  3. Cannot remotely reboot a node
3 Posts 2 Posters 3.3k Views 1 Watching
  • C
    C
    coldpower
    First of all - thanks a lot for the beatiful library!
    Here is my issue.
    Cannot restart node using MYSController_0_1_2_280.
    Is it only me who has such issue? Where to look in order to find source?
    Here is what i have done:
    • there is serial gateway connected to the computer and one node
    • added section to my arduino ide boards.txt
    • burned MYSBootloader.hex which came with MYSController as a bootloader
    • have uploaded DallasTemperatureSensor example to the node.
    • it seems working fine and sends data to the controlloer
    • it also gets some packets back from the controller;
    • made a minor modification to it to make it sending temperature every 10 seconds even if temperature was not changed and indicate (just print 'starting') the reboot;
    • it seems reporting fine to MYSController;
    • trying to reboot node from the MYSController, i.e. right click node -> click at 'reboot' menu item;
    • node does not restart and continue working;
    I tried to use bootloaders from the MySensor git repository (either Bootloader and MYSBootloader), but result is the same.
    Thanks a lot for the advice!
    tekkaT 1 Reply Last reply
    • C coldpower
      Here is my issue.
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      @coldpower
      The node is sleeping during the majority of the time and doesn't process incoming commands.
      Substituting gw.sleep() with gw.wait() should do the trick (gw.wait() calls gw.process() while waiting).
      A second option for battery-powered sensors that saves battery life:
      • add gw.wait(200) after the last send command and keep gw.sleep()
      • in MYSController, select Battery powered in node properties
      What happens now: The node listens during 200ms for incoming commands and then goes to sleep. MYSController will send commands once it receives a message from the node.
      • C
        C
        coldpower
        I did not realize that sample is for battery powered node. Now it works fine, thank you for the advice!
