  3. Combine PIR, relay, distance and gas sensors
7 Posts 4 Posters 5.0k Views 2 Watching
    miremi
    wrote on last edited by miremi
    Hi everyone,
    I'm trying to combine 3 relays, PIR, gas and distance sensors together for my kitchen but i have no luck already spend 3 days on but nothing works.
    Can someone help me please? Gas sensor is not necessary
    Using: mysensors 1.4
    Controller: Domoticz
    Everything separately working fine but not together.
    Here is my code with 3 relays, pir and distance sensors
    #include <NewPing.h>
    #define CHILD_ID 8
    #define TRIGGER_PIN  8  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define ECHO_PIN     7  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
    unsigned long SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds)
    #define MOTOIN_INPUT_SENSOR 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 3 // Total number of attached relays
    #define RELAY_ON 0  // GPIO value to write to turn on attached relay
    #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
    #define MOTION_CHILD_ID 5   // Id of the sensor child
    #define RELAY_CHILD_ID 1   // Id of the sensor child
    boolean lastMotion = false;
    NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    MyMessage msgdist(MOTION_CHILD_ID, V_TRIPPED);
    MyMessage msg(CHILD_ID, V_DISTANCE);
    int lastDist;
    boolean metric = true;
      gw.sendSketchInfo("Zet", "1.0");
      gw.present(CHILD_ID, S_DISTANCE);
      boolean metric = gw.getConfig().isMetric;
      pinMode(MOTOIN_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as input
      gw.present(MOTION_CHILD_ID, S_MOTION);
      // Fetch relay status
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      int dist = metric?sonar.ping_cm():sonar.ping_in();
      Serial.print("Ping: ");
      Serial.print(dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
      Serial.println(metric?" cm":" in");
      if (dist != lastDist) {
          gw.send(msg.set(dist));
          lastDist = dist;
      gw.process();
      // Read digital motion value
      boolean motion = digitalRead(MOTOIN_INPUT_SENSOR) == HIGH;
      if (lastMotion != motion) {
        lastMotion = motion;
        gw.send(msg.set(motion ? "1" : "0" ));  // Send motion value to gw
      gw.sleep(SLEEP_TIME);
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    LOG from serial monitor:
    repeater started, id 1
    send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
    send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
    read: 0-0-1 s=255,c=3,t=6,pt=0,l=1:M
    send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=3,st=ok:Zet
    send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
    send: 1-1-0-0 s=8,c=0,t=15,pt=0,l=5,st=ok:1.4.1
    send: 1-1-0-0 s=5,c=0,t=1,pt=0,l=5,st=ok:1.4.1
    send: 1-1-0-0 s=1,c=0,t=3,pt=0,l=5,st=ok:1.4.1
    send: 1-1-0-0 s=2,c=0,t=3,pt=0,l=5,st=ok:1.4.1
    send: 1-1-0-0 s=3,c=0,t=3,pt=0,l=5,st=ok:1.4.1
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Ping: 0 cm
    Any help?
    RJ_MakeR 1 Reply Last reply
    • S
      stephenmhall
      I would try getting rid of the sleep time and use a timer function to call the motion detection every 5 seconds. As noting else can happen during sleep.
      • M miremi
        Hi everyone,
        #define CHILD_ID 8
        int lastDist;
              lastDist = dist;
          gw.process();
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Ping: 0 cm
        Any help?
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @miremi I think @stephenmhall is right on the money.
        Get rid of the sleep function all together, and run "full tilt boggy" to see what happens (don't try activating any of the relays).
        Did I miss the gas code??
        If PIR, and Distance works, then add in a interval to slow things down.
        RJ_Make
          miremi
          @stephenmhall How can i do that?
          @ServiceXp I don't have the knowledge of arduino programming to do that :( i just started 2 days ago with arduino for dummies.
          Can you help me with this one?
          I didn't include gas code yet because i was thinking let the firs three work and than gas sensor.
          • S
            stephenmhall
            Okydoky
            here is some of my code from a combined temp/humidity sensor a relay and a button to trigger the relay locally. Hopefully you can put your code together with it.
            First I do some variable setup. the gap between checks (30 seconds) and millis() gives time in unix time.
            unsigned long CHECK_TIME = millis();
            in the void loop I have the gw.process() and code to check for the button being pressed and also a timer that calls the function to check the sensors. It gets the current time, subtracts the old time from it and if the difference is greater than the SLEEP_TIME it calls the check function.
              gw.process();
              debouncer.update();
              // Get the update value
              int value = debouncer.read();
              if (value != oldValue && value==0) {
                  gw.send(msgRelay.set(state?false:true), true); // Send new state and request ack back
              oldValue = value;
              // Check Temp and Humidity sensor every set ammount of time
              unsigned long NOW_TIME = millis();
              if(NOW_TIME - CHECK_TIME >= SLEEP_TIME) {
                getTemps();
                CHECK_TIME = NOW_TIME;
            Here is the function to read the temps, this goes below the void loop. You probably have the void incommingMesage function for MySensors, it can go above or below that.
            void getTemps(){
              if (isnan(temperature)) {
                lastTemp = temperature;
                if (!metric) {
                Serial.print("T: ");
                Serial.println(temperature);
              if (isnan(humidity)) {
                  lastHum = humidity;
                  Serial.print("H: ");
                  Serial.println(humidity);
            this does the work of checking the sensors and updating the gateway if the readings have changed.
            This way it is always checking for the button being pressed, and only checking the sensors every 30 seconds, with no sleeptime. Probably not great if on batteries but that's another problem. My Arduino kung-fu is not super strong, I suspect you can set up interrupts and stuff to allow for sleeptime but that is beyond me currently.
              miremi
              @stephenmhall thank for your help.
              Still no luck. Pir and distance sensors working but relay doesn't wont to work.
              • rvendrameR
                rvendrameR
                rvendrame
                What happens when you add the relay? Only the relay does not obey, or the pir/dist stop too? What do you get in serial monitor?
                ESP8266 GW + mySensors 2.3.2
                Alexa / Google Home
