  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 675.9k Views 99 Watching
  • marceltrapmanM marceltrapman
    @azuntik You should know what you are creating ;)
    In PaperUI you first create a thing for the gateway (I assume that worked for you).
    Next OpenHAB should find all attached things for you, no need to create them manually. Just confirm what OpenHAB found.
    Based on available properties you create an Item.
    A
    A
    azuntik
    wrote on last edited by azuntik
    #381
    @marceltrapman Frankenstein's Monster? :D
    So, the UI is not detecting anything, although testing mysgw shows it receiving data. Is this a misconfiguration on my part?
    Edit: Nevermind. I think what you said just sank in. Thanks for your help!
    • N
      N
      nikos1671
      Hi TimO
      Can you please add support for gas meter S_GAS like the water meter.
      Nikos
      S 1 Reply Last reply
      • D
        D
        David Link
        Hello all! I believe I have done my due diligence in solving my own problem, but I am stuck. Can anyone point me in the right direction?
        I am trying to get started with an Ethernet Gateway. The gateway is displayed on the PaperUI, but in the log, it continues to try and connect to the ip bridge (Sending to MySensors: 0;0;3;0;2;)
        I am on:
        openhab 2.1.0-snapshot build #791
        MySensors Binding: 2.0.0.201701181308
        Gateway is using library 2.1.1
        I have tried:
        Clearing the EEPROM on the gateway thinking some garbage got stuck there.
        Set up and successfully used an MQTT gateway, thinking bad hardware?
        Restarted the binding, openhab, kitchen sink countless times.
        Updating everything to the latest build I could find
        Manually creating things
        The only thing that seems odd to me is the gateway repeats over and over what appears to be initialization data (displays ip address, 0;255;3;0;9;MC0;BGN;STP.....). However, it does receive data from a temperature node I built.
        I appreciate any pointers that can be provided, including "have you read this page?", though I think my Google search is permanently stuck on "mysensors openhab" at this point.
        Thanks,
        Dave
        T A 2 Replies Last reply
        • N nikos1671
          Hi TimO
          Nikos
          stoffej
          @nikos1671
          Where do I found the Mysensors Binding 2.0.0.201701181308 jar file for download?
          Or is it mandatory to compile it from source?
          Thanks Kristoffer
          T 1 Reply Last reply
          • D David Link
            I am on:
            I have tried:
            Thanks,
            Dave
            TimO
            @David-Link Are you sure the gateway isn't in a boot loop?
            D 1 Reply Last reply
            • S stoffej
              @nikos1671
              Thanks Kristoffer
              TimO
              @stoffej HERE
              • T TimO
                D
                D
                David Link
                @TimO That's exactly what is going on. Thank you for the tip, I was pulling my hair out. Now on to solving that problem! Thanks again.
                  mlava
                  Hi @TimO
                  I am having trouble but think I might be doing it wrong.
                  Is it possible to use this binding with a MQTT gateway?
                  I see that it needs to find the gateway on port 5003 but this isn't defined in MQTT gateway.
                  Is it possible?
                  • M mlava
                    Hi @TimO
                    Is it possible?
                    TimO
                    Hi @mlava !
                    The MQTT gateway is not supported at the moment. I've done a proof of concept and it will be implemented after the refactoring we're currently working on.
                    M 1 Reply Last reply
                    • T TimO
                      Hi @mlava !
                      mlava
                      @TimO
                      Wonderful, thank you for the answer.
                      I'll wait eagerly for progress! 😀
                      • D David Link
                        I am on:
                        I have tried:
                        Thanks,
                        Dave
                        A
                        A
                        Andrew Currie
                        @David-Link It looks like you have a similar issue to me re the ethernet gateway. I have also tried "everything" and then yesterday discovered an old bug that might have resurfaced. I just put the following up on github:
                        https://github.com/mysensors/MySensors/issues/777
                        It might help you..
                        • A
                          A
                          Andrew Currie
                          Further to my client ethernet gateway not working with the MySensors 2.1.1 library, I tried 2.0.0 and now go much further. The gateway does not keep restarting, talks to the openhab controller and at least reads the messages and tripped status from my motion sensor
                          0;255;3;0;9;TSM:INIT
                          0;255;3;0;9;TSM:RADIO:OK
                          0;255;3;0;9;TSM:GW MODE
                          0;255;3;0;9;TSM:READY
                          IP: 192.168.1.9
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                          0;255;3;0;9;TSP:SANCHK:OK```
                          I had to turn on the skipStartupCheck for the ethernet gateway to come online in openhab (and the gateway serial monitor did show the 0;0;3;0;2; and ethernet messages between openhab and the gateway)
                          15:10:13.316 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.1.9:5003]
                          15:10:13.819 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                          15:10:14.320 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                          15:10:15.320 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                          15:10:16.320 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                          15:10:17.321 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                          15:10:18.321 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Cannot start reading/writing thread, probably sync message (I_VERSION) not received. Try set skipStartupCheck to true
                          15:10:18.322 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:1)
                          15:10:18.322 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Disconnecting from IP bridge ...
                          15:10:18.323 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Stopping Writer thread
                          15:10:18.324 [DEBUG] [rs.internal.protocol.MySensorsReader] - Stopping Reader thread
                          15:10:18.324 [ERROR] [rs.internal.protocol.MySensorsWriter] - (java.lang.InterruptedException) on writing to connection, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorsIpWriter
                          15:10:18.325 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.InterruptedException: sleep interrupted) on reading from connection, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorIpReader
                          15:10:25.236 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Disposing of the MySensors bridge
                          15:10:25.236 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Destroying connection
                          15:10:25.236 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                          15:10:25.237 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [1]
                          15:10:25.237 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [1]
                          15:10:25.239 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                          15:10:25.239 [INFO ] [smarthome.event.ThingUpdatedEvent   ] - Thing 'mysensors:bridge-eth:cb1d6dd1' has been updated.
                          15:10:25.240 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Set skip check on startup to: true
                          15:10:25.240 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Enabling connection watchdog
                          15:10:25.240 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                          15:10:25.241 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.1.9:5003]
                          15:10:25.241 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [1]
                          15:10:25.241 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                          15:10:25.244 [WARN ] [al.protocol.ip.MySensorsIpConnection] - Skipping I_VERSION connection test, not recommended...
                          15:10:25.244 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                          I then got my motion sensor to come online in openhab
                          15:13:24.300 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: nodeId 1, chiledId: 1, requestAck: false, revertState: false, smartSleep: false
                          15:13:24.301 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 1-1 not registered yet, registering...
                          15:13:24.305 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:motion:24559d07' changed from INITIALIZING to ONLINE```
                          However the motion sensor (via gateway) and openhab controller are not talking to each other. Does skipping the startup check result in problems?
                          Any ideas on how to progress with MySensors 2.0.0 library or do I need to wait for a fix to 2.1.1?
                          Many Thanks...
                          • A Andrew Currie
                            It might help you..
                            D
                            D
                            David Link
                            @Andrew-Currie I think that is the same thing I am dealing with. I will take a look, thank you!
                            I "cheated" and just hooked it up to my Pi that is running OpenHab and it works like a charm.
                            • A Andrew Currie
                              IP: 192.168.1.9
                              Many Thanks...
                              TimO
                              @Andrew-Currie It should make no difference for the binding if you're using 2.0.0 or 2.1.1. I can't see any incoming messages in the debug log you've posted. If the gateway is properly connected you should see messages incoming, for example from your motion sensor. Could you please establish a telnet connection to the gateway at port 5003 and post the output? In parallel check the serial output of the gateway, there you should see the establishment of the telnet connection for example.
                              A 1 Reply Last reply
                              • T TimO
                                A
                                A
                                Andrew Currie
                                @TimO Thanks Tim for your feedback. Here is the log from the gateway. It receives messages from openhab re the ethernet connection and also from the motion sensor and gets a fail from one send
                                IP: 192.168.1.9
                                0;255;3;0;9;Eth: connect
                                0;255;3;0;9;Eth: 0;0;3;0;2;
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;Eth: disconnect
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;Eth:
                                0;255;3;0;9;TSP:MSG:READ 1-1-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                0;255;3;0;9;TSP:MSG:BC
                                0;255;3;0;9;TSP:MSG:FPAR REQ (sender=1)
                                0;255;3;0;9;TSP:CHKUPL:OK
                                0;255;3;0;9;TSP:MSG:GWL OK
                                0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                                0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                0;255;3;0;9;TSP:MSG:PINGED (ID=1, hops=1)
                                0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                                0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                0;255;3;0;9;!TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
                                0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor
                                0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                                0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=0,t=1,pt=0,l=0,sg=0:
                                0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                                The telnet connection shows no action and the gateway device is on the local network
                                $ telnet 192.168.1.9 5003
                                Trying 192.168.1.9...
                                Connected to 192.168.1.9.
                                Escape character is '^]'.
                                $ arp -a
                                HPB482AF (192.168.1.2) at 28:92:4a:c0:c3:27 [ether] on wlan0
                                WIZnet9FFEED (192.168.1.9) at de:ad:b1:9f:fe:ed [ether] on wlan0
                                NB604N.Home (192.168.1.1) at 00:60:64:83:50:8b [ether] on wlan0
                                HF-LPB100 (192.168.1.12) at f0:fe:6b:16:a1:4a [ether] on wlan0
                                I have tried all sorts of ubuntu firewall settings to allow access to and from 192.168.1.9 port 5003 and also looked into the router settings with no joy.
                                As another approach I tried the serial gateway and investigated the linux settings given in
                                http://docs.openhab.org/installation/linux.html#privileges-for-common-peripherals
                                The furthest I got with the serial gateway was as follows, first the debug log at startup and then when creating the gateway thing in the paper ui
                                10:07:04.218 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.mysensors.internal.factory.MySensorsHandlerFactory, component.id=197, service.id=340, service.bundleid=250, service.scope=bundle} - org.openhab.binding.mysensors
                                10:07:04.219 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTED – org.openhab.binding.mysensors
                                10:08:52.520 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=341, service.bundleid=250, service.scope=singleton} – org.openhab.binding.mysensors
                                10:08:52.524 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                                10:08:52.526 [DEBUG] [col.serial.MySensorsSerialConnection] - Set skip check on startup to: false
                                10:08:52.526 [DEBUG] [col.serial.MySensorsSerialConnection] - Enabling connection watchdog
                                10:08:52.527 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to ttyUSB1 [baudRate:115200]
                                10:08:52.530 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                                10:08:52.531 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
                                10:08:52.532 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                                testRead() open failed: /dev/ttyUSB1
                                localClose: File Descriptor error, not closing
                                10:08:52.545 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: ttyUSB1:/dev/ttyUSB1
                                testRead() open failed: ttyUSB1
                                Failed to connect on port: ttyUSB1 exception:
                                gnu.io.NoSuchPortException
                                While my plan was to test on my ubuntu 16.04 laptop, I have gone ahead and ordered a Raspberry pi 3 and intend to install the openhabianpi img file. Hopefully better progress there...
                                • B
                                  B
                                  balder88
                                  Hey guys, first message on this forum. Been reading alot before. But now I have a problem I just can't solve.
                                  It's about smartsleep with openhab 2.
                                  Im using wifi gw rfm 69.
                                  Regular messages works as it should both ways.
                                  But it almost seems like the smartsleep isn't enabled in the binding.
                                  Here are my configs and logs.
                                  Things file:
                                  Bridge mysensors:bridge-eth:gw69 [ ipAddress="192.168.1.235", tcpPort=5003, sendDelay=100, enableNetworkSanCheck=true ] {
                                  //  Anarduino
                                      humidity        AnHum   [ nodeId="66", childId="0" ]
                                      temperature     AnTemp  [ nodeId="66", childId="1" ]
                                      light           light02 [ nodeId="66", childId="3", smartSleep=true ]
                                  Items file:
                                  Switch  TestLight   "Test lampa" (Test) { channel="mysensors:light:gw69:light02:status" }
                                  Sketch: (Cleaned up the parts that dont matter, RTC and so on.)
                                  #define MY_RADIO_RFM69
                                  #define MY_IS_RFM69HW
                                  #define MY_NODE_ID 66
                                  #define MY_RFM69_NETWORKID 100
                                  #define MY_SMART_SLEEP_WAIT_DURATION_MS 1000
                                  #include <TimeLib.h>
                                  #include <Wire.h>
                                  #include <MCP7940RTC.h>
                                  #include <DHT.h>
                                  #define MCP7940_CTRL_ID 0x6F
                                  #define CSMEM_PIN 5
                                  #define LEDPIN 9
                                  long sleepIntervalSec=5;
                                  long loopCnt=0;
                                  uint8_t d[8];
                                  uint8_t dAlarm[8];
                                  int d1[8];
                                  #define DHT_DATA_PIN 6
                                  #define SENSOR_TEMP_OFFSET 0
                                  static const uint64_t UPDATE_INTERVAL = 5000;
                                  #define CHILD_ID_HUM 0
                                  #define CHILD_ID_TEMP 1
                                  #define CHILD_ID_MULTIMETER 2
                                  float lastTemp;
                                  float lastHum;
                                  uint8_t nNoUpdatesTemp;
                                  uint8_t nNoUpdatesHum;
                                  bool metric = true;
                                  MyMessage msgVolt(CHILD_ID_MULTIMETER, V_VOLTAGE);
                                  DHT dht;
                                  int oldBatteryPcnt = 0;
                                  int batteryBasement = 812;
                                  int batteryFull = 922;
                                  float batteryConstant = 100.0 / (batteryFull - batteryBasement);
                                  float lastbatteryV = 0;
                                  const int buzzer = 7; //buzzer to arduino pin 7
                                  #define RELAY_1  8  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                  void before()
                                    for (int sensor=3, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
                                      pinMode(pin, OUTPUT);
                                     analogReference(INTERNAL);
                                    pinMode(LEDPIN, OUTPUT);
                                    digitalWrite(LEDPIN, LOW);
                                    Wire.begin();
                                    pinMode(CSMEM_PIN, OUTPUT);
                                    digitalWrite(CSMEM_PIN, HIGH);
                                    sleepIntervalSec = dht.getMinimumSamplingPeriod();
                                    clearAlarm();
                                    delay(20);
                                    setNewAlarm();
                                    analogRead(BATTERY_SENSE_PIN);
                                  void presentation() {
                                     sendSketchInfo("Humidity sensor", "1.0");
                                     present(CHILD_ID_MULTIMETER, S_MULTIMETER, "VOLT", true);
                                     present(CHILD_ID_HUM, S_HUM, "HUMIDITY", true);
                                     present(CHILD_ID_TEMP, S_TEMP, "TEMP", true);
                                      present(sensor, S_BINARY);
                                    wait(100);
                                     #ifdef MY_DEBUG
                                     Serial.println(sensorValue);
                                     float batteryV  = sensorValue * 0.004551646;
                                     if(sensorValue < batteryBasement) {
                                      sensorValue = batteryBasement;
                                      batteryV = 0;
                                     else if (sensorValue > batteryFull) {
                                      sensorValue = batteryFull;
                                     int batteryPcnt = (sensorValue - batteryBasement) * batteryConstant;
                                         if ((abs(oldBatteryPcnt - batteryPcnt) > 1)) {
                                        oldBatteryPcnt = batteryPcnt;
                                     if(batteryV != lastbatteryV) {
                                     send(msgVolt.set(batteryV, 2));
                                     lastbatteryV = batteryV;
                                     #ifdef MY_DEBUG
                                     Serial.print(batteryV);
                                     Serial.println(" V");
                                     Serial.print(batteryPcnt);
                                     Serial.println(" %");
                                    dht.readSensor(true);
                                    if (isnan(temperature)) {
                                      lastTemp = temperature;
                                      if (!metric) {
                                      // Reset no updates counter
                                      nNoUpdatesTemp = 0;
                                      #ifdef MY_DEBUG
                                      Serial.print("T: ");
                                      Serial.println(temperature);
                                    } else {
                                      nNoUpdatesTemp++;
                                    if (isnan(humidity)) {
                                      lastHum = humidity;
                                      nNoUpdatesHum = 0;
                                      #ifdef MY_DEBUG
                                      Serial.print("H: ");
                                      Serial.println(humidity);
                                    } else {
                                      nNoUpdatesHum++;
                                  long sleepTime = UPDATE_INTERVAL;
                                  if (batteryPcnt < 50) {
                                    sleepTime = (sleepTime * 2);
                                    sleepIntervalSec = sleepTime / 1000;
                                    Serial.println();
                                    Serial.print("Setting new sleep time: ");
                                    Serial.print(sleepIntervalSec);
                                    Serial.println(" seconds.");
                                    clearAlarm();
                                    delay(20);
                                    setNewAlarm();
                                    smartSleep(sleepTime);
                                    if (message.type==V_STATUS) {
                                      // Change relay state
                                      // Store state in eeprom
                                      // Write some debug info
                                      Serial.print(message.sensor);
                                  Sensor startup:
                                  0 MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.1.1
                                  3 MCO:BGN:BFR
                                  4 TSM:INIT
                                  5 TSF:WUR:MS=0
                                  8 TSM:INIT:TSP OK
                                  9 TSM:INIT:STATID=66
                                  11 TSF:SID:OK,ID=66
                                  13 TSM:FPAR
                                  143 TSF:MSG:SEND,66-66-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  524 TSF:MSG:READ,0-0-66,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                  529 TSF:MSG:FPAR OK,ID=0,D=1
                                  2150 TSM:FPAR:OK
                                  2151 TSM:ID
                                  2152 TSM:ID:OK
                                  2154 TSM:UPL
                                  2161 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  2181 TSF:MSG:READ,0-0-66,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                  2186 TSF:MSG:PONG RECV,HP=1
                                  2189 TSM:UPL:OK
                                  2190 TSM:READY:ID=66,PAR=0,DIS=1
                                  2199 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                  2253 TSF:MSG:READ,0-0-66,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                  2310 TSF:MSG:SEND,66-66-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                                  2366 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  2403 TSF:MSG:READ,0-0-66,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                  2461 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=OK:Humidity sensor
                                  2562 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                                  2618 TSF:MSG:SEND,66-66-0-0,s=2,c=0,t=30,pt=0,l=4,sg=0,ft=0,st=OK:VOLT
                                  2757 !TSF:MSG:SEND,66-66-0-0,s=0,c=0,t=7,pt=0,l=8,sg=0,ft=0,st=NACK:HUMIDITY
                                  2777 TSF:MSG:SEND,66-66-0-0,s=1,c=0,t=6,pt=0,l=4,sg=0,ft=1,st=OK:TEMP
                                  2912 !TSF:MSG:SEND,66-66-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=NACK:
                                  2918 MCO:REG:REQ
                                  2974 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                                  2991 TSF:MSG:READ,0-0-66,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                  2996 MCO:PIM:NODE REG=1
                                  2999 MCO:BGN:STP
                                  3154 MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  3160 MCO:SLP:TPD
                                  3161 MCO:SLP:WUP=-1
                                  3163 MCO:BGN:INIT OK,TSP=1
                                  Log Sensor: (This is when I press the button when the sensor is awake)
                                  It's sends away it's heartbeat correctly.
                                  125578 TSF:MSG:READ,0-0-66,s=3,c=1,t=2,pt=0,l=1,sg=0:0
                                  Incoming change for sensor:3, New status: 0
                                  Setting new sleep time: 5 seconds.
                                  137926 MCO:SLP:MS=5000,SMS=1,I1=255,M1=255,I2=255,M2=255
                                  137939 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:134932
                                  Log Openhab: And the gateway receives heartbeat.
                                  18:21:37.174 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 66;3;1;0;2;0
                                  18:21:37.178 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'TestLight' received command OFF
                                  18:21:37.181 [INFO ] [marthome.event.ItemStateChangedEvent] - TestLight changed from ON to OFF
                                  18:22:15.416 [DEBUG] [rs.internal.protocol.MySensorsReader] - 66;255;3;0;22;134932
                                  18:22:16.372 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                                  18:22:16.408 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;2;2.1.1
                                  Log Openhab: When the node sleeps..
                                  18:26:52.396 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 66;3;1;0;2;0
                                  18:26:52.397 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'TestLight' received command OFF
                                  18:26:52.399 [INFO ] [marthome.event.ItemStateChangedEvent] - TestLight changed from ON to OFF
                                  As you can see there is no mention in the openhab log file about buffering or smart sleep. Or a received heartbeat. Which it gets.
                                  What am I doing wrong?
                                  B 1 Reply Last reply
                                  • L
                                    L
                                    LastSamurai
                                    Hi, just a short question as I haven't found any up to date information about it: I am thinking about switching from domoticz to openHab 2 (as I really like the new UIs and the auto discovery). I am using an ESP8266 based MQTT gateway. Does openhab 2 on a raspi work with Mysensors using MQTT and does it support the new sensors/actor types added Mysensors 2 (specially RGBW)?
                                    Thank you!
                                    • F
                                      F
                                      Fabien
                                      Yes you can using proxy items and rules. see example here : https://github.com/mortommy/MySensorDioder
                                      But why not switching to ethernet/serial gateway with @TimO OH2 plugin ?
                                      • L
                                        L
                                        LastSamurai
                                        Thanks @Fabien I have a serial gateway too, but I liked the idea of a MQTT gateway more because its much more flexible. Does Tims plugin not support MQTT? I wanted to use that.
                                        andreacioniA 1 Reply Last reply
                                        • L LastSamurai
                                          andreacioniA
                                          andreacioniA
                                          andreacioni
                                          Hi @LastSamurai , currently Timo is working on MQTT gateway but I don't know precisely when it will be available to all.
                                          @TimO said in openHAB 2.0 binding:
                                          @Fabien Thank you for your feedback!
                                          And: I've waited for that question according firmware updates to come up. :-D
                                          I've looked into it and I'm very interested but till now there is only the implementation in the library, I've not seen an implementation in a binding. I'll continue to look at it, but with low priority. :-)
                                          Current priority list is:
                                          1. Include binding in OH2 repository.
                                          2. Test and include the big refactoring from @andreacioni .
                                          3. Add MQTT gateway (proof of concept working, full integration after refactoring).
                                          4. Add little feature requests, add sensors ...
