  3. My Sensor node "motherboard" (MySensorsNode)
72 Posts 13 Posters 45.0k Views 21 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    It's not designed for RFM69 but if you use an adapter and solder de bridge of the interrupt, then theoretically it could be used.
    The processor is an atmega328p (not a pro mini).
    • Cliff KarlssonC
      Cliff KarlssonC
      Cliff Karlsson
      I just got my boards from dirtyPCBs but are there any list of the required components? And can I use rfm69 with a 5v pro mini or do I have to use a 3.3v pro mini?
      AnticimexA 1 Reply Last reply
        AnticimexA
        AnticimexA
        Anticimex
        @Cliff-Karlsson you can find the BOM in GitHub under manufacturing. The board is designed for 3.3v pro mini. I have not taken 5v variant into consideration at all.
        • Cliff KarlssonC
          Cliff KarlssonC
          Cliff Karlsson
          Are all components required? I know you can only use one radio / pcb and that the power sockets are optional. But I tried to find the cheapest components and after adding all the components from aliexpress the cost is almost 100 EUR and then I got probably atleast as many components from the more expensive shops left.
            AnticimexA
            AnticimexA
            Anticimex
            @Cliff-Karlsson well, I did not consider cost for my board. That said, 100EUR is definitely not required to spend for components on it. It depends on how you intend to use it and what flexibility you want. The ability to control certain aspects is optional as indicated by jumper configurations. I made it clear in my schematic what parts are optional to solder. You can of course cut more cost by skipping decoupling and such as well, but I can't vouch for board performance in that case.
            • PejoP
              PejoP
              Pejo
              @Anticimex Do you know what screws are expected for the BOX-2252? Is it M2 or something else?
              • AnticimexA
                AnticimexA
                Anticimex
                @Pejo I believe M2.
                • PejoP
                  PejoP
                  Pejo
                  @Anticimex Thanks!
                  • Cliff KarlssonC
                    Cliff KarlssonC
                    Cliff Karlsson
                    Is it possible to only solder a mini pro 3.3v and an rfm69hw to your pcb and use it as a mysensors gateway? Or do I need to solder any more components?
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @Cliff-Karlsson it was never design for that purpose, but I suppose you could. You'll need to see the schematics to determine what additional components are needed for power and regulation. Decoupling is also highly recommend. Remember that you need to expose a serial port for the GW.
                      • MiKaM
                        MiKaM
                        MiKa
                        Can You share also pcb for BOX-2252 please
                        Thanks,
                        MiKa
                        • MiKaM MiKa
                          Thanks,
                          MiKa
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @MiKa https://www.openhardware.io/view/2/MySensors-node
                          It's all there. However, be adviced that the board has a hard time fitting BOX-2252.
                          • MiKaM
                            MiKaM
                            MiKa
                            Which one is problem to fit into the box? 2252 or LE-BOX-0028 ?
                            Here You wrote about 2252 and on the openhardware site is LE-BOX-0028...
                            Regards,
                            MiKa
                            • MiKaM MiKa
                              Regards,
                              MiKa
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @MiKa Hi, sorry, my bad. It is LE-BOX-0028 (the big one) that has problems fitting (at least the box I have).
                              • B
                                B
                                bilbolodz
                                Could some please point me to right (working) Dualoptiboot bootloader for these board? I'm fighting with it for over two days but without success.
                                • AnticimexA
                                  AnticimexA
                                  Anticimex
                                  I have not used dualoptiboot. But there should not be need for a special variant of it. It is a board that takes a standard arduino pro mini so a bootloader designed for that arduino should work just fine. Just make sure to configure the proper JEDEC ID for the flash.
                                  • B
                                    B
                                    bilbolodz
                                    I've took bootloader from: https://github.com/LowPowerLab/DualOptiboot
                                    What JEDEC ID is correct for AT25DF512C?
                                    • B bilbolodz
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      #58
                                      @bilbolodz that is stated in the datasheet of the device. Table 12.2. Manufacturer ID is 1Fh and Device ID part 1 is 65h. So you need to define MY_OTA_FLASH_JDECID to 0x1F65 (which is default I believe).
                                      I don't know if you need to reconfigure DualOptiboot if you took it from LowPowerLab. Perhaps.
                                      • B
                                        B
                                        bilbolodz
                                        I've got it working BUT I've very strange "solution". I'll write it down maybe someone be able to explain me what's going on:
                                        I've 3 versions of "test program" 1.0, 1.1, 1.2 (actually the only difference is sketch number).
                                        1. I'm uploading manually with avrdude DualOptiboot from "Mysensors board package" (uploading using gui not working - gives strange error about fuses).
                                        2. I'm uploading (using USBasp and Arduino GUI) program version 1.0: program is working but "Reboot" command send from MYSController gets arduin into endless loop during "boot"
                                        0 MCO:BGN:INIT REPEATER,CP=RNORAA-,VER=2.1.1
                                        4 TSM:INIT
                                        4 TSF:WUR:MS=0
                                        12 TSM:INIT:TSP OK
                                        14 TSF:0 MCO:BGN:INIT REPEATER,CP=RNORAA-,VER=2.1.1
                                        4 TSM:INIT
                                        4 TSF:WUR:MS=0
                                        12 TSM:INIT:TSP OK
                                        1. Physical reset of board and OTA update to v 1.1 using MYSControler. OTA update is finished but at the end "endless loop"
                                        133398 OTA:FWP:RECV B=0000
                                        133400 OTA:FWP:FW END
                                        136038 OTA:CRC:B=05A8,C=6506,F=6506
                                        136040 OTA:FWP:CRC OK
                                        4 TSM:INIT
                                        4 TSF:WUR:MS=0
                                        12 TSM:INIT:TSP OK
                                        14 TSF:�0 MCO:BGN:INIT REPEATER,CP=RNORAA-,VER=2.1.1
                                        4 TSM:INIT
                                        4 TSF:WUR:MS=0
                                        12 TSM:INIT:TSP OK
                                        1. Physical reset of board: still version 1.0 present and running, reboot NOT working
                                        2. One again I program bootloader using command:
                                        avrdude -c usbasp -p m328p -u -U flash:w:optiboot_atmega328_pro_8MHz.hex
                                        1. Surprise, surprise: version 1.1 present and running, reboot command WORKING!
                                        2. After these I can program freely (using OTA) other versions of program (e.x. 1.2 or even "start version" 1.0)
                                        I'm making some STUPID mistake but I can't find it......
                                        AnticimexA rozpruwaczR 2 Replies Last reply
                                        • B bilbolodz
                                          4 TSM:INIT
                                          4 TSF:WUR:MS=0
                                          12 TSM:INIT:TSP OK
                                          4 TSM:INIT
                                          4 TSF:WUR:MS=0
                                          12 TSM:INIT:TSP OK
                                          4 TSM:INIT
                                          4 TSF:WUR:MS=0
                                          12 TSM:INIT:TSP OK
                                          4 TSM:INIT
                                          4 TSF:WUR:MS=0
                                          12 TSM:INIT:TSP OK
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @bilbolodz hm, sorry. Can't really help there. The board should be SenseBender compatible so what ever flow is described for that board (and bootloader designed for that board) should work on this. But perhaps the fact that this one has a pro mini and not just a vanilla atmega cause it to behave differently in some way.
