you use S_LIGHT in presentation above
      		   oldValue_1 = value_1;
      		  break;
      	  case 2:
      		  debouncer_2.update();
      		  int value_2 = debouncer_2.read();
      		  if (value_2 != oldValue_2) {
      		   gw.sendVariable(ZONE_1+i, V_TRIPPED, value_2==HIGH ? "1" : "0");  // Change to V_LIGHT if you use S_LIGHT in presentation above
      		   oldValue_2 = value_2;
      		  break;
      	  case 3:
      		  debouncer_3.update();
      		  int value_3 = debouncer_3.read();
      		  if (value_3 != oldValue_3) {
      		   gw.sendVariable(ZONE_1+i, V_TRIPPED, value_3==HIGH ? "1" : "0");  // Change to V_LIGHT if you use S_LIGHT in presentation above
      		   oldValue_3 = value_3;
      		  break;
      	  case 4:
      		  debouncer_4.update();
      		  int value_4 = debouncer_4.read();
      		  if (value_4 != oldValue_4) {
      		   gw.sendVariable(ZONE_1+i, V_TRIPPED, value_4==HIGH ? "1" : "0");  // Change to V_LIGHT if you use S_LIGHT in presentation above
      		   oldValue_4 = value_4;
      		  break;
      	  case 5:
      		  debouncer_5.update();
      		  int value_5 = debouncer_5.read();
      		  if (value_5 != oldValue_5) {
      		   gw.sendVariable(ZONE_1+i, V_TRIPPED, value_5==HIGH ? "1" : "0");  // Change to V_LIGHT if you use S_LIGHT in presentation above
      		   oldValue_5 = value_5;
      		  break;
      	  case 6:
      		  debouncer_6.update();
      		  int value_6 = debouncer_6.read();
      		  if (value_6 != oldValue_6) {
      		   gw.sendVariable(ZONE_1+i, V_TRIPPED, value_6==HIGH ? "1" : "0");  // Change to V_LIGHT if you use S_LIGHT in presentation above
      		   oldValue_6 = value_6;
      		break;
      • C
        C
        chuckconnors
        wrote on last edited by chuckconnors
        Thanks Mikeones! I will try it out. I do have one question though. You seem to be setting all pins based on ZONE_1 variable, correct? So you would be using pins 14-19 for your input? Shouldn't ZONE_1 be set to 3 to use pins 3-8? Again, I am totally new so maybe I'm looking at it wrong. I am using a nano if that makes a difference.
        M 1 Reply Last reply
        • C chuckconnors
          mikeones
          @chuckconnors
          I have this on a nano also but the only open pins I have left are analog. That is why I started at ping 14.
          C 1 Reply Last reply
          • M mikeones
            @chuckconnors
            C
            C
            chuckconnors
            @mikeones Oh, okay.. That makes sense. Are you using any resistors with your switches or are you using just the switches?
            • C
              C
              chuckconnors
              Wow. It's been two years since I've visited this. At any rate. I'm trying to update to the latest mysensors version and am running into an issue. I've used the binary sensor as a base but I'm pretty sure that I'm doing something wrong. Here's the code I'm trying to use:
              #define ZONE_1  3  // Arduino Digital I/O pin for button/reed switch
              int oldValue_1 =-1;
              int oldValue_2 =-1;
              int oldValue_3 =-1;
              int oldValue_4 =-1;
              int oldValue_5 =-1;
              int oldValue_6 =-1;
                gw.begin();
                 // Setup the button
                  MyMessage msg(ZONE_1+i,V_TRIPPED);
                    switch (1+i)
                    case 1:
                      break;
                    case 2:
                      break;
                    case 3:
                      break;
                    case 4:
                      break;
                    case 5:
                      break;
                gw.present(ZONE_1+i, S_DOOR);
                delay(1000);
                  int num = 1+i;
                  switch (num)
                    case 1:
                         gw.send(msg.setSensor(ZONE_1+i).set(value_1==HIGH ? 1 : 0));
                        break;
                    case 2:
                         gw.send(msg.setSensor(ZONE_1+i).set(value_2==HIGH ? 1 : 0));
                        break;
                    case 3:
                         gw.send(msg.setSensor(ZONE_1+i).set(value_3==HIGH ? 1 : 0));
                        break;
                    case 4:
                        gw.send(msg.setSensor(ZONE_1+i).set(value_4==HIGH ? 1 : 0));
                        break;
                    case 5:
                         gw.send(msg.setSensor(ZONE_1+i).set(value_5==HIGH ? 1 : 0));
                        break;
                    case 6:
                         gw.send(msg.setSensor(ZONE_1+i).set(value_6==HIGH ? 1 : 0));
                      break;
              When I try to compile I get this error:
              Arduino: 1.6.6 (Windows 7), Board: "Arduino/Genuino Uno"
              Warning: platform.txt from core 'MySensors AVR based boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
              WARNING: Category '' in library UIPEthernet is not valid. Setting to 'Uncategorized'
              C:\Users\User\Documents\Arduino\alarm\alarm.ino: In function 'void loop()':
              alarm:118: error: 'msg' was not declared in this scope
              alarm:129: error: 'msg' was not declared in this scope
              alarm:140: error: 'msg' was not declared in this scope
              alarm:151: error: 'msg' was not declared in this scope
              alarm:162: error: 'msg' was not declared in this scope
              alarm:173: error: 'msg' was not declared in this scope
              exit status 1
              I'm guessing it's a syntax error but I'm having trouble trying to format it correctly. I'm a hacker not a programmer so any help would be most appreciated! Thanks
              • S
                salvato
                I think that your problem is that you are using a "variable" (msg) that you never declare.
                C++ requires that every variable used MUST have a type and be declared in advance.
                Inserting a declaration:
                MyMessage msg;
                should fix your problem. Let us know.
                Ciao
                • C
                  C
                  chuckconnors
                  Thanks for the advice. I did have the variable declared as:
                  but it's quite possible that I'm doing that wrong. I tried changing it to your version and I get the same error.
                  I'm very excited to get this working but am so in the dark when it comes to actual programming. I appreciate any help you guys can give to get this thing running finally.
                    You are declaring msg inside a for loop. It will not live outside the scope of that for loop. You need to declare it globally (=outside any function) to make it available inside the loop() and setup() functions.
                    Since you are using multiple messages, an array makes sense. See line 20 in this code
                    for an example.
                    You can convert the debouncer_Ns and oldvalue_Ns to arrays in a similar manner, making your code much neater (no need for the long switch statement for example).
                    • C
                      C
                      chuckconnors
                      Thank you for taking the time to help. Unfortunately I'm more of hacker than a programmer. I understand what you are saying about making the message a global, but I don't know exactly how to accomplish it. I tried to just force it like this:
                      MyMessage msg(1,V_TRIPPED);
                      MyMessage msg(2,V_TRIPPED);
                      MyMessage msg(3,V_TRIPPED);
                      MyMessage msg(4,V_TRIPPED);
                      MyMessage msg(5,V_TRIPPED);
                      MyMessage msg(6,V_TRIPPED);
                      but that did not work. Also, I do understand using an array would clean things up a bit but I'd like to get it working in this basic format first then work on refining it. Thanks again.
                      • C
                        C
                        chuckconnors
                        Thanks for the help again. I think I have something working. Could definitely use some help cleaning it up though:
                        #define round(x) ((x)>=0?(long)((x)+0.5):(long)((x)-0.5))
                        #define SLEEP_TIME 600000 // Sleep time between reads (in milliseconds)
                        #define STABILIZATION_TIME 500 // Let the sensor stabilize 0.5 seconds before reading
                        const int SENSORS[] = {3,4,5,6,7,8}; // Remove the pins that you don't want to use
                        #define N_ELEMENTS(array) (sizeof(array)/sizeof((array)[0]))
                        int oldValue_1 =-1;
                        int oldValue_2 =-1;
                        int oldValue_3 =-1;
                        int oldValue_4 =-1;
                        int oldValue_5 =-1;
                        int oldValue_6 =-1;
                        MyMessage button_messages[N_ELEMENTS(SENSORS)];
                          gw.begin();
                          for (int sensor = 0; sensor < N_ELEMENTS(SENSORS); sensor++) {
                            button_messages[sensor].sensor = sensor + 1; // Battery uses child ID 0 so sensors start at 1
                            button_messages[sensor].type = V_TRIPPED;
                            delay(250);
                            gw.present(sensor + 1, S_DOOR);
                          for (int i = 0; i < N_ELEMENTS(SENSORS); i++) {
                            pinMode(SENSORS[i], INPUT);
                            digitalWrite(SENSORS[i], HIGH);
                            switch (1+i)
                              case 1:
                                debouncer_1.attach(SENSORS[i]);
                                break;
                              case 2:
                                debouncer_2.attach(SENSORS[i]);
                                break;
                              case 3:
                                debouncer_3.attach(SENSORS[i]);
                                break;
                              case 4:
                                debouncer_4.attach(SENSORS[i]);
                                break;
                              case 5:
                                debouncer_5.attach(SENSORS[i]);
                                break;
                              case 6:
                                debouncer_6.attach(SENSORS[i]);
                                debouncer_6.interval(5);
                                break;
                                int num = 1+sensor;
                            switch (num)
                              case 1:
                                   gw.send(button_messages[sensor].set(value_1==HIGH ? 1 : 0));
                                   Serial.print("Switch 1=");
                                   Serial.println(value_1);
                                  break;
                              case 2:
                                   gw.send(button_messages[sensor].set(value_2==HIGH ? 1 : 0));
                                   Serial.print("Switch 2=");
                                   Serial.println(value_2);
                                  break;
                              case 3:
                                   gw.send(button_messages[sensor].set(value_3==HIGH ? 1 : 0));
                                   Serial.print("Switch 3=");
                                   Serial.println(value_3);
                                  break;
                              case 4:
                                   gw.send(button_messages[sensor].set(value_4==HIGH ? 1 : 0));
                                   Serial.print("Switch 4=");
                                   Serial.println(value_4);
                                  break;
                              case 5:
                                   gw.send(button_messages[sensor].set(value_5==HIGH ? 1 : 0));
                                   Serial.print("Switch 5=");
                                   Serial.println(value_5);
                                  break;
                              case 6:
                                   gw.send(button_messages[sensor].set(value_6==HIGH ? 1 : 0));
                                   Serial.print("Switch 6=");
                                   Serial.println(value_6);
                                break;
                          Great work! I'll see if I can help you with the cleanup tomorrow.
                          • C
                            C
                            chuckconnors
                            That would be great. Thanks for the push in the right direction.. I'm about to connect it to the alarm wires!
                              Something like this should work. Note: I haven't tested the code, but it compiles and I think it does the same as your old code.
                              const int SENSORS[] = {3, 4, 5, 6, 7, 8}; // Remove the pins that you don't want to use
                              Bounce debouncers[N_ELEMENTS(SENSORS)];
                              int oldValues[N_ELEMENTS(SENSORS)];
                                gw.begin();
                                  debouncers[sensor] = Bounce();
                                  oldValues[sensor] = -1;
                                  delay(250);
                                  pinMode(SENSORS[sensor], INPUT);
                                  digitalWrite(SENSORS[sensor], HIGH);
                                  debouncers[sensor].attach(SENSORS[sensor]);
                                  debouncers[sensor].interval(5);
                                  int num = 1 + sensor;
                                  debouncers[num].update();
                                  int value = debouncers[num].read();
                                  if (value != oldValues[num]) {
                                    gw.send(button_messages[sensor].set(value == HIGH ? 1 : 0));
                                    Serial.print("Switch ");
                                    Serial.print(num);
                                    Serial.print(" =");
                                    Serial.println(value);
                                    oldValues[num] = value;
                              • C
                                C
                                chuckconnors
                                Much cleaner! I'll give it a go soon. Thanks for all the help!
