  3. Battery percentage incorrectly send to gateway.
6 Posts 3 Posters 3.4k Views 2 Watching
  • P
    P
    pjeterinfo
    wrote on last edited by pjeterinfo
    I ordered a custom pcb with a ATMega328P and a dallas tempsensor , powered by 2AA batteries. Simular like http://forum.mysensors.org/topic/1107/sensors-in-boxes/7.
    I use allso the sketch as shown in that topic, however the battery status allways read 102%. I'm sure the batteries are not full.
    Can you point me in the right direction why my battery percentage is not send correctly?
    // Example sketch showing how to send in OneWire temperature readings
    #include <OneWire.h>
    OneWire oneWire(ONE_WIRE_BUS);
    int numSensors=0;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
    MyMessage msgvolt(1,V_VOLTAGE);
    int BATTERY_SENSE_PIN = A0;
    int oldBatteryPcnt = 0;
    analogReference(INTERNAL);
    // Startup OneWire
    sensors.begin();
    gw.begin();
    gw.sendSketchInfo("Temperature Sensor", "1.0");
    gw.present(i, S_TEMP);
    gw.process();
    // Battery Monitoring
    float batteryV = sensorValue * 0.003363075;
    Serial.print(batteryV);
    Serial.println(" V");
    Serial.print(batteryPcnt);
    Serial.println(" %");
    gw.send(msgvolt.set(batteryPcnt,1));
    oldBatteryPcnt = batteryPcnt;
    if (lastTemperature[i] != temperature && temperature != -127.00) {
    gw.sleep(SLEEP_TIME);
    • DwaltD
      DwaltD
      Dwalt
      I believe the sketch you linked was built for 2-AAA batteries, not 2-AA.
      • P
        P
        pjeterinfo
        I tried just with 2 AAA batteries (used from a remotecontrol), again it shows 102%. :-(
        • sundberg84S
          Did you wire the voltage divider like this? http://www.mysensors.org/build/battery or how does your wiring look like=?
          • P
            P
            pjeterinfo
            @sundberg84
            This is a screenshot of the schema. ( left out the top layer which is only used for the radio)
            I tried the basic battery sensor sketch. I see that the sensor value is devided 10.
            Should this be default or can I calculate how the devider should be programmed?
            end: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=o x00x00send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
            send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
            read: 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
            sensor started, id=1, parent=0, distance=1
            send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,st=ok:Battery Meter
            send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
            1023
            Battery Voltage: 3.44 V
            Battery percent: 102 %
            send: 1-1-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:102
            • P
              P
              pjeterinfo
              Ok... resistors are switched place , problem solved ;-) make a big difference offcource.
              934
              Battery Voltage: 3.14 V
              Battery percent: 93 %
              send: 1-1-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:93
