  3. Domoticz
  4. Domoticz and ACK
Domoticz and ACK
9 Posts 4 Posters 6.2k Views 3 Watching
  • Y Offline
    Y Offline
    yury
    wrote on last edited by yury
    Is there any way to make Domoticz read back acknowledgements from relay nodes when you turn them on or off? Like when you press on and if radio fails GUI icon will show as it is off.
    • N Offline
      N Offline
      NewFolk
      wrote on last edited by NewFolk
      Hello @yury
      Did you find workaround ?
      You could ask gizmocuz for help.
      https://www.domoticz.com/forum/viewtopic.php?f=42&t=7839&p=58270#p58270
      • Y Offline
        Y Offline
        yury
        Hello @NewFolk !
        Not yet.
        Thanks for your post in domoticz forum!
        • N Offline
          N Offline
          NewFolk
          Great news guys!!!
          Take a look at Beta version #3448.
          http://www.domoticz.com/forum/viewtopic.php?f=42&t=7839&p=59180#p59163
          • Y Offline
            Y Offline
            yury
            Super!!!
            One little issue I found so far. If there is a repeater used between the node and the gateway, somehow domoticz accept ack from from repeater even if node is off line.
            Otherwise it works very nice.
            • N Offline
              N Offline
              NewFolk
              Are you sure? Post it on domoticz forum. I can`t test this.
              • P Offline
                P Offline
                pjr
                Eh. better question could be why repeater sends that ack in any case? Shouldnt it behave just as repeater... :/
                F 1 Reply Last reply
                • P pjr
                  F Offline
                  F Offline
                  fets
                  @pjr :+1:
                  • Y Offline
                    Y Offline
                    yury
                    Everything is OK. It was my mistake.
                    I did not do clear EPROM properly... so I ended up with the repeater and the node with the same nodeID which I hard coded. That is why repeater ACK was accepted as node ACK.
                    All work great.
                    12.2k
