  3. Relay with actuator standalone functionality with no Gateway
3 Posts 2 Posters 2.5k Views 2 Watching
  • DrJeffD
    DrJeffD
    DrJeff
    In the sample code for the actuator and relay how hard is it to make the code work even if the gateway is off. That is the button/switch is still controlling the load locally. Optimally I want the code to handle a switch that is just toggling the relay even if the remote controller has changed the status of the light. The Idea is that locally the switch will still just function like a normal switch if the gateway is lost, or down.
     * Version 1.0 - Henrik Ekblad
     * Example sketch for a "light switch" where you can control light or something
     * else from both HA controller and a local physical button
     * (connected between digital pin 3 and GND).
     * This node also works as a repeader for other nodes
    #include <Bounce2.h>
    #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    int oldValue=0;
    bool state;
    MyMessage msg(CHILD_ID,V_LIGHT);
      gw.sendSketchInfo("Relay & Button", "1.0");
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      gw.present(CHILD_ID, S_LIGHT);
      pinMode(RELAY_PIN, OUTPUT);
      state = gw.loadState(CHILD_ID);
      gw.process();
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value==0) {
          gw.send(msg.set(state?false:true), true); // Send new state and request ack back
      oldValue = value;
      if (message.isAck()) {
         // Change relay state
         state = message.getBool();
         // Store state in eeprom
         gw.saveState(CHILD_ID, state);
         // Write some debug info
         Serial.print(message.sensor);
    • DrJeffD DrJeff
      #define RELAY_ON 1
      #define RELAY_OFF 0
      int oldValue=0;
      bool state;
       // Setup the button
        gw.process();
        debouncer.update();
        oldValue = value;
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @DrJeff
      you can try something like this, which changes state by either a button press or by the controller
      (untested)
      #define RELAY_ON 1
      #define RELAY_OFF 0
      int oldValue = 0;
      bool state;
      bool lastState = false;
      MyMessage msg(CHILD_ID, V_LIGHT);
        gw.sendSketchInfo("ButtonSwitch", "1.0");
        pinMode(BUTTON_PIN, INPUT);
        digitalWrite(BUTTON_PIN, HIGH);
        digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);
        gw.process();
        debouncer.update();
        if (value != oldValue && value == 0)
          state = !state;
        if (state != lastState)
          gw.send(msg.set(state ? true : false), true); // Send new state and request ack back
        lastState = state;
        oldValue = value;
      DrJeffD 1 Reply Last reply
        @DrJeff
        (untested)
        #define RELAY_ON 1
        #define RELAY_OFF 0
        int oldValue = 0;
        bool state;
          gw.process();
          debouncer.update();
            state = !state;
          lastState = state;
          oldValue = value;
        DrJeffD
        DrJeffD
        DrJeff
        @BulldogLowell Thanks I will give it a try!
