  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 678.2k Views 99 Watching
  • G
    G
    gonzalonal
    Hi Tim0.
    Really nice work with this binding. Huge step forward into a official MySensors OpenHAB binding.
    It would be nice to have the repo updated so as to try the new features you have implemented.
    Have you had time to check why we are gewtting that error at OpenHAB 2 Beta while trying to install the binding?
    Let me know if there is any way in which I can help.
    Thanks, regards!
    Gonzalo.
    • T
      TimO
      Hi @gonzalonal !
      I'm working on it. Due to the changes in the OH git repository my environment is all messed up. :-(
      • andreacioniA
        andreacioniA
        andreacioni
        wrote on last edited by andreacioni
        #103
        This kind of problem (as I've read online) in this release of OH seems to be not only related to this binding. One suggestion that I found is here: https://github.com/openhab/openhab-distro/issues/82 (last comment) or here: https://github.com/openhab/openhab-distro/issues/81
        I've tested it without success but I don't know if I've done it right. I've also try to build myself a rfxcom binding (this one use gnu.io) and it has the same issue
        hope this help
        EDIT: this work for me, run on OSGI console: feature:install openhab-transport-serial and restart OH
        G T 2 Replies Last reply
        • andreacioniA andreacioni
          hope this help
          G
          G
          gonzalonal
          hope this help
          Hi @andreacioni.
          You saved the day. It worked for me.
          Here the steps I did to make it work.
          1- Download latest snapshot from https://openhab.ci.cloudbees.com/job/openHAB-Distribution/ (Download offline version)
          2- Unzip the file.
          3- Run start_debug.sh
          4- In console write "feature:install openhab-runtime-compat1x"
          5- Ctrl-D to exit/shutdown OpenHAB
          6- Once exited, copy MySensors binding to addons folder.
          7- Start againg OpenHAB-
          8- Thats it. It should work
          Remember to copy your serial thing to things folder.
          Regards!
          Gonzalo
            hope this help
            TimO
            @andreacioni: Absolultly amazing! Thanks!
            I don't understand why this helps though because the changes in the code I have to do have nothing to do with OH1 (compability).
            I hope to provide an adjusted version today or tomorrow along with a clean and working repository.
            Thanks for your patience! :-)
            andreacioniA 1 Reply Last reply
            • T TimO
              andreacioniA
              andreacioniA
              andreacioni
              #106
              @TimO I'think the OH1 compatibility is not the problem. It seems that OH2 beta1 have not installed transport feature and so it has no definition for the gno.io pakage, so I'think there's nothing to do on your code :D
              PS tell me when the new repo is OK that I download it and try to add the baudrate config ;) Thanks!!
              • T
                TimO
                So, I would like to show you my current status. I've tested it against my mini MySensors environment and it looks good so far. Feel free to test.
                1. Download latest snapshot from cloudbees: https://openhab.ci.cloudbees.com/job/openHAB-Distribution/lastSuccessfulBuild/artifact/distributions/openhab-offline/target/openhab-offline-2.0.0-SNAPSHOT.zip
                2. Unzip file (into a directory like oh2).
                3. Download the current binding from Binding and place it in the addons directory under oh2.
                4. Configure addons, things, items and sitemap. Example?! addons.cfg, demo.things , demo.items, demo.sitemap
                5. Start "start_debug.sh", "start_debug.bat" ...
                6. In the karaf console enter: "feature:install openhab-transport-serial".
                7. MySensors Plugin "should" start. ;-)
                8: "log:set debug" + "log:tail" to see debug output.
                Github and documentation will follow, please refer to the "old" Readme and the examples.
                • T TimO
                  andreacioniA
                  andreacioniA
                  andreacioni
                  @TimO Hi Tim, for debugging outupt of the binding I need to write: log:set DEBUG org.openhab.binding.mysensors, without this I cannot see anything about binding logs
                  G 1 Reply Last reply
                    G
                    G
                    gonzalonal
                    wrote on last edited by gonzalonal
                    #109
                    @andreacioni Hi andreacioni. Same issue with debug mode with me. Thanks for the tip!
                    @TimO: V_STOP for Rollershutter sensors, is a MySensors binding limitation, or it is not implemented in OH2 yet?
                    Another thing I've noticed is that every item added, despite being a regular switch or a rollershutter, is is being added as:
                    Battery Level
                    mysensors:cover:gateway:Cover_1_0:battery
                    MySensors Battery Channel
                    Is this the intended behavior for every node of my sensor, despite having or not a battery?
                    Regards.
                    Gonzalo.
                    • T
                      TimO
                      It is a limitation of OH2 and I don't understand the limitation. It is very confusing, because with the "RollerShutter" widget in OH2 I get three buttons: UP, DOWN and STOP. UP and down calls the handler in which I generate the MySensors message. STOP don't call the handler and therefore I can't do anything. I need to dig deeper.
                      Battery Level
                      This is intended behavior. The battery status is send via an internal message and there is no presentation if a sensor has a battery or not.
                      I've therefore added the battery channel to every item. In Paper UI you are able to simply disable the channel by clicking the blue circle next to the battery channel or in the configuration file you have to specify the channel, if you want to use it. If the battery channel is not defined for a thing it won't receive the battery status.
                      For the future: maybe there is a way to hide the channel as long as there was no battery status received and display it only when used. But currently I don't see an easy way to implement that.
                      Greetings!
                      Tim
                      • T TimO
                        Battery Level
                        Greetings!
                        Tim
                        G
                        G
                        gonzalonal
                        @TimO
                        Great TimO. Thanks for clarifying this topic.
                        Regards.
                        Gonzalo
                        • T
                          TimO
                          @gonzalonal : I found a solution for V_STOP! It will be available soon.
                          But more important: @andreacioni is doing some great work improving the stability and performance of the binding!!
                          I just wanted to let you know, that the binding is currently under heavy development. :+1:
                          • T TimO
                            G
                            G
                            gonzalonal
                            @TimO
                            Great news TimO. Really nice to hear that.
                            Regarding STOP functionality for the binding, I have read somewhere that the supported commands by OpenHAB, for RollerShutter items, are Up, Down and StopMove. Have yoy tried something like this?
                            Regards
                            Gonzalo.
                            • T
                              TimO
                              Yeah, my problem till yesterday was, that I was not able to cast the given state to StopMoveType in case of Stop, while casting the state to UpDownType for Up and Down was no problem. :-)
                              I changed the way how the binding handles this type of message and it works now.
                              S 1 Reply Last reply
                              • T TimO
                                Sebastián Zaffarano
                                @TimO
                                Can we clone the latest source code from this binding? I think that your github repository is outdated and I want to work this weekend with it, 'cause I would like to integrate the mysensors 2.0-beta "smartSleep" feature with your binding in my home sensors setup (ESP8266 Ethernet GW).
                                Also, if there are any ISSUE y your TODO list in which I can help you, please tell me.
                                Regards
                                • S Sebastián Zaffarano
                                  @TimO
                                  Regards
                                  andreacioniA
                                  andreacioniA
                                  andreacioni
                                  @Sebastián-Zaffarano
                                  Hi Sebastián, what repository have you checked? Currently the development is not on the old https://github.com/wishmoooop/openhab2/tree/master/addons/binding/org.openhab.binding.mysensors but was moved here: https://github.com/tobof/openhab2-addons/tree/MySensors/addons/binding/org.openhab.binding.mysensors
                                  Hope this help :)
                                    Hope this help :)
                                    Sebastián Zaffarano
                                    Hope this help :)
                                    Thanks @andreacioni
                                    I was working on the old repo! :)
                                    • T
                                      TimO
                                      I've updated the first posting in this thread. You'll find the current repo there (also). ;-)
                                      I've added a Wiki to the repo and made a brief description of the installation and configuration process.
                                      https://github.com/tobof/openhab2-addons/wiki
                                      The current binding (jar) is also in the repo now. You'll find the link in the wiki under "Installation".
                                      Modifications in the current version:
                                      • RollerShutter now supports STOP
                                      • Performance of the binding improved. Big thanks to @andreacioni !!
                                      • Stability improved. Also big thanks to @andreacioni
                                      • Error handling on connection loss improved
                                      • The baud rate of the serial gateway is now adjustable. (@andreacioni again!)
                                      • some code cleanup: removed not needed debug output etc.
                                      Please let me know if you found the time to test the binding and what the results are. :-)
                                      • T TimO
                                        Sebastián Zaffarano
                                        Thank you @TimO !
                                        This weekend I started migrating from my OH1.8 + mqtt GW setup to OH 2 beta + your binding. At the moment all is working fine, I spent some time learning about OH2 / Eclipse smartHome and watching your code, because I want to implement the smartSleep feature (https://github.com/mysensors/Arduino/pull/271) in the mysensors binding.
                                        My idea is: when the handler don't receive an ACK from a message, it store the message for a while, waiting a heartbeat from a node, and, if the binding has some message stored for this node, then send it again. I don't know if this is correct, or if you thinks there is a better solution.
                                        Regards
                                        • T
                                          TimO
                                          That sounds like a good plan. The binding already uses a queue where messages that should be send are buffered and you are able to specify how long a message is hold in the queue (when it is time to send again).
                                          I've already implemented a mechanism to request for an ACK message. This mechanism sends a message to the node, but holds this message in the queue and increments the number of retries (currently 4 retries, with different/longer delays). If the node responds with an ACK or the number of retries exceeds 4 the message is removed from queue. So you could indicate, with a configuration setting, that the node is an smartSleep node and thus only send the message once and if no ACK is received store the message for 10 minutes (for example) in the queue.
                                          Here is the implementation: https://github.com/tobof/openhab2-addons/blob/MySensors/addons/binding/org.openhab.binding.mysensors/src/main/java/org/openhab/binding/mysensors/protocol/MySensorsWriter.java
                                          BUT: The reader and the writer are working in different threads (asynchronus), so we have to sync the threads (the queue), if we receive an ACK and remove a message from the queue. I'm still struggling with that and that is the reason why the request for ACK should not be used at the moment and this will be a problem for smartSleep too.
                                          According to the ACK feature: if the binding don't receive an ACK after 4 timeouts it will revert the status of the thing to the last value. So if you for example try to switch on your light and the message is not acknowledged, the binding will revert the switch state to off. I've removed the code for this, because of the issue above, but will add it again in the future.
