  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 677.3k Views 99 Watching
  • S stoffej
    @nikos1671
    Where do I found the Mysensors Binding 2.0.0.201701181308 jar file for download?
    Or is it mandatory to compile it from source?
    Thanks Kristoffer
    TimO
    @stoffej HERE
    • T TimO
      @David-Link Are you sure the gateway isn't in a boot loop?
      David Link
      @TimO That's exactly what is going on. Thank you for the tip, I was pulling my hair out. Now on to solving that problem! Thanks again.
        mlava
        Hi @TimO
        I am having trouble but think I might be doing it wrong.
        Is it possible to use this binding with a MQTT gateway?
        I see that it needs to find the gateway on port 5003 but this isn't defined in MQTT gateway.
        Is it possible?
        • M mlava
          Hi @TimO
          Is it possible?
          TimO
          Hi @mlava !
          The MQTT gateway is not supported at the moment. I've done a proof of concept and it will be implemented after the refactoring we're currently working on.
          • T TimO
            Hi @mlava !
            mlava
            @TimO
            Wonderful, thank you for the answer.
            I'll wait eagerly for progress! 😀
            • D David Link
              Hello all! I believe I have done my due diligence in solving my own problem, but I am stuck. Can anyone point me in the right direction?
              I am trying to get started with an Ethernet Gateway. The gateway is displayed on the PaperUI, but in the log, it continues to try and connect to the ip bridge (Sending to MySensors: 0;0;3;0;2;)
              I am on:
              openhab 2.1.0-snapshot build #791
              MySensors Binding: 2.0.0.201701181308
              Gateway is using library 2.1.1
              I have tried:
              Clearing the EEPROM on the gateway thinking some garbage got stuck there.
              Set up and successfully used an MQTT gateway, thinking bad hardware?
              Restarted the binding, openhab, kitchen sink countless times.
              Updating everything to the latest build I could find
              Manually creating things
              The only thing that seems odd to me is the gateway repeats over and over what appears to be initialization data (displays ip address, 0;255;3;0;9;MC0;BGN;STP.....). However, it does receive data from a temperature node I built.
              I appreciate any pointers that can be provided, including "have you read this page?", though I think my Google search is permanently stuck on "mysensors openhab" at this point.
              Dave
              Andrew Currie
              @David-Link It looks like you have a similar issue to me re the ethernet gateway. I have also tried "everything" and then yesterday discovered an old bug that might have resurfaced. I just put the following up on github:
              https://github.com/mysensors/MySensors/issues/777
              It might help you..
              D 1 Reply Last reply
              • A
                Andrew Currie
                Further to my client ethernet gateway not working with the MySensors 2.1.1 library, I tried 2.0.0 and now go much further. The gateway does not keep restarting, talks to the openhab controller and at least reads the messages and tripped status from my motion sensor
                0;255;3;0;9;TSM:INIT
                0;255;3;0;9;TSM:RADIO:OK
                0;255;3;0;9;TSM:GW MODE
                0;255;3;0;9;TSM:READY
                IP: 192.168.1.9
                0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                0;255;3;0;9;TSP:SANCHK:OK```
                I had to turn on the skipStartupCheck for the ethernet gateway to come online in openhab (and the gateway serial monitor did show the 0;0;3;0;2; and ethernet messages between openhab and the gateway)
                15:10:13.316 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.1.9:5003]
                15:10:13.819 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                15:10:14.320 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                15:10:15.320 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                15:10:16.320 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                15:10:17.321 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                15:10:18.321 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Cannot start reading/writing thread, probably sync message (I_VERSION) not received. Try set skipStartupCheck to true
                15:10:18.322 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:1)
                15:10:18.322 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Disconnecting from IP bridge ...
                15:10:18.323 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Stopping Writer thread
                15:10:18.324 [DEBUG] [rs.internal.protocol.MySensorsReader] - Stopping Reader thread
                15:10:18.324 [ERROR] [rs.internal.protocol.MySensorsWriter] - (java.lang.InterruptedException) on writing to connection, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorsIpWriter
                15:10:18.325 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.InterruptedException: sleep interrupted) on reading from connection, message: class org.openhab.binding.mysensors.internal.protocol.ip.MySensorIpReader
                15:10:25.236 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Disposing of the MySensors bridge
                15:10:25.236 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Destroying connection
                15:10:25.236 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                15:10:25.237 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [1]
                15:10:25.237 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [1]
                15:10:25.239 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                15:10:25.239 [INFO ] [smarthome.event.ThingUpdatedEvent   ] - Thing 'mysensors:bridge-eth:cb1d6dd1' has been updated.
                15:10:25.240 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Set skip check on startup to: true
                15:10:25.240 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Enabling connection watchdog
                15:10:25.240 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                15:10:25.241 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Connecting to IP bridge [192.168.1.9:5003]
                15:10:25.241 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: [1]
                15:10:25.241 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                15:10:25.244 [WARN ] [al.protocol.ip.MySensorsIpConnection] - Skipping I_VERSION connection test, not recommended...
                15:10:25.244 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                I then got my motion sensor to come online in openhab
                15:13:24.300 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: nodeId 1, chiledId: 1, requestAck: false, revertState: false, smartSleep: false
                15:13:24.301 [DEBUG] [ternal.handler.MySensorsThingHandler] - Event listener for node 1-1 not registered yet, registering...
                15:13:24.305 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:motion:24559d07' changed from INITIALIZING to ONLINE```
                However the motion sensor (via gateway) and openhab controller are not talking to each other. Does skipping the startup check result in problems?
                Any ideas on how to progress with MySensors 2.0.0 library or do I need to wait for a fix to 2.1.1?
                Many Thanks...
                • A Andrew Currie
                  It might help you..
                  David Link
                  @Andrew-Currie I think that is the same thing I am dealing with. I will take a look, thank you!
                  I "cheated" and just hooked it up to my Pi that is running OpenHab and it works like a charm.
                  • A Andrew Currie
                    IP: 192.168.1.9
                    Many Thanks...
                    TimO
                    @Andrew-Currie It should make no difference for the binding if you're using 2.0.0 or 2.1.1. I can't see any incoming messages in the debug log you've posted. If the gateway is properly connected you should see messages incoming, for example from your motion sensor. Could you please establish a telnet connection to the gateway at port 5003 and post the output? In parallel check the serial output of the gateway, there you should see the establishment of the telnet connection for example.
                    A 1 Reply Last reply
                    • T TimO
                      Andrew Currie
                      @TimO Thanks Tim for your feedback. Here is the log from the gateway. It receives messages from openhab re the ethernet connection and also from the motion sensor and gets a fail from one send
                      IP: 192.168.1.9
                      0;255;3;0;9;Eth: connect
                      0;255;3;0;9;Eth: 0;0;3;0;2;
                      0;255;3;0;9;Eth:
                      0;255;3;0;9;Eth:
                      0;255;3;0;9;Eth:
                      0;255;3;0;9;Eth:
                      0;255;3;0;9;Eth:
                      0;255;3;0;9;Eth: disconnect
                      0;255;3;0;9;Eth:
                      0;255;3;0;9;Eth:
                      0;255;3;0;9;Eth:
                      0;255;3;0;9;Eth:
                      0;255;3;0;9;Eth:
                      0;255;3;0;9;TSP:MSG:READ 1-1-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                      0;255;3;0;9;TSP:MSG:BC
                      0;255;3;0;9;TSP:MSG:FPAR REQ (sender=1)
                      0;255;3;0;9;TSP:CHKUPL:OK
                      0;255;3;0;9;TSP:MSG:GWL OK
                      0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                      0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      0;255;3;0;9;TSP:MSG:PINGED (ID=1, hops=1)
                      0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                      0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      0;255;3;0;9;!TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
                      0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                      0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor
                      0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                      0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=0,t=1,pt=0,l=0,sg=0:
                      0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                      0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                      The telnet connection shows no action and the gateway device is on the local network
                      $ telnet 192.168.1.9 5003
                      Trying 192.168.1.9...
                      Connected to 192.168.1.9.
                      Escape character is '^]'.
                      $ arp -a
                      HPB482AF (192.168.1.2) at 28:92:4a:c0:c3:27 [ether] on wlan0
                      WIZnet9FFEED (192.168.1.9) at de:ad:b1:9f:fe:ed [ether] on wlan0
                      NB604N.Home (192.168.1.1) at 00:60:64:83:50:8b [ether] on wlan0
                      HF-LPB100 (192.168.1.12) at f0:fe:6b:16:a1:4a [ether] on wlan0
                      I have tried all sorts of ubuntu firewall settings to allow access to and from 192.168.1.9 port 5003 and also looked into the router settings with no joy.
                      As another approach I tried the serial gateway and investigated the linux settings given in
                      http://docs.openhab.org/installation/linux.html#privileges-for-common-peripherals
                      The furthest I got with the serial gateway was as follows, first the debug log at startup and then when creating the gateway thing in the paper ui
                      10:07:04.218 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.mysensors.internal.factory.MySensorsHandlerFactory, component.id=197, service.id=340, service.bundleid=250, service.scope=bundle} - org.openhab.binding.mysensors
                      10:07:04.219 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTED – org.openhab.binding.mysensors
                      10:08:52.520 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=341, service.bundleid=250, service.scope=singleton} – org.openhab.binding.mysensors
                      10:08:52.524 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                      10:08:52.526 [DEBUG] [col.serial.MySensorsSerialConnection] - Set skip check on startup to: false
                      10:08:52.526 [DEBUG] [col.serial.MySensorsSerialConnection] - Enabling connection watchdog
                      10:08:52.527 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to ttyUSB1 [baudRate:115200]
                      10:08:52.530 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                      10:08:52.531 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
                      10:08:52.532 [DEBUG] [ernal.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                      testRead() open failed: /dev/ttyUSB1
                      localClose: File Descriptor error, not closing
                      10:08:52.545 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: ttyUSB1:/dev/ttyUSB1
                      testRead() open failed: ttyUSB1
                      Failed to connect on port: ttyUSB1 exception:
                      gnu.io.NoSuchPortException
                      While my plan was to test on my ubuntu 16.04 laptop, I have gone ahead and ordered a Raspberry pi 3 and intend to install the openhabianpi img file. Hopefully better progress there...
                      • B
                        B
                        balder88
                        Hey guys, first message on this forum. Been reading alot before. But now I have a problem I just can't solve.
                        It's about smartsleep with openhab 2.
                        Im using wifi gw rfm 69.
                        Regular messages works as it should both ways.
                        But it almost seems like the smartsleep isn't enabled in the binding.
                        Here are my configs and logs.
                        Things file:
                        Bridge mysensors:bridge-eth:gw69 [ ipAddress="192.168.1.235", tcpPort=5003, sendDelay=100, enableNetworkSanCheck=true ] {
                        //  Anarduino
                            humidity        AnHum   [ nodeId="66", childId="0" ]
                            temperature     AnTemp  [ nodeId="66", childId="1" ]
                            light           light02 [ nodeId="66", childId="3", smartSleep=true ]
                        Items file:
                        Switch  TestLight   "Test lampa" (Test) { channel="mysensors:light:gw69:light02:status" }
                        Sketch: (Cleaned up the parts that dont matter, RTC and so on.)
                        #define MY_RADIO_RFM69
                        #define MY_IS_RFM69HW
                        #define MY_NODE_ID 66
                        #define MY_SMART_SLEEP_WAIT_DURATION_MS 1000
                        #include <TimeLib.h>
                        #include <MCP7940RTC.h>
                        #define MCP7940_CTRL_ID 0x6F
                        #define CSMEM_PIN 5
                        #define LEDPIN 9
                        long sleepIntervalSec=5;
                        long loopCnt=0;
                        uint8_t d[8];
                        uint8_t dAlarm[8];
                        int d1[8];
                        #define DHT_DATA_PIN 6
                        #define SENSOR_TEMP_OFFSET 0
                        static const uint64_t UPDATE_INTERVAL = 5000;
                        #define CHILD_ID_HUM 0
                        #define CHILD_ID_TEMP 1
                        #define CHILD_ID_MULTIMETER 2
                        float lastTemp;
                        float lastHum;
                        uint8_t nNoUpdatesTemp;
                        uint8_t nNoUpdatesHum;
                        bool metric = true;
                        MyMessage msgVolt(CHILD_ID_MULTIMETER, V_VOLTAGE);
                        DHT dht;
                        int oldBatteryPcnt = 0;
                        int batteryBasement = 812;
                        int batteryFull = 922;
                        float batteryConstant = 100.0 / (batteryFull - batteryBasement);
                        float lastbatteryV = 0;
                        const int buzzer = 7; //buzzer to arduino pin 7
                        #define RELAY_1  8  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                        void before()
                          for (int sensor=3, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
                            pinMode(pin, OUTPUT);
                           analogReference(INTERNAL);
                          pinMode(LEDPIN, OUTPUT);
                          digitalWrite(LEDPIN, LOW);
                          Wire.begin();
                          pinMode(CSMEM_PIN, OUTPUT);
                          digitalWrite(CSMEM_PIN, HIGH);
                          sleepIntervalSec = dht.getMinimumSamplingPeriod();
                          clearAlarm();
                          delay(20);
                          setNewAlarm();
                          analogRead(BATTERY_SENSE_PIN);
                           sendSketchInfo("Humidity sensor", "1.0");
                           present(CHILD_ID_MULTIMETER, S_MULTIMETER, "VOLT", true);
                           present(CHILD_ID_HUM, S_HUM, "HUMIDITY", true);
                           present(CHILD_ID_TEMP, S_TEMP, "TEMP", true);
                            present(sensor, S_BINARY);
                          wait(100);
                           #ifdef MY_DEBUG
                           Serial.println(sensorValue);
                           float batteryV  = sensorValue * 0.004551646;
                           if(sensorValue < batteryBasement) {
                            sensorValue = batteryBasement;
                            batteryV = 0;
                           else if (sensorValue > batteryFull) {
                            sensorValue = batteryFull;
                           int batteryPcnt = (sensorValue - batteryBasement) * batteryConstant;
                               if ((abs(oldBatteryPcnt - batteryPcnt) > 1)) {
                              oldBatteryPcnt = batteryPcnt;
                           if(batteryV != lastbatteryV) {
                           send(msgVolt.set(batteryV, 2));
                           lastbatteryV = batteryV;
                           #ifdef MY_DEBUG
                           Serial.print(batteryV);
                           Serial.println(" V");
                           Serial.print(batteryPcnt);
                           Serial.println(" %");
                          dht.readSensor(true);
                          if (isnan(temperature)) {
                            lastTemp = temperature;
                            if (!metric) {
                            // Reset no updates counter
                            nNoUpdatesTemp = 0;
                            #ifdef MY_DEBUG
                            Serial.print("T: ");
                            nNoUpdatesTemp++;
                          if (isnan(humidity)) {
                            lastHum = humidity;
                            nNoUpdatesHum = 0;
                            #ifdef MY_DEBUG
                            Serial.print("H: ");
                            Serial.println(humidity);
                            nNoUpdatesHum++;
                        long sleepTime = UPDATE_INTERVAL;
                        if (batteryPcnt < 50) {
                          sleepTime = (sleepTime * 2);
                          sleepIntervalSec = sleepTime / 1000;
                          Serial.println();
                          Serial.print("Setting new sleep time: ");
                          Serial.print(sleepIntervalSec);
                          Serial.println(" seconds.");
                          clearAlarm();
                          delay(20);
                          setNewAlarm();
                          smartSleep(sleepTime);
                          if (message.type==V_STATUS) {
                            // Change relay state
                            // Store state in eeprom
                        Sensor startup:
                        3 MCO:BGN:BFR
                        4 TSM:INIT
                        5 TSF:WUR:MS=0
                        8 TSM:INIT:TSP OK
                        9 TSM:INIT:STATID=66
                        11 TSF:SID:OK,ID=66
                        13 TSM:FPAR
                        143 TSF:MSG:SEND,66-66-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        524 TSF:MSG:READ,0-0-66,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                        529 TSF:MSG:FPAR OK,ID=0,D=1
                        2150 TSM:FPAR:OK
                        2151 TSM:ID
                        2152 TSM:ID:OK
                        2154 TSM:UPL
                        2161 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                        2181 TSF:MSG:READ,0-0-66,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                        2186 TSF:MSG:PONG RECV,HP=1
                        2189 TSM:UPL:OK
                        2190 TSM:READY:ID=66,PAR=0,DIS=1
                        2199 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                        2253 TSF:MSG:READ,0-0-66,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                        2310 TSF:MSG:SEND,66-66-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                        2366 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                        2403 TSF:MSG:READ,0-0-66,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                        2461 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=OK:Humidity sensor
                        2562 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                        2618 TSF:MSG:SEND,66-66-0-0,s=2,c=0,t=30,pt=0,l=4,sg=0,ft=0,st=OK:VOLT
                        2757 !TSF:MSG:SEND,66-66-0-0,s=0,c=0,t=7,pt=0,l=8,sg=0,ft=0,st=NACK:HUMIDITY
                        2777 TSF:MSG:SEND,66-66-0-0,s=1,c=0,t=6,pt=0,l=4,sg=0,ft=1,st=OK:TEMP
                        2912 !TSF:MSG:SEND,66-66-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=NACK:
                        2918 MCO:REG:REQ
                        2974 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                        2991 TSF:MSG:READ,0-0-66,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                        2996 MCO:PIM:NODE REG=1
                        2999 MCO:BGN:STP
                        3154 MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
                        3160 MCO:SLP:TPD
                        3161 MCO:SLP:WUP=-1
                        3163 MCO:BGN:INIT OK,TSP=1
                        Log Sensor: (This is when I press the button when the sensor is awake)
                        It's sends away it's heartbeat correctly.
                        125578 TSF:MSG:READ,0-0-66,s=3,c=1,t=2,pt=0,l=1,sg=0:0
                        Setting new sleep time: 5 seconds.
                        137926 MCO:SLP:MS=5000,SMS=1,I1=255,M1=255,I2=255,M2=255
                        137939 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:134932
                        Log Openhab: And the gateway receives heartbeat.
                        18:21:37.174 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 66;3;1;0;2;0
                        18:21:37.178 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'TestLight' received command OFF
                        18:21:37.181 [INFO ] [marthome.event.ItemStateChangedEvent] - TestLight changed from ON to OFF
                        18:22:15.416 [DEBUG] [rs.internal.protocol.MySensorsReader] - 66;255;3;0;22;134932
                        18:22:16.372 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                        18:22:16.408 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;2;2.1.1
                        Log Openhab: When the node sleeps..
                        18:26:52.396 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 66;3;1;0;2;0
                        18:26:52.397 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'TestLight' received command OFF
                        18:26:52.399 [INFO ] [marthome.event.ItemStateChangedEvent] - TestLight changed from ON to OFF
                        As you can see there is no mention in the openhab log file about buffering or smart sleep. Or a received heartbeat. Which it gets.
                        What am I doing wrong?
                        B 1 Reply Last reply
                        • L
                          L
                          LastSamurai
                          Hi, just a short question as I haven't found any up to date information about it: I am thinking about switching from domoticz to openHab 2 (as I really like the new UIs and the auto discovery). I am using an ESP8266 based MQTT gateway. Does openhab 2 on a raspi work with Mysensors using MQTT and does it support the new sensors/actor types added Mysensors 2 (specially RGBW)?
                          Thank you!
                          • F
                            F
                            Fabien
                            Yes you can using proxy items and rules. see example here : https://github.com/mortommy/MySensorDioder
                            But why not switching to ethernet/serial gateway with @TimO OH2 plugin ?
                            • L
                              L
                              LastSamurai
                              Thanks @Fabien I have a serial gateway too, but I liked the idea of a MQTT gateway more because its much more flexible. Does Tims plugin not support MQTT? I wanted to use that.
                              andreacioniA 1 Reply Last reply
                              • L LastSamurai
                                andreacioniA
                                andreacioniA
                                andreacioni
                                Hi @LastSamurai , currently Timo is working on MQTT gateway but I don't know precisely when it will be available to all.
                                @Fabien Thank you for your feedback!
                                And: I've waited for that question according firmware updates to come up. :-D
                                I've looked into it and I'm very interested but till now there is only the implementation in the library, I've not seen an implementation in a binding. I'll continue to look at it, but with low priority. :-)
                                Current priority list is:
                                1. Include binding in OH2 repository.
                                2. Test and include the big refactoring from @andreacioni .
                                3. Add MQTT gateway (proof of concept working, full integration after refactoring).
                                4. Add little feature requests, add sensors ...
                                • L
                                  L
                                  LastSamurai
                                  Ok, I will keep an eye on this one and stay with the serial gateway for now.
                                  • A
                                    Andrew Currie
                                    After moving from my ubuntu laptop to RP3 I have had success!!
                                    Flashed the sd card with the latest openhabian, waited for everything to auto install on the RP3 and could then install the my sensors (ethernet) gateway on the pi and also open a karaf console to log openhab2 via a remote/headless ssh. My remote browser could open the paper ui via openhabianpi:8080 and I added the ethernet gateway successfully. Adding the motion sensor needed the node id 2 and child id 1 as set by the Arduino sketch. The light level sensor was then turned on and it just showed up as my sensors (2,2) in the paper ui inbox so this level of discovery works! The sensors now show tripped status/light level in the paper ui control.
                                    Looks like I can now progress to using My Sensors to control the mi-lights already working in openhab2.
                                    Thanks Tim for all your work on the binding
                                    • AndrewZA
                                      AndrewZA
                                      AndrewZ
                                      @TimO , I just noticed a weird behavior - I've changed configuration for another binding and restarted it from the console but that killed mysensors binding:
                                      2017-03-04 13:07:19.110 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'demo.things'
                                      2017-03-04 13:07:19.123 [ERROR] [col.serial.MySensorsSerialConnection] - Interrupted reset time wait
                                      2017-03-04 13:07:19.124 [WARN ] [col.serial.MySensorsSerialConnection] - Skipping I_VERSION connection test, not recommended...
                                      2017-03-04 13:07:19.125 [INFO ] [col.serial.MySensorsSerialConnection] - Successfully connected to MySensors Bridge.
                                      2017-03-04 13:07:19.125 [WARN ] [col.serial.MySensorsSerialConnection] - Network Sanity Checker thread disabled from bridge configuration
                                      2017-03-04 13:07:21.141 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
                                      2017-03-04 13:07:21.149 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
                                      2017-03-04 13:07:33.161 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
                                      2017-03-04 13:07:33.163 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:1)
                                      Complete stop/start of OH is the only solution so far.
                                      • AndrewZA AndrewZ
                                        andreacioniA
                                        andreacioniA
                                        andreacioni
                                        Hi @AndrewZ , yes this is a known issue (I just openend an issue here) with the binding. Just out of curiosity, have you changed something in things file?
                                        AndrewZA 1 Reply Last reply
                                        • andreacioniA andreacioni
                                          AndrewZA
                                          AndrewZA
                                          AndrewZ
                                          @andreacioni thank you
                                          Yes, it was a change in the .things file, but it was related to another binding.
