  3. "Washing machine ended" sensor
21 Posts 11 Posters 18.2k Views 11 Watching
  • JahFyahhJ JahFyahh
    @Moshe-Livne how did you setup the sensitivity on the senser. I tried your advice, turning it to 0 (all the way to the left) then one stripe back. I pasted it with double sided tape to the top of the machine. Any other tips? I'm thinking of pasting it to the back of the machine.
    Moshe LivneM
    Moshe LivneM
    Moshe Livne
    @JahFyahh it was mostly trial and error. I was lucky and my initial setup was good but these sensors have very sensitive adjustment (all cheap sensors do, i think) and sometimes a fraction of a turn is enough to change things. I think I wrote a simple "read in a loop" sketch and shaked it a bit (like a washing machine, small shakes) to see if i have a read. Hope that helps. I think top of the machine vibrates a bit more than back. if you put on the back, maybe try to mount it high as the upper part moves more than the lower part.
